一、XL53L0简介激光测距,有效距离2米,多种测距模式(单次,连续,时间间隔),多种工作模式(默认,快速,高精度,长距离)。
二、XL53L0硬件介绍
如下图:
除去供电引脚剩余的引脚作用分别如下
1.SDA,SCL两脚为I2C通信引脚,两个引脚上拉。
2.GPIO为中断引脚,数据测完向外部发射一脉冲,不用时上拉。
3.XSHUT类似复位引脚,低电平有效,不用时上拉。
STM32单片机源程序如下:
- #include "main.h"
- int main(void)
- Led_Init(); //led引脚初始化
- Adc_Init();
- SystemInit(); //初始化
- Systick_Init(); //滴答时钟初始化
- Uart1_Init(9600); //串口初始化
- USB_Port_Set(0); //断开usb
- Delay_Ms(20); //延时
- USB_Port_Set(1); //连接USB
- Set_USBClock(); //使能USB时钟
- USB_Interrupts_Config(); //USB中断配置
- USB_Init(); //USB初始化
- Host_Value_Init(); //主机参数初始化
- vl53l0x_Init(); //VL53L0初始化
- vl53l0x_Calibration_Init(); //VL53L0设备参数设置
- while(1)
- Vl53l0x_Get_Distance(3); //获取高度数据
- Get_Adc_Average(5); //获取角度值
- Dispose_Usb_Data(); //处理USB的数据
复制代码- #include "vl53l0.h"
- VL53L0X_Dev_t vl53l0x_dev0;
- VL53L0X_Dev_t vl53l0x_dev1;
- VL53L0X_Dev_t vl53l0x_dev2;
- VL53L0X_Dev_t vl53l0x_dev3;
- VL53L0X_DeviceInfo_t vl53l0x_dev_info;
- VL53L0X_RangingMeasurementData_t vl53l0x_data;
- VL53L0X_Error vl53l0x_status;
- void print_pal_error(VL53L0X_Error Status)
- char buf[VL53L0X_MAX_STRING_LENGTH];
- VL53L0X_GetPalErrorString(Status, buf); //得到错误码与字符串
- printf("API Status: %i : %s\n", Status, buf);
- void print_range_status(VL53L0X_RangingMeasurementData_t* pdata)
- uint8_t RangeStatus;
- // New Range Status: data is valid when pdata->RangeStatus = 0
- RangeStatus = pdata->RangeStatus;
- VL53L0X_GetRangeStatusString(RangeStatus, buf);
- printf("Range Status: %i : %s\n", RangeStatus, buf);
- uint16_t vl53l0x_start_single_test(VL53L0X_Dev_t *pdev,
- VL53L0X_RangingMeasurementData_t *pdata)
- int i=0,sum=0;
- VL53L0X_Error status = VL53L0X_ERROR_NONE;
- if(vl53l0x_status != VL53L0X_ERROR_NONE)
- return vl53l0x_status;
- status = VL53L0X_PerformSingleRangingMeasurement(pdev, pdata); //VL53L0X执行单一测量范围
- if(status != VL53L0X_ERROR_NONE){
- printf("error:Call of VL53L0X_PerformSingleRangingMeasurement\n");
- return status;
- for(i=0;i<5;i++)
- sum+=pdata->RangeMilliMeter;
- pdata->RangeMilliMeter=sum/5;
- return pdata->RangeMilliMeter;
- 函数功能:配置VL53L0X设备I2C地址
- 入口参数:dev:设备I2C参数结构体
- newaddr:设备新I2C地址
- 返 回 值:错误状态
- VL53L0X_Error vl53l0x_Addr_set(VL53L0X_Dev_t *dev,uint8_t newaddr)
- uint16_t Id;
- uint8_t FinalAddress;
- VL53L0X_Error Status = VL53L0X_ERROR_NONE;
- u8 sta=0x00;
- FinalAddress = newaddr;
- if(FinalAddress==dev->I2cDevAddr)//新设备I2C地址与旧地址一致,直接退出
- return VL53L0X_ERROR_NONE;
- //在进行第一个寄存器访问之前设置I2C标准模式(400Khz)
- Status = VL53L0X_WrByte(dev,0x88,0x00);
- if(Status!=VL53L0X_ERROR_NONE)
- sta=0x01;//设置I2C标准模式出错
- goto set_error;
- //尝试使用默认的0x52地址读取一个寄存器
