LCD.c文件:
#include "LPC11XX.h"
#include "gpio.h"
#include "main.h"
#include "Delay.h"
#include "LCD.h"
/*-----------设置D0-D7为输出口-------------*/
void Set_GPIO_Output(void)
LPC_GPIO2->DIR |= (0x1<<0); //设置D0-D7为输出
LPC_GPIO2->DIR |= (0x1<<1);
LPC_GPIO2->DIR |= (0x1<<2);
LPC_GPIO2->DIR |= (0x1<<3);
LPC_GPIO2->DIR |= (0x1<<4);
LPC_GPIO2->DIR |= (0x1<<5);
LPC_GPIO2->DIR |= (0x1<<6);
LPC_GPIO2->DIR |= (0x1<<7);
/*-----------设置D0-D7为输入口-------------*/
void Set_GPIO_Input(void)
LPC_GPIO2->DIR &= ~(0x1<<0); //设置D0-D7为输入
LPC_GPIO2->DIR &= ~(0x1<<1);
LPC_GPIO2->DIR &= ~(0x1<<2);
LPC_GPIO2->DIR &= ~(0x1<<3);
LPC_GPIO2->DIR &= ~(0x1<<4);
LPC_GPIO2->DIR &= ~(0x1<<5);
LPC_GPIO2->DIR &= ~(0x1<<6);
LPC_GPIO2->DIR &= ~(0x1<<7);
/*-----------LCD端口初始化-------------*/
void LCD_GPIO_Init(void)
//P2口可以用这种方式设置为GPIO,这种方式较合理正式。
LPC_IOCON->PIO2_0 &= (~0x07); //设置P2.0~P2.10为GPIO
LPC_IOCON->PIO2_1 &= (~0x07);
LPC_IOCON->PIO2_2 &= (~0x07);
LPC_IOCON->PIO2_3 &= (~0x07);
LPC_IOCON->PIO2_4 &= (~0x07);
LPC_IOCON->PIO2_5 &= (~0x07);
LPC_IOCON->PIO2_6 &= (~0x07);
LPC_IOCON->PIO2_7 &= (~0x07);
LPC_IOCON->PIO2_8 &= (~0x07);
LPC_IOCON->PIO2_9 &= (~0x07);
LPC_IOCON->PIO2_10 &=(~0x07);
LPC_GPIO2->DIR |= (0x1<<8); //RS 设为输出
LPC_GPIO2->DIR |= (0x1<<9); //R/W 设为输出
LPC_GPIO2->DIR |= (0x1<<10); //EN 设为输出
LPC_GPIO3->DIR |= (0x1<<3); //BackLighting 液晶屏背光设为输出
GPIOSetValue( 3, 3, 1 ); //BackLighting位写1,开启液晶屏背光,写0关闭液晶屏背光
/*-----------写数据到D0-D7-------------*/
void Write_Data_Port(unsigned char Data)
LPC_GPIO2->DATA &= ~(0xff);
LPC_GPIO2->DATA |=Data;
/*-----------读D0-D7的数据-------------*/
unsigned char Read_Data_Port(void)
//unsigned char In_Data=0;
//In_Data=LPC_GPIO2->DATA;
//return In_Data;
return(LPC_GPIO2->DATA);
* 函 数 名: uchar Chk_LCD_busy(void)
* 函数功能: 读液晶忙通道数据
* 入口参数: 无
* 返 回: 无
unsigned char Chk_LCD_busy(void)
unsigned char gR_data;
unsigned char gwait_time=0xff; //设置忙超时数
Set_GPIO_Input(); //接收口设为输入口
LCD_RS_Low(); //表示状态
LCD_RW_High(); //选择读
LCD_EN_High();
Delay_Us(30);
gR_data=Read_Data_Port();
Delay_Us(10);
while(TESTBIT(gR_data,7)) //表示busy
--gwait_time;
if(!gwait_time)
LCD_EN_Low();
Set_GPIO_Output(); //恢复为输出口
return 0;
LCD_EN_Low();
return 1;
* 函 数 名: void Write_LCD_command(uchar gcmd,uchar gvalue)
* 函数功能: 写指令
* 入口参数: gcmd--指令 gvalue--是否查忙
* 返 回: 无
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue)
if(gvalue) //写命令时大部分情况下是在LCD空闲模式下写
if(Chk_LCD_busy())
LCD_RS_Low(); //选择指令
LCD_RW_Low(); //选择写
LCD_EN_High(); //使能
Write_Data_Port(gcmd); //赋指令
Delay_Us(15);
LCD_EN_Low();
LCD_RW_Low(); //选择写
LCD_EN_High(); //使能
Delay_Us(10);
LCD_EN_Low();
* 函 数 名: void Write_LCD_data(uchar gdata)
* 函数功能: 写数据
* 入口参数: gdata--数据
* 返 回: 无
/*----------- 写数据 -------------*/
void Write_LCD_data(unsigned char gdata)
