我想用OLED来画出竖横斜线。
现在画点函数已经做好了,画横竖线就容易了。
sbit SCL=P1^4; //串行时钟
sbit SDA=P1^3; //串行数据
#define high 1
#define low 0
#define Brightness 0xCF
#define X_WIDTH 128
#define Y_WIDTH 64
/*********************OLED驱动程序用的延时程序************************************/
void delay(unsigned int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
//IIC Start
void IIC_Start()
SCL = high;
SDA = high;
SDA = low;
SCL = low;
//IIC Stop
void IIC_Stop()
SCL = low;
SDA = low;
SCL = high;
SDA = high;
// 通过I2C总线写一个字节
void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
for(i=0;i<8;i++)
if(IIC_Byte & 0x80)
SDA=high;
SDA=low;
SCL=high;
SCL=low;
IIC_Byte<<=1;
SDA=1;
SCL=1;
SCL=0;
/*********************OLED写数据************************************/
void OLED_WrDat(unsigned char IIC_Data)
IIC_Start();
Write_IIC_Byte(0x78);
Write_IIC_Byte(0x40); //write data
Write_IIC_Byte(IIC_Data);
IIC_Stop();
/*********************OLED写命令************************************/
void OLED_WrCmd(unsigned char IIC_Command)
IIC_Start();
Write_IIC_Byte(0x78); //Slave address,SA0=0
Write_IIC_Byte(0x00); //write command
Write_IIC_Byte(IIC_Command);
IIC_Stop();
/*********************OLED 设置坐标************************************/
void OLED_Set_Pos(unsigned char x, unsigned char y)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(((x&0xf0)>>4)|0x10);
OLED_WrCmd((x&0x0f)|0x01);
/*********************OLED全屏************************************/
void OLED_Fill(unsigned char bmp_dat)
unsigned char y,x;
for(y=0;y<8;y++)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(0x01);
OLED_WrCmd(0x10);
for(x=0;x<X_WIDTH;x++)
OLED_WrDat(bmp_dat);
/*********************OLED复位************************************/
void OLED_CLS(void)
unsigned char y,x;
for(y=0;y<8;y++)
OLED_WrCmd(0xb0+y);
OLED_WrCmd(0x01);
OLED_WrCmd(0x10);
OLED_WrDat(0);
/*********************OLED初始化************************************/
void OLED_Init(void)
delay(500);//初始化之前的延时很重要!
OLED_WrCmd(0xae);//--turn off oled panel
OLED_WrCmd(0x00);//---set low column address
OLED_WrCmd(0x10);//---set high column address
OLED_WrCmd(0x40);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
OLED_WrCmd(0x81);//--set contrast control register
OLED_WrCmd(Brightness); // Set SEG Output Current Brightness
OLED_WrCmd(0xa1);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
OLED_WrCmd(0xc8);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
OLED_WrCmd(0xa6);//--set normal display
OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
OLED_WrCmd(0x3f);//--1/64 duty
OLED_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
OLED_WrCmd(0x00);//-not offset
OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
OLED_WrCmd(0xd9);//--set pre-charge period
OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
OLED_WrCmd(0xda);//--set com pins hardware configuration