- Status = VL53L0X_RdWord(dev, VL53L0X_REG_IDENTIFICATION_MODEL_ID, &Id);
- sta=0x02;//读取寄存器出错
- goto set_error;
- if(Id == 0xEEAA)
- //设置设备新的I2C地址
- Status = VL53L0X_SetDeviceAddress(dev,FinalAddress);
- sta=0x03;//设置I2C地址出错
- goto set_error;
- //修改参数结构体的I2C地址
- dev->I2cDevAddr = FinalAddress;
- //检查新的I2C地址读写是否正常
- sta=0x04;//新I2C地址读写出错
- goto set_error;
- set_error:
- print_pal_error(Status);//打印错误信息
- if(sta!=0)
- printf("sta:0x%x\r\n",sta);
- return Status;
- 函数功能:VL53L0初始化
- 入口参数:VL53L0X_Dev_t *pMyDevice ,u8 vl53l0_x_id
- 设备结构体 设备ID
- 返 回 值:错误状态
- VL53L0X_Error vl53l0x_InitX(VL53L0X_Dev_t *pMyDevice ,u8 vl53l0_x_id)
- VL53L0X_Error Status = VL53L0X_ERROR_NONE; //初始值赋值为0
- pMyDevice->I2cDevAddr = 0x52; //iic地址 0x52是默认地址,要初始化必须先写0x52,才能初始化,之后再通过软件修改
- pMyDevice->comms_type = 1; //选择IIC还是SPI iic=1;SPI=0
- pMyDevice->comms_speed_khz = 400; //iic速率
- //正点原子的VL53L0用户手册上写明了再次使能时地址会恢复为0x52,所以只能使能一次,设置好地址即可,这里是核心
- switch(vl53l0_x_id)
- case 0:
- I2C_X0_HIGH();
- Delay_Ms(1);
- vl53l0x_Addr_set(pMyDevice,0x54);//设置第一个VL53L0X传感器I2C地址
- break;
- case 1:
- I2C_X1_HIGH();
- Delay_Ms(1);
- vl53l0x_Addr_set(pMyDevice,0x56);//设置第二个VL53L0X传感器I2C地址
- break;
- case 2:
- I2C_X2_HIGH();
- Delay_Ms(1);
- vl53l0x_Addr_set(pMyDevice,0x58);
- break;
- case 3:
- I2C_X3_HIGH();
- Delay_Ms(1);
- vl53l0x_Addr_set(pMyDevice,0x5a);
- break;
- Status = VL53L0X_DataInit(pMyDevice); //设备的初始化,赋默认值
- if(Status != VL53L0X_ERROR_NONE){ //判断如果状态不为0 打印错误信息
- return Status; //返回错误值 可通过此值DEBUG查找错误位置
- Status = VL53L0X_GetDeviceInfo(pMyDevice, &vl53l0x_dev_info); //读取给定设备的设备信息
- return Status;
- printf("VL53L0X_GetDeviceInfo:\n");
- printf("Device Name : %s\n", vl53l0x_dev_info.Name); //设备名
- printf("Device Type : %s\n", vl53l0x_dev_info.Type); //产品类型VL53L0X = 1, VL53L1 = 2
- printf("Device ID : %s\n", vl53l0x_dev_info.ProductId); // 设备ID
- printf("ProductRevisionMajor : %d\n", vl53l0x_dev_info.ProductRevisionMajor);
- printf("ProductRevisionMinor : %d\n", vl53l0x_dev_info.ProductRevisionMinor);
- if ((vl53l0x_dev_info.ProductRevisionMajor != 1) && (vl53l0x_dev_info.ProductRevisionMinor != 1)){
- printf("Error expected cut 1.1 but found cut %d.%d\n",
- vl53l0x_dev_info.ProductRevisionMajor, vl53l0x_dev_info.ProductRevisionMinor);
- Status = VL53L0X_ERROR_NOT_SUPPORTED;
- return Status;
- // Device Initialization
- Status = VL53L0X_StaticInit(pMyDevice); //基本设备初始化
- if(Status != VL53L0X_ERROR_NONE){ //判断是否初始化成功 失败打印错误信息
- printf ("Call of VL53L0X_StaticInit\n");
- return Status;
- return Status;
- 函数功能:sPANS参考校准
- 入口参数:VL53L0X_Dev_t *pMyDevice ,Device_Message *pDev
- 设备结构体 设备信息
