51驱动16路舵机程序。
单片机源程序如下:- #include"reg51.h"
- #include <intrins.h>
- #include <stdio.h>
- #include <math.h>
- typedef unsigned char uchar;
- typedef unsigned int uint;
- sbit scl=P2^1;
- sbit sda=P2^0;
- #define PCA9685_adrr 0x80
- #define PCA9685_SUBADR1 0x2
- #define PCA9685_SUBADR2 0x3
- #define PCA9685_SUBADR3 0x4
- #define PCA9685_MODE1 0x0
- #define PCA9685_PRESCALE 0xFE
- #define LED0_ON_L 0x6
- #define LED0_ON_H 0x7
- #define LED0_OFF_L 0x8
- #define LED0_OFF_H 0x9
- #define ALLLED_ON_L 0xFA
- #define ALLLED_ON_H 0xFB
- #define ALLLED_OFF_L 0xFC
- #define ALLLED_OFF_H 0xFD
- #define SERVOMIN 90 // this is the 'minimum' pulse length count (out of 4096)
- #define SERVOMAX 700 // this is the 'maximum' pulse length count (out of 4096)
- #define SERVO000 130 //
- #define SERVO180 520 //
- void delayms(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=148;y>0;y--);
- void delayus()
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- void init()
- sda=1;
- delayus();
- scl=1;
- delayus();
- void start()
- sda=1;
- delayus();
- scl=1;
- delayus();
- sda=0;
- delayus();
- scl=0;
- delayus();
- void stop()
- sda=0;
- delayus();
- scl=1;
- delayus();
- sda=1;
- delayus();
- void ACK()
- uchar i;
- scl=1;
- delayus();
- while((sda==1)&&(i<255))
- i++;
- scl=0;
- delayus();
- void write_byte(uchar byte)
- uchar i,temp;
- temp=byte;
- for(i=0;i<8;i++)
- temp=temp<<1;
- scl=0;
- delayus();
- sda=CY;
- delayus();
- scl=1;
- delayus();
- scl=0;
- delayus();
- sda=1;
- delayus();
- uchar read_byte()
- uchar i,j,k;
- scl=0;
- delayus();
- sda=1;
- delayus();
- for(i=0;i<8;i++)
- delayus();
- scl=1;
- delayus();
- if(sda==1)
- j=1;
- else j=0;
- k=(k<< 1)|j;
- scl=0;
- delayus();
- return k;
- void PCA9685_write(uchar address,uchar date)
- start();
- write_byte(PCA9685_adrr);
- ACK();
- write_byte(address);
- ACK();
- write_byte(date);
- ACK();
- stop();
- uchar PCA9685_read(uchar address)
- uchar date;
- start();
- ACK();
- ACK();
- start();
- write_byte(PCA9685_adrr|0x01);
- ACK();
- date=read_byte();
- stop();
- return date;
- void reset(void)
- PCA9685_write(PCA9685_MODE1,0x0);
- void begin(void)
- reset();
- void setPWMFreq(float freq)
- uint prescale,oldmode,newmode;
- float prescaleval;
- freq *= 0.92; // Correct for overshoot in the frequency setting
- prescaleval = 25000000;
- prescaleval /= 4096;
- prescaleval /= freq;
- prescaleval -= 1;
- prescale = floor(prescaleval + 0.5);
- oldmode = PCA9685_read(PCA9685_MODE1);
- newmode = (oldmode&0x7F) | 0x10; // sleep
- PCA9685_write(PCA9685_MODE1, newmode); // go to sleep
- PCA9685_write(PCA9685_PRESCALE, prescale); // set the prescaler
- PCA9685_write(PCA9685_MODE1, oldmode);
- delayms(2);
- PCA9685_write(PCA9685_MODE1, oldmode | 0xa1);
- void setPWM(uint num, uint on, uint off)
- PCA9685_write(LED0_ON_L+4*num,on);
- PCA9685_write(LED0_ON_H+4*num,on>>8);
- PCA9685_write(LED0_OFF_L+4*num,off);
- PCA9685_write(LED0_OFF_H+4*num,off>>8);
- void main()
- begin();
- setPWMFreq(50);
- setPWM(0, 0, 130);//?0?????????
- setPWM(1, 0, 130);//?1?????0??
- setPWM(2, 0, 130);
- setPWM(3, 0,130);
- delayms(2000);
- setPWM(0, 0, 210);
- setPWM(1, 0, 210);
- setPWM(2, 0, 210);
- setPWM(3, 0, 210);
- delayms(2000);
- while(1)
复制代码 以上代码的Keil工程包下载:
51舵机驱动.zip
(52.82 KB, 下载次数: 60)