OLED_WrCmd(0x12);
OLED_WrCmd(0xdb);//--set vcomh
OLED_WrCmd(0x40);//Set VCOM Deselect Level
OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
OLED_WrCmd(0x02);//
OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
OLED_WrCmd(0x14);//--set(0x10) disable
OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
OLED_WrCmd(0xaf);//--turn on oled panel
OLED_Fill(0x00); //初始清屏
OLED_Set_Pos(0,0);
/***************功能描述:显示6*8一组标准ASCII字符串 显示的坐标(x,y),y为页范围0~7****************/
void OLED_P6x8Str(unsigned char x, y,unsigned char ch[])
unsigned char c=0,i=0,j=0;
while (ch[j]!='\0')
c =ch[j]-32;
if(x>126){x=0;y++;}
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WrDat(F6x8[c][ i]);
x+=6;
j++;
/*******************功能描述:显示8*16一组标准ASCII字符串 显示的坐标(x,y),y为页范围0~7****************/
void OLED_P8x16Str(unsigned char x, y,unsigned char ch[])
while (ch[j]!='\0')
c =ch[j]-32;
if(x>120){x=0;y++;}
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WrDat(F8X16[c*16+i]);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
OLED_WrDat(F8X16[c*16+i+8]);
x+=8;
j++;
/*****************功能描述:显示16*16点阵 显示的坐标(x,y),y为页范围0~7****************************/
void OLED_P16x16Ch(unsigned char x, y, N)
unsigned char wm=0;
unsigned int adder=32*N;
OLED_Set_Pos(x , y);
for(wm = 0;wm < 16;wm++)
OLED_WrDat(F16x16[adder]);
adder += 1;
OLED_Set_Pos(x,y + 1);
adder += 1;
/***********功能描述:显示显示BMP图片128×64起始点坐标(x,y),x的范围0~127,y为页的范围0~7*****************/
void Draw_BMP(unsigned char x0, y0,x1, y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
if(y1%8==0) y=y1/8;
else y=y1/8+1;
for(y=y0;y<y1;y++)
OLED_Set_Pos(x0,y);
for(x=x0;x<x1;x++)
OLED_WrDat(BMP[j++]);
void OLED_Point(unsigned char x, y)
switch(y)
case(0):OLED_Set_Pos(x,0);OLED_WrDat(0x01);break;
case(1):OLED_Set_Pos(x,0);OLED_WrDat(0x02);break;
case(2):OLED_Set_Pos(x,0);OLED_WrDat(0x04);break;
case(3):OLED_Set_Pos(x,0);OLED_WrDat(0x08);break;
case(4):OLED_Set_Pos(x,0);OLED_WrDat(0x10);break;
case(5):OLED_Set_Pos(x,0);OLED_WrDat(0x20);break;
case(6):OLED_Set_Pos(x,0);OLED_WrDat(0x40);break;
case(7):OLED_Set_Pos(x,0);OLED_WrDat(0x80);break;
case(8):OLED_Set_Pos(x,1);OLED_WrDat(0x01);break;
case(9):OLED_Set_Pos(x,1);OLED_WrDat(0x02);break;
case(10):OLED_Set_Pos(x,1);OLED_WrDat(0x04);break;
case(11):OLED_Set_Pos(x,1);OLED_WrDat(0x08);break;
case(12):OLED_Set_Pos(x,1);OLED_WrDat(0x10);break;
case(13):OLED_Set_Pos(x,1);OLED_WrDat(0x20);break;
case(14):OLED_Set_Pos(x,1);OLED_WrDat(0x40);break;
case(15):OLED_Set_Pos(x,1);OLED_WrDat(0x80);break;
case(16):OLED_Set_Pos(x,2);OLED_WrDat(0x01);break;
case(17):OLED_Set_Pos(x,2);OLED_WrDat(0x02);break;
case(18):OLED_Set_Pos(x,2);OLED_WrDat(0x04);break;
case(19):OLED_Set_Pos(x,2);OLED_WrDat(0x08);break;
case(20):OLED_Set_Pos(x,2);OLED_WrDat(0x10);break;