- 返 回 值:错误状态
- VL53L0X_Error PerformRefSpad_CalibrationX(VL53L0X_Dev_t *pMyDevice,Device_Message *pDev)
- uint32_t refSpadCount;
- uint8_t isApertureSpads;
- VL53L0X_Error Status = VL53L0X_ERROR_NONE; //执行sPANS参考校准
- Status = VL53L0X_PerformRefSpadManagement(pMyDevice,&refSpadCount, &isApertureSpads);
- printf ("Call of VL53L0X_PerformRefSpadManagement\n");
- printf ("refSpadCount = %d, isApertureSpads = %d\n", refSpadCount, isApertureSpads);
- return Status;
- pDev->refSpadCount = refSpadCount;
- pDev->isApertureSpads = isApertureSpads;
- return Status;
- 函数功能:Ref校准
- 设备结构体 设备信息
- 返 回 值:错误状态
- VL53L0X_Error PerformRef_CalibrationX(VL53L0X_Dev_t *pMyDevice,Device_Message *pDev)
- uint8_t VhvSettings;
- uint8_t PhaseCal;
- // Device Initialization //执行温度参考校准
- Status = VL53L0X_PerformRefCalibration(pMyDevice, &VhvSettings,&PhaseCal);
- printf ("Call of VL53L0X_PerformRefCalibration\n");
- return Status;
- pDev->VhvSettings = VhvSettings; //更新结构体
- pDev->PhaseCal = PhaseCal;
- return Status;
- 函数功能:Offset校准
- 设备结构体 设备信息
- 返 回 值:错误状态
- VL53L0X_Error Offset_CalibrationX(VL53L0X_Dev_t *pMyDevice,Device_Message *pDev)
- int32_t OffsetMicroMeter;
- Status=VL53L0X_PerformOffsetCalibration(pMyDevice,100<<16,&OffsetMicroMeter); //偏移校准,把白色物体放在100mm处进行,输出偏移校准值
- return Status;
- pDev->OffsetMicroMeter = OffsetMicroMeter;
- return Status;
- 函数功能:XTalk校准
- 设备结构体 设备ID
- 返 回 值:错误状态
- VL53L0X_Error XTalk_CalibrationX(VL53L0X_Dev_t *pMyDevice,Device_Message *pDev)
- FixPoint1616_t XTalkCompensation;
- Status=VL53L0X_PerformXTalkCalibration(pMyDevice,250<<16,&XTalkCompensation); //偏移校准,把白色物体放在100mm处进行,输出偏移校准值
- return Status;
- pDev->XTalkCompensation = XTalkCompensation;
- return Status;
- //校准参数设置
- VL53L0X_Error vl53l0x_Set_InitX(VL53L0X_Dev_t *pMyDevice,Device_Message *pDev)
- //SPAD校准参数设置
- Status = VL53L0X_SetReferenceSpads(pMyDevice,pDev->refSpadCount,pDev->isApertureSpads);
- if(Status!=VL53L0X_ERROR_NONE) { return Status; }
- //温度校准参数设置
- Status = VL53L0X_SetRefCalibration(pMyDevice,pDev->VhvSettings,pDev->PhaseCal);
- //偏移校准参数设置
- Status = VL53L0X_SetOffsetCalibrationDataMicroMeter(pMyDevice,pDev->OffsetMicroMeter);
- //盖玻片校准参数设置
- Status = VL53L0X_SetXTalkCompensationRateMegaCps(pMyDevice,pDev->XTalkCompensation);
- //使能串扰校准
- Status = VL53L0X_SetXTalkCompensationEnable(pMyDevice,ENABLE);
- return Status;
- VL53L0X_Error vl53l0x_Set_ModeX(VL53L0X_Dev_t *pMyDevice)
- // no need to do this when we use VL53L0X_PerformSingleRangingMeasurement
- Status = VL53L0X_SetDeviceMode(pMyDevice, VL53L0X_DEVICEMODE_SINGLE_RANGING); // Setup in single ranging mode 设置单一测量模式
