材料清单:
1供电:12V航模电池,12V~5V转电压模块,开关*1
2控制:STM32C8T6最小系统板,红外避障模块*2
3驱动:L298N驱动模块*2
4对象:电机*4的小车
注:红色部分不可缺。
放实物图
32避障小车实物图
线路连接图
线路原理图
(避障模块没有放进去因为是低电平触发,两个避障模块接B0,B1口)
STM32单片机源程序文件:
- #include "ALLhander.h"
- int main(void)
- LED_Config();
- Motor_enable_Init();
- Motor_PWM_control_GPIO_Config();
- Tim3_mode_Config(T_Period,T_PSC,200);
- Total_NVIC_interrupt_config();
- Obstacle_avoidance();
- while(1)
- straight();
- Systick_Delay_ms(1000);
复制代码 L298N配置文件
- #include "L298N_GPIO.h"
- #include "systick.h"
- void LED_Config(void)
- GPIO_InitTypeDef GPIO_InitStruct;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
- //LED指示灯
- GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;
- GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOC, &GPIO_InitStruct);
- void Front_Motor_enzble_control(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- GPIO_InitStructure.GPIO_Pin = Motor1_cw_Pin|Motor1_ccw_Pin|Motor2_cw_Pin|Motor2_ccw_Pin;
- GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- void Back_Motor_enzble_control(void)
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
- GPIO_InitStructure.GPIO_Pin = Motor3_cw_Pin|Motor3_ccw_Pin|Motor4_cw_Pin|Motor4_ccw_Pin;
- GPIO_Init(GPIOB,&GPIO_InitStructure);
- void Motor_enable_Init(void)
- Front_Motor_enzble_control();
- Back_Motor_enzble_control();
- void Motor_PWM_control_GPIO_Config(void)
- //RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
- //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- GPIO_InitStructure.GPIO_Pin = Speed_control_Pin;
- GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;
- GPIO_Init(Speed_control_Port,&GPIO_InitStructure);
- void Tim3_mode_Config(uint16_t period,uint16_t Prescaler,uint16_t Pulse)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- //开启定时器3的时钟
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
- //TIM3重映射
- GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
- // 自动重装载寄存器的值,累计TIM_Period+1个频率后产生一个更新或者中断
- TIM_TimeBaseStructure.TIM_Period = period;
- // 驱动CNT计数器的时钟 = Fck_int/(psc+1)
- TIM_TimeBaseStructure.TIM_Prescaler = Prescaler;
- //时钟分割
- TIM_TimeBaseStructure.TIM_ClockDivision = 0;
- // // 时钟分频因子 ,配置死区时间时需要用到
- // TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- // 计数器计数模式,设置为向上计数
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
- // 重复计数器的值,没用到不用管
- //TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
- // 初始化定时器
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
- // 配置为PWM模式1
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
- // 输出使能
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- // 互补输出使能
- //TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
- // 设置脉冲宽度 CRR的值,0-65535
- TIM_OCInitStructure.TIM_Pulse = Pulse;
- // 输出通道电平极性配置
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- // 互补输出通道电平极性配置
- //TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
- // 输出通道空闲电平极性配置
- //TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
- // 互补输出通道空闲电平极性配置
- //TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
- // TIM_OC1Init(TIM3, &TIM_OCInitStructure);
- // TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_OC1Init(TIM3, &TIM_OCInitStructure);
- TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
- // TIM_OC3Init(TIM2, &TIM_OCInitStructure);
- // TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable);
- // TIM_OC4Init(TIM2, &TIM_OCInitStructure);
- // TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_Cmd(TIM3, ENABLE);
- // 主输出使能,当使用的是通用定时器时,这句不需要
- //TIM_CtrlPWMOutputs(ADVANCE_TIM, ENABLE);
- //电机1
- void Motor1_CW(void)
- GPIO_ResetBits(GPIOA,Motor1_ccw_Pin);
- GPIO_SetBits(GPIOA,Motor1_cw_Pin);
- void Motor1_CCW(void)
- GPIO_ResetBits(GPIOA,Motor1_cw_Pin);
- GPIO_SetBits(GPIOA,Motor1_ccw_Pin);
- //电机2
- void Motor2_CW(void)
- GPIO_ResetBits(GPIOA,Motor2_ccw_Pin);
- GPIO_SetBits(GPIOA,Motor2_cw_Pin);
- void Motor2_CCW(void)
- GPIO_ResetBits(GPIOA,Motor2_cw_Pin);
- GPIO_SetBits(GPIOA,Motor2_ccw_Pin);
- //电机3
- void Motor3_CW(void)
- GPIO_ResetBits(GPIOB,Motor3_ccw_Pin);
- GPIO_SetBits(GPIOB,Motor3_cw_Pin);
- void Motor3_CCW(void)
- GPIO_ResetBits(GPIOB,Motor3_cw_Pin);
- GPIO_SetBits(GPIOB,Motor3_ccw_Pin);
- //电机4
- void Motor4_CW(void)
- GPIO_ResetBits(GPIOB,Motor4_ccw_Pin);
- GPIO_SetBits(GPIOB,Motor4_cw_Pin);
- void Motor4_CCW(void)
- GPIO_ResetBits(GPIOB,Motor4_cw_Pin);
- GPIO_SetBits(GPIOB,Motor4_ccw_Pin);
- void straight(void)
- Motor1_CW();
- Motor2_CW();
- Motor3_CW();
- Motor4_CW();
- void Turn_left(void)
- Motor1_CCW();
- Motor2_CW();
- Motor3_CCW();
- Motor4_CW();
- void Turn_left_move(void)
- Motor1_CCW();
- Motor2_CW();
- Motor3_CW();
- Motor4_CCW();
- void Turn_right(void)
- Motor1_CW();
- Motor2_CCW();
- Motor3_CW();
- Motor4_CCW();
- void Turn_right_move(void)
- Motor1_CW();
- Motor2_CCW();
- Motor3_CCW();
- Motor4_CW();
- void Back(void)
- Motor1_CCW();
- Motor2_CCW();
- Motor3_CCW();
- Motor4_CCW();
- void Stop_motor1(void)
- void Stop_motor2(void)
- void Stop_motor3(void)
- Systick_Delay_ms(300);
- void Stop_motor4(void)
复制代码 中断服务函数
- void Left_spinner_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line1) !=RESET)
- Back();
- Turn_right();
- Systick_Delay_ms(200);
- straight();
- EXTI_ClearITPendingBit(EXTI_Line1);
- void right_spinner_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line0) !=RESET)
- Back();
- Turn_left();
- straight();
- EXTI_ClearITPendingBit(EXTI_Line0);
复制代码 帖主的水平可能并没有那么高,但是我愿与大家共同分享,一起进步,欢迎吐槽打扰
下面包含所有文件:
基于STM32的双路避障小车仿真图源程序.7z
(328.65 KB, 下载次数: 140)