case(21):OLED_Set_Pos(x,2);OLED_WrDat(0x20);break;
case(22):OLED_Set_Pos(x,2);OLED_WrDat(0x40);break;
case(23):OLED_Set_Pos(x,2);OLED_WrDat(0x80);break;
case(24):OLED_Set_Pos(x,3);OLED_WrDat(0x01);break;
case(25):OLED_Set_Pos(x,3);OLED_WrDat(0x02);break;
case(26):OLED_Set_Pos(x,3);OLED_WrDat(0x04);break;
case(27):OLED_Set_Pos(x,3);OLED_WrDat(0x08);break;
case(28):OLED_Set_Pos(x,3);OLED_WrDat(0x10);break;
case(29):OLED_Set_Pos(x,3);OLED_WrDat(0x20);break;
case(30):OLED_Set_Pos(x,3);OLED_WrDat(0x40);break;
case(31):OLED_Set_Pos(x,3);OLED_WrDat(0x80);break;
case(32):OLED_Set_Pos(x,4);OLED_WrDat(0x01);break;
case(33):OLED_Set_Pos(x,4);OLED_WrDat(0x02);break;
case(34):OLED_Set_Pos(x,4);OLED_WrDat(0x04);break;
case(35):OLED_Set_Pos(x,4);OLED_WrDat(0x08);break;
case(36):OLED_Set_Pos(x,4);OLED_WrDat(0x10);break;
case(37):OLED_Set_Pos(x,4);OLED_WrDat(0x20);break;
case(38):OLED_Set_Pos(x,4);OLED_WrDat(0x40);break;
case(39):OLED_Set_Pos(x,4);OLED_WrDat(0x80);break;
case(40):OLED_Set_Pos(x,5);OLED_WrDat(0x01);break;
case(41):OLED_Set_Pos(x,5);OLED_WrDat(0x02);break;
case(42):OLED_Set_Pos(x,5);OLED_WrDat(0x04);break;
case(43):OLED_Set_Pos(x,5);OLED_WrDat(0x08);break;
case(44):OLED_Set_Pos(x,5);OLED_WrDat(0x10);break;
case(45):OLED_Set_Pos(x,5);OLED_WrDat(0x20);break;
case(46):OLED_Set_Pos(x,5);OLED_WrDat(0x40);break;
case(47):OLED_Set_Pos(x,5);OLED_WrDat(0x80);break;
case(48):OLED_Set_Pos(x,6);OLED_WrDat(0x01);break;
case(49):OLED_Set_Pos(x,6);OLED_WrDat(0x02);break;
case(50):OLED_Set_Pos(x,6);OLED_WrDat(0x04);break;
case(51):OLED_Set_Pos(x,6);OLED_WrDat(0x08);break;
case(52):OLED_Set_Pos(x,6);OLED_WrDat(0x10);break;
case(53):OLED_Set_Pos(x,6);OLED_WrDat(0x20);break;
case(54):OLED_Set_Pos(x,6);OLED_WrDat(0x40);break;
case(55):OLED_Set_Pos(x,6);OLED_WrDat(0x80);break;
case(56):OLED_Set_Pos(x,7);OLED_WrDat(0x01);break;
case(57):OLED_Set_Pos(x,7);OLED_WrDat(0x02);break;
case(58):OLED_Set_Pos(x,7);OLED_WrDat(0x04);break;
case(59):OLED_Set_Pos(x,7);OLED_WrDat(0x08);break;
case(60):OLED_Set_Pos(x,7);OLED_WrDat(0x10);break;
case(61):OLED_Set_Pos(x,7);OLED_WrDat(0x20);break;
case(62):OLED_Set_Pos(x,7);OLED_WrDat(0x40);break;
case(63):OLED_Set_Pos(x,7);OLED_WrDat(0x80);break;
void OLED_XLine(unsigned char x0, y0,x1)
unsigned char z;
if(x0<=x1)
OLED_Point(x0, y0);
for(z=x0;z<x1;z++)
OLED_Point(z, y0);
if(x0>=x1)
OLED_Point(x0, y0);
for(z=x0;z<=x1;z--) //z=16 z=0 z--
OLED_Point(z, y0);
但不知道为什么,画点函数有些地方就不能一起显示(表达能力有限,可以自己试下)!
例如:
OLED_Point(0, 0);
OLED_Point(1, 1);
大家可以在自己的屏幕上试试看。
还有,画竖线函数我编好后下载到屏幕上却花屏。
源码:
void OLED_YLine(unsigned char y0, x0,y1){ unsigned char z; if(y0<=y1) { OLED_Point(x0, y0); for(z=y0;z<y1;z++) { OLED_Point(x0, z); } } if(y0>=y1) { OLED_Point(x0, y0); for(z=y0;z<=y1;z--) //z=16 z=0 z-- { OLED_Point(x0, z); } }}复制代码
现在求助各位大神,给我解释以下这怎么回事,要怎么解决?