- printf ("Call of VL53L0X_SetDeviceMode\n");
- return Status;
- // Enable/Disable Sigma and Signal check
- if(Status == VL53L0X_ERROR_NONE){Status = VL53L0X_SetLimitCheckEnable(pMyDevice, //启用/禁用特定限制检查
- VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE, 1);
- VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE, 1);
- if(Status == VL53L0X_ERROR_NONE){ Status = VL53L0X_SetLimitCheckValue(pMyDevice,
- (FixPoint1616_t)(0.25*65536));
- (FixPoint1616_t)(18*65536));
- if(Status == VL53L0X_ERROR_NONE){ Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, //设置微秒时间
- 200000);
- printf ("Sigma and Signal check error\n");
- return Status;
- return Status; //返回0
- 函数功能:设备初始化·
- 入口参数:无
- 返 回 值:错误参数
- VL53L0X_Error vl53l0x_Init(void)
- //初始化一定按照这个顺序执行,否则不成功
- VL53L0X_i2c_init();
- vl53l0x_InitX(&vl53l0x_dev0,0);
- vl53l0x_InitX(&vl53l0x_dev1,1);
- vl53l0x_InitX(&vl53l0x_dev2,2);
- vl53l0x_InitX(&vl53l0x_dev3,3);
- 函数功能:参数赋值程序
- 入口参数:无
- 返 回 值:错误参数
- VL53L0X_Error vl53l0x_Set_Init(void)
- vl53l0x_Set_InitX(&vl53l0x_dev0,&Device0_Calibration_Message);
- vl53l0x_Set_InitX(&vl53l0x_dev1,&Device1_Calibration_Message);
- vl53l0x_Set_InitX(&vl53l0x_dev2,&Device2_Calibration_Message);
- vl53l0x_Set_InitX(&vl53l0x_dev3,&Device3_Calibration_Message);
- return Status;
- return Status;
- 函数功能:设置模式
- 入口参数:无
- 返 回 值:错误参数
- VL53L0X_Error vl53l0x_Set_Mode(void)
- Status = vl53l0x_Set_ModeX(&vl53l0x_dev0);
- Status = vl53l0x_Set_ModeX(&vl53l0x_dev1);
- Status = vl53l0x_Set_ModeX(&vl53l0x_dev2);
- Status = vl53l0x_Set_ModeX(&vl53l0x_dev3);
- return Status;
- return Status;
- 函数功能:校准程序
- 入口参数:无
- 返 回 值:错误参数
- VL53L0X_Error vl53l0x_Calibration_Init(void)
- if(Host_Configuration.calibration_marker == 0xaa)
- Status = vl53l0x_Set_Init();
- USB_USART_SendData(Host_Configuration.calibration_marker); //设备数据设定
- else
- { usb_printf("等待偏移校准!");
- while(1){Dispose_Usb_Data();
- if(Host_Configuration.calibration_marker == 0x0a){break;}}; //等待偏移校准
- Status = PerformRefSpad_Calibration();
- Status = PerformRef_Calibration();
- Status = Offset_Calibration();
- usb_printf("等待载玻片校准!");
- if(Host_Configuration.calibration_marker == 0xaa){break;}}; //等待载玻片校准
- Status = XTalk_Calibration();
- usb_printf("校准成功!");
- Save_Device_Data_To_Flash(&Device0_Calibration_Message,0); //保存校准后参数
- Save_Device_Data_To_Flash(&Device1_Calibration_Message,1);
- Save_Device_Data_To_Flash(&Device2_Calibration_Message,2);
- Save_Device_Data_To_Flash(&Device3_Calibration_Message,3);
- vl53l0x_Set_Mode();
- usb_printf("设备启动!");
- return Status;
- //SPAD校准程序
