查看: 987|回复: 1
VHDL四选一的结构描述
ID:833673 发表于 2023-3-17 15:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VHDL语句的四选一结构描述
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity erxuanyi is
    Port ( A, B, Sel : in std_logic;
           Y : out std_logic);
end erxuanyi;
architecture Behavioral of erxuanyi is
begin
    Y <= A when Sel = '0' else B;
end Behavioral;
library IEEE;
entity sixuanyi is
    Port ( A, B, C, D, Sel : in std_logic_vector(1 downto 0);
           Y : out std_logic);
end sixuanyi;
-- 实现模块
architecture Behavioral of sixuanyi is
    -- 元件例化
    component erxuanyi
               Y : out std_logic);
    end component;
    -- 信号定义
    signal AB, CD : std_logic;
begin
    -- 实例化二选一模块
    U1: erxuanyi port map (A => A(0), B => B(0), Sel => Sel(0), Y => AB);
    U2: erxuanyi port map (A => C(0), B => D(0), Sel => Sel(0), Y => CD);
    -- 连接选择信号
    U3: erxuanyi port map (A => AB, B => CD, Sel => Sel(1), Y => Y);
end Behavioral;
verilog语句的四选一结构描述
module erxuanyi(
    input A, B, Sel,
    output Y
    assign Y = (Sel == 1'b0) ? A : B;
endmodule
module sixuanyi(
    input [1:0] A, B, C, D, Sel,
    output Y
    wire AB, CD;
    erxuanyi U1(
        .A(A[0]), .B(B[0]), .Sel(Sel[0]),
        .Y(AB)
    erxuanyi U2(
        .A(C[0]), .B(D[0]), .Sel(Sel[0]),
        .Y(CD)
    erxuanyi U3(
        .A(AB), .B(CD), .Sel(Sel[1]),
        .Y(Y)
endmodule
ID:1005954 发表于 2023-5-10 15:34 | 只看该作者
为什么有两个实体名啊erxuanyi和sixuanyi
