查看: 1486|回复: 5
4*4矩阵扫描 STM32f103RCT6的程序是对的 改成ZET6就不对了
回帖奖励 5 黑币 回复本帖可获得 5 黑币奖励! 每人限 1 次
ID:849635 发表于 2021-9-9 22:08 | 显示全部楼层 |阅读模式
RCT6的程序是对的,改成原子ZET6核心板就不对了
#include "key4_4.h"
#include "delay.h"
#include "sys.h"
//8个引脚 4个为行 4个为列
//行输出端口定义
#define X1_GPIO_PORT GPIOA
#define X2_GPIO_PORT GPIOA
#define X3_GPIO_PORT GPIOA
#define X4_GPIO_PORT GPIOB
//列输入端口定义
#define Y1_GPIO_PORT GPIOB
#define Y2_GPIO_PORT GPIOB
#define Y3_GPIO_PORT GPIOB
#define Y4_GPIO_PORT GPIOB
//行输出引脚定义
#define X1_GPIO_PIN GPIO_Pin_11
#define X2_GPIO_PIN GPIO_Pin_12
#define X3_GPIO_PIN GPIO_Pin_15
#define X4_GPIO_PIN GPIO_Pin_5
//列输入引脚定义
#define Y1_GPIO_PIN GPIO_Pin_6
#define Y2_GPIO_PIN GPIO_Pin_7
#define Y3_GPIO_PIN GPIO_Pin_8
#define Y4_GPIO_PIN GPIO_Pin_9
//行输出时钟定义
#define X1_RCC RCC_APB2Periph_GPIOA
#define X2_RCC RCC_APB2Periph_GPIOA
#define X3_RCC RCC_APB2Periph_GPIOA
#define X4_RCC RCC_APB2Periph_GPIOB
//列输入时钟定义
#define Y1_RCC RCC_APB2Periph_GPIOB
#define Y2_RCC RCC_APB2Periph_GPIOB
#define Y3_RCC RCC_APB2Periph_GPIOB
#define Y4_RCC RCC_APB2Periph_GPIOB
//移植代码只需要修改上面的端口和引脚和时钟即可,下面的代码不用修改。
//矩阵键盘所用的8个引脚可连续可不连续,看实际需要和个人爱好自己定义。
unsigned char Y1,Y2,Y3,Y4;
void Key_Init(void)
   RCC_APB2PeriphClockCmd(X1_RCC|X2_RCC|X3_RCC|X4_RCC|Y1_RCC|Y2_RCC|Y3_RCC|Y4_RCC|RCC_APB2Periph_AFIO, ENABLE);
   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
//    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
////开启AFIO时钟
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
////改变指定管脚的映射 GPIO_Remap_SWJ_Disable SWJ 完全禁用(JTAG+SW-DP)
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
////改变指定管脚的映射 GPIO_Remap_SWJ_JTAGDisable ,JTAG-DP 禁用 + SW-DP 使能
/*****************************4行输出*********************************************/
   GPIO_InitStructure.GPIO_Pin =  X1_GPIO_PIN ;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
   GPIO_Init(X1_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  X2_GPIO_PIN ;
   GPIO_Init(X2_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  X3_GPIO_PIN ;
   GPIO_Init(X3_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = X4_GPIO_PIN ;
   GPIO_Init(X4_GPIO_PORT, &GPIO_InitStructure);
/**************************************4列输入*************************************/
   GPIO_InitStructure.GPIO_Pin =  Y1_GPIO_PIN ;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
   GPIO_Init(Y1_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  Y2_GPIO_PIN ;
   GPIO_Init(Y2_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  Y3_GPIO_PIN ;
   GPIO_Init(Y3_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = Y4_GPIO_PIN;
   GPIO_Init(Y4_GPIO_PORT, &GPIO_InitStructure);
int Key_Scan(void)
   uchar KeyVal;
   GPIO_SetBits(X1_GPIO_PORT,X1_GPIO_PIN);  //先让X1输出高
   GPIO_SetBits(X2_GPIO_PORT,X2_GPIO_PIN);  //先让X2输出高
   GPIO_SetBits(X3_GPIO_PORT,X3_GPIO_PIN);  //先让X3输出高
   GPIO_SetBits(X4_GPIO_PORT,X4_GPIO_PIN);  //先让X4输出高
    if((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN)|GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN)|GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN)|GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))==0x0000)
        return -1; //如果X1到X4全为零则没有按键按下
        delay_ms(5);    //延时5ms去抖动
        return -1;
     GPIO_ResetBits(X1_GPIO_PORT,X1_GPIO_PIN);
     GPIO_ResetBits(X2_GPIO_PORT,X2_GPIO_PIN);
     GPIO_ResetBits(X3_GPIO_PORT,X3_GPIO_PIN);
    Y1=GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN);Y2=GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN);
    Y3=GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN);Y4=GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN);
     if(Y1==1&&Y2==0&&Y3==0&&Y4==0)
            KeyVal='*';
     if(Y1==0&&Y2==1&&Y3==0&&Y4==0)
            KeyVal=0;
     if(Y1==0&&Y2==0&&Y3==0&&Y4==1)
            KeyVal='D';
     if(Y1==0&&Y2==0&&Y3==1&&Y4==0)
            KeyVal='#';
     while(((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN))|(GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN))|(GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN))|(GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))) > 0);
    //等待按键释放
     GPIO_ResetBits(X4_GPIO_PORT,X4_GPIO_PIN);
            KeyVal=1;
            KeyVal=2;
            KeyVal=3;
            KeyVal='A';
            KeyVal=4;
            KeyVal=5;
            KeyVal=6;
            KeyVal='B';
            KeyVal=7;
            KeyVal=8;
            KeyVal=9;
            KeyVal='C';
        return KeyVal;
        按键表盘为:        1  2  3  A
                            4  5  6  B
                            7  8  9  C
                            *  0  #  D
void Key_Test(void)
    int num;
      num = Key_Scan();
      switch(num)
                case 0: printf("0\n"); break;
                case 1: printf("1\n"); break;
                case 2: printf("2\n"); break;
                case 3: printf("3\n"); break;
                case 4: printf("4\n"); break;
                case 5: printf("5\n"); break;
                case 6: printf("6\n"); break;
                case 7: printf("7\n"); break;
                case 8: printf("8\n"); break;
                case 9: printf("9\n"); break;
                case 'A': printf("A\n"); break;
                case 'B': printf("B\n"); break;
                case 'C': printf("C\n"); break;
                case 'D': printf("D\n"); break;
                case '#': printf("#\n"); break;
                case '*': printf("*\n"); break;
51.7z
222.48 KB, 下载次数: 2
ID:965024 发表于 2021-9-10 09:22 | 显示全部楼层
是不是库文件有问题
ID:514901 发表于 2021-9-10 09:59 | 显示全部楼层
一般没问题的,你说的不对是程序不能用还是键盘和数字对不上,后者的话建议检测接线顺序
ID:849635 发表于 2021-9-10 11:43 | 显示全部楼层
接线没有问题的,但是16个按键只能打印一两个,还不对
ID:849635 发表于 2021-9-10 11:50 | 显示全部楼层
hal_w 发表于 2021-9-10 09:22
是不是库文件有问题
库文件?HD,s吗?
ID:96682 发表于 2021-9-10 12:09 来自手机 | 显示全部楼层
问题是芯片型号后缀不一样能直接使用么?