- VL53L0X_Error PerformRefSpad_Calibration(void)
- //SPAD校准
- PerformRefSpad_CalibrationX(&vl53l0x_dev0,&Device0_Calibration_Message);
- PerformRefSpad_CalibrationX(&vl53l0x_dev1,&Device1_Calibration_Message);
- PerformRefSpad_CalibrationX(&vl53l0x_dev2,&Device2_Calibration_Message);
- PerformRefSpad_CalibrationX(&vl53l0x_dev3,&Device3_Calibration_Message);
- return Status;
- return Status;
- //温度校准程序
- VL53L0X_Error PerformRef_Calibration(void)
- //温度校准
- PerformRef_CalibrationX(&vl53l0x_dev0,&Device0_Calibration_Message);
- PerformRef_CalibrationX(&vl53l0x_dev1,&Device1_Calibration_Message);
- PerformRef_CalibrationX(&vl53l0x_dev2,&Device2_Calibration_Message);
- PerformRef_CalibrationX(&vl53l0x_dev3,&Device3_Calibration_Message);
- return Status;
- return Status;
- //偏移校准程序
- VL53L0X_Error Offset_Calibration(void)
- //偏移校准
- Offset_CalibrationX(&vl53l0x_dev0,&Device0_Calibration_Message);
- Offset_CalibrationX(&vl53l0x_dev1,&Device1_Calibration_Message);
- Offset_CalibrationX(&vl53l0x_dev2,&Device2_Calibration_Message);
- Offset_CalibrationX(&vl53l0x_dev3,&Device3_Calibration_Message);
- return Status;
- return Status;
- //串扰校准程序
- VL53L0X_Error XTalk_Calibration(void)
- //串扰校准
- XTalk_CalibrationX(&vl53l0x_dev0,&Device0_Calibration_Message);
- XTalk_CalibrationX(&vl53l0x_dev1,&Device1_Calibration_Message);
- XTalk_CalibrationX(&vl53l0x_dev2,&Device2_Calibration_Message);
- XTalk_CalibrationX(&vl53l0x_dev3,&Device3_Calibration_Message);
- return Status;
- return Status;
- 函数功能:获取四个传感器测量的高度
- 入口参数:times :滤波次数
- 返 回 值:无
- void Vl53l0x_Get_Distance(u8 times) //times不易过大为好
- static u8 m=0;
- Data_Mover(vl5310_1_value_filter,LEFT,times);
- Data_Mover(vl5310_2_value_filter,LEFT,times);
- Data_Mover(vl5310_3_value_filter,LEFT,times);
- Data_Mover(vl5310_4_value_filter,LEFT,times);
- for(;m<times;m++) //读取距离数据
- vl5310_1_value_filter[m]= vl53l0x_start_single_test(&vl53l0x_dev0, &vl53l0x_data);
- vl5310_2_value_filter[m]= vl53l0x_start_single_test(&vl53l0x_dev1, &vl53l0x_data);
- vl5310_3_value_filter[m]= vl53l0x_start_single_test(&vl53l0x_dev2, &vl53l0x_data);
- vl5310_4_value_filter[m]= vl53l0x_start_single_test(&vl53l0x_dev3, &vl53l0x_data);
- m--; //下次执行此函数时只用读取一次即可
- Send_Information.first_vl53l0_value = Buf_Add(vl5310_1_value_filter,times)/times; //更新传感器的值
- Send_Information.second_vl53l0_value= Buf_Add(vl5310_2_value_filter,times)/times;
- Send_Information.third_vl53l0_value = Buf_Add(vl5310_3_value_filter,times)/times;
- Send_Information.fourth_vl53l0_value= Buf_Add(vl5310_4_value_filter,times)/times;
Keil代码下载:
四传感器测距代码.7z
(283.24 KB, 下载次数: 158)
