查看: 2663|回复: 3
带定时功能时钟问题,望各位指教一番
ID:51589 发表于 2013-7-8 21:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题描述:烧入程序之后,LED显示如图所示,望各位指教
#include<AT89X51.h>
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99
,0x92,0x82,0xf8,0x80,0x90};//共阳数码管
uchar time,hour_now,min_now,sec_now,hour_a1,min_a1,sec_a1,key;
sbit beep=P3^7;
void delayms(uchar i)
while(i--);
void write(uchar num,chose)
uchar i;
for(i=0;i<2;i++)
  P0=0xff;
     P2=~chose;//位选
     if(i==0)
        P0=table[num%10];//段选
        P0=table[num/10];//段选
  chose=chose<<1;
     delayms(5000);
void show()
P0=0xff;
P2=0xdb;
P0=0xbf;
delayms(5000);
}//-隔开时,分,秒显示
void init()
TMOD=0x01;
TH0=0x4c;
TL0=0x00;
EA=1;
ET0=1;
TR0=1;
void display(uchar hour_now,uchar min_now,uchar sec_now)
  write(sec_now,0x01);
  write(min_now,0x08);
  write(hour_now,0x40);
  show();
void jianpanjiance()
uchar temp;
P1=0xfe;
temp=P1;
if(temp!=temp&0xf0)
    delayms(10000);
temp=P1;
if(temp!=temp&0xf0)
    temp=P1;
    switch(temp)
     case 0xee:
             key=1;
         break;
  case 0xde:
         key=2;
      break;
  case 0xbe:
         key=3;
      break;
  case 0x7e:
         key=4;
      break;
while(temp!=0xf0)
   temp=P1;
         temp=temp&0xf0;
P1=0xfd;
temp=P1;
if(temp!=temp&0xf0)
    delayms(10000);
temp=P1;
if(temp!=temp&0xf0)
    temp=P1;
    switch(temp)
     case 0xed:
             key=5;
         break;
  case 0xdd:
         key=6;
      break;
  case 0xbd:
         key=7;
      break;
  case 0x7d:
         key=8;
      break;
while(temp!=0xf0)
   temp=P1;
         temp=temp&0xf0;
P1=0xfb;
temp=P1;
if(temp!=temp&0xf0)
    delayms(10000);
temp=P1;
if(temp!=temp&0xf0)
    temp=P1;
    switch(temp)
     case 0xeb:
             key=9;
         break;
  case 0xdb:
         key=10;
      break;
  case 0xbb:
         key=11;
      break;
  case 0x7b:
         key=12;
      break;
while(temp!=0xf0)
   temp=P1;
         temp=temp&0xf0;
P1=0xf7;
temp=P1;
if(temp!=temp&0xf0)
    delayms(10000);
temp=P1;
if(temp!=temp&0xf0)
    temp=P1;
    switch(temp)
     case 0xe7:
             key=13;
         break;
  case 0xd7:
         key=14;
      break;
  case 0xb7:
         key=15;
      break;
  case 0x77:
         key=16;
      break;
while(temp!=0xf0)
   temp=P1;
         temp=temp&0xf0;
void display_key(uchar hour,uchar min,uchar sec,tkey)
uchar i=0,take_key;
uchar data timenum[]={0,0,0,0,0,0};
jianpanjiance();
if(key==tkey)
    take_key=1;
    timenum[0]=hour/10;
timenum[1]=hour%10;
timenum[2]=min/10;
timenum[3]=min%10;
while(take_key==1)
  jianpanjiance();
  if(key<11)
     i++;
  timenum[i-1]=key;
  key=17;
  if(key==12)
    take_key=0;
  if(i==6)
    take_key=0;
  hour=timenum[0]*10+timenum[1];
  min=timenum[2]*10+timenum[3];
  sec=timenum[4]*10+timenum[5];
  display(hour,min,sec);
    if(sec>59)
   sec=0;
if(min>59)
   min=0;
if(hour>23)
   hour=0;
if(key==11)
    sec_now=sec;
    min_now=min;
    hour_now=hour;
if(key==13)
    sec_a1=sec;
    min_a1=min;
    hour_a1=hour;
hour_now=23;
min_now=37;
sec_now=50;
display(hour_now,min_now,sec_now);
init();
   display_key(hour_now,min_now,sec_now,11);
   display_key(hour_a1,min_a1,sec_a1,13);
void T0_Time() interrupt 1
TH0=0x4c;
TL0=0x00;
time++;
if(time==20)
    time=0;
      if(hour_now==hour_a1&min_now==min_a1)
      beep=0;
      beep=1;
       sec_now++;
    if(sec_now==60)
       sec_now=0;
       min_now++;
        if(min_now==60)
          min_now=0;
          hour_now++;
          if(hour_now==24)
             hour_now=0;
收藏收藏1 分享淘帖 顶 踩
ID:1 发表于 2013-7-8 23:00 | 只看该作者
工程文件上传上来 我看看
ID:51589 发表于 2013-7-10 00:21 | 只看该作者
admin 发表于 2013-7-8 23:00
工程文件上传上来 我看看
Desktop.zip (22.71 KB, 下载次数: 3)
ID:51589 发表于 2013-7-10 00:23 | 只看该作者
工程文件上传上来 我看看
工程文件 Desktop.zip (22.71 KB, 下载次数: 5)