if(Chk_LCD_busy()) //写数据必须是在LCD空闲模式下才能写
LCD_RS_High(); //选择数据
LCD_RW_Low(); //选择写
LCD_EN_High(); //使能
Write_Data_Port(gdata);
Delay_Us(15);
LCD_EN_Low();
* 函 数 名: void INIT_LCD(void)
* 函数功能: 初始化1602LCD
* 入口参数: 无
* 返 回: 无
/*-----------LCD初始化函数-------------*/
void INIT_LCD(void)
LCD_GPIO_Init();
Delay_Ms(15);
Write_LCD_command(0x38,0); //设置16X2显示,5X7点阵,8位数据传送,不检测忙信号
Delay_Ms(5);
Delay_Ms(5);
Delay_Us(100);
Write_LCD_command(0x38,1); //设置16X2显示,5X7点阵,8位数据传送,检测忙信号
Write_LCD_command(0x08,1); //关闭显示、无光标、检测忙信号
Write_LCD_command(0x01,1); //清屏、光标归位、AC=0、检测忙信号
Delay_Ms(2);
Write_LCD_command(0x06,1); //显示光标右移位置、检测忙信号
Write_LCD_command(0x0C,1); //显示功能开、无光标、检测忙信号
* 函 数 名: void Display_LCD_string(uchar gadd_start,uchar gline,uchar glength,uchar *pdata)
* 函数功能: 显示字符串
* 入口参数: gadd_start-列号,uchar gline-行号,glength-数据长度,pdata-数组元素
* 返 回: 无
/*-----------显示字符串-------------*/
// 列号 行号 数据长度 数组元素
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata)
unsigned char gaddress;
//uchar *pdat;
unsigned char gcount=0;
if(!gline) //第0行
{ gaddress=0x80+gadd_start; } //地址对应
{ gaddress=0xc0+gadd_start; } //第一行
for(;gcount<glength;gcount++)
Write_LCD_command(gaddress,1); //设定数据地址
Write_LCD_data(*pdata); //取设定地址里的数据
gaddress++;
pdata++;
* 函 数 名: void DispChar_XY_LCD(uchar x,uchar y,uchar gdata)
* 函数功能: 指定位置显示字符
* 入口参数: x-起始地址横坐标,y-起始地址纵坐标,gdata-要显示的字符
* 返 回: 无
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata)
if(!y)
{ gaddress=0x80+x; }
{ gaddress=0xc0+x; }
Write_LCD_data(gdata);
* 函 数 名: void DispNum_XY_LCD(uchar x,uchar y,uchar gdata)
* 函数功能: 指定位置显示数字
* 入口参数: x-起始地址横坐标,y-起始地址纵坐标,gdata-要显示的数字
* 返 回: 无
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata)
if(!y)
Write_LCD_data(gdata+0x30);
/*-----------清屏-------------*/
void Clear_Display(void)
Delay_Ms(5);
LCD.h文件:
#ifndef __LCD_H__
#define __LCD_H__
#define TESTBIT(a,b) ((a)&(1<<(b)))
#define LCD_RS_Low() LPC_GPIO2->DATA &=~(1<<8) //给P2.8位写0
#define LCD_RS_High() LPC_GPIO2->DATA |=(1<<8) //给P2.8位写1
#define LCD_RW_Low() LPC_GPIO2->DATA &=~(1<<9) //给P2.9位写0
#define LCD_RW_High() LPC_GPIO2->DATA |=(1<<9) //给P2.9位写1
#define LCD_EN_Low() LPC_GPIO2->DATA &=~(1<<10) //给P2.10位写0
#define LCD_EN_High() LPC_GPIO2->DATA |=(1<<10) //给P2.10位写1
void Set_GPIO_Output(void);
void Set_GPIO_Input(void);
void LCD_GPIO_Init(void);
void Write_Data_Port(unsigned char Data);
unsigned char Read_Data_Port(void);
unsigned char Chk_LCD_busy(void);
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue);
void Write_LCD_data(unsigned char gdata);
void INIT_LCD(void);
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata);
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void Clear_Display(void);
#endif
