查看: 375|回复: 5
单片机lcd显示 不明白怎么写程序
要求通过矩阵键盘显示6位学号,但目前只可以单位显示,没法显示6位,希望大佬给一个思路
#include <reg52.h>      //包含52头文件
#define uint unsigned int //宏定义uint代替unsigned int
#define uchar unsigned char //宏定义uchar代替unsigned char
#define out P0
sbit lcdrs=P2^4;
sbit lcdrw=P2^5;
sbit lcden=P2^6;
void check_busy(void);
void write_cmd(char cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void keyscan();
uchar key,num=100,flag;
uint cnt=0;
uchar dat[]="0123456789ABCDEF";
void delay (uint xms)     //毫秒函数定义
    uint i,j;
    for(i=0;i<xms;i++)
       for(j=0;j<120;j++);
void  main()                            //主函数
{        lcd_init();
          write_cmd(0x80+0x40);
          keyscan();
           if(num<16)
             write_data(dat[key]);
/**********************检查忙标志函数************************/
    uchar dt;
        out=0xff;
        do
           lcden=0;
           lcdrs=0;
           lcdrw=1;
           lcden=1;
           dt=out;
        }while(dt&0x80);
        lcden=0;
/**************************1602显示****************************/
void write_cmd(char cmd)  //写指令函数
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=0;
        lcdrw=0;//先将RW拉低
        out=cmd;
        lcden=1;
        lcden=0;
void write_data(uchar dat) //写数据函数
        check_busy();
        lcden=0;//再把EN拉低
        lcdrs=1;
        lcdrw=0;//先将RW拉低
        out=dat;
        lcden=1;
        lcden=0;
void write_str(uchar *str)//写字符串函数
        while(*str!='\0')
                write_data(*str++);
                delay(5);
/***************************初始化******************************/
void lcd_init()//初始化1602
        write_cmd(0x38);//显示模式设置
        write_cmd(0x0c);//显示开关,光标没有闪烁
        write_cmd(0x06);//显示光标移动设置
        write_cmd(0x01);//清除屏幕
        delay(1);
void keyscan()
    uchar temp,num;
    P1=0xff;       //先向P1写1
        P1=0xfe;       //选中按键第一行
        temp=P1;           //把P1给中间变量
        temp=temp&0xf0;//低四位清零
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xee:key=0; break;
                            case 0xde:key=1; break;
                            case 0xbe:key=2; break;
                            case 0x7e:key=3; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfd;//选中按键第二行
        temp=P1;        //把P1给中间变量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xed:key=4; break;
                            case 0xdd:key=5; break;
                            case 0xbd:key=6; break;
                            case 0x7d:key=7; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
        P1=0xfb;//选中按键第三行
        temp=P1;        //把P1给中间变量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xeb:key=8; break;
                            case 0xdb:key=9; break;
                            case 0xbb:key=10; break;
                            case 0x7b:key=11; break;
                        while(temp!=0xf0)
                            temp=P1;
                            temp=temp&0xf0;
        P1=0xf7;//选中按键第四行
        temp=P1;        //把P1给中间变量
        while(temp!=0xf0)
        delay(5);
        temp=P1;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P1;
            switch(temp)
                            case 0xe7:key=12; break;
                            case 0xd7:key=13; break;
                            case 0xb7:key=14; break;
                            case 0x77:key=15; break;
                        while(temp!=0xf0)
                        temp=P1;
                        temp=temp&0xf0;
   while((num<50)&&(temp!=0xf0))
   {delay(10);
     num++;
    num=0;
收藏收藏1 分享淘帖 顶 踩
ID:1102504 发表于 2023-12-4 15:32 来自手机 | 只看该作者
你可以去b站学一下
ID:94031 发表于 2023-12-4 16:01 | 只看该作者
先解决6位数码管能不断显示缓存数组里的内容,再解决缓存能存储矩阵键盘输入的学号。
ID:374110 发表于 2023-12-4 16:57 | 只看该作者
找个1602的程序自己看看逻辑,没有位选和片选处理怎么会多位显示
ID:161164 发表于 2023-12-7 10:31 | 只看该作者
ID:1096616 发表于 2023-12-11 18:05 | 只看该作者
哦,这个是一个可行的想法
