- #include<STC12C5A60S2.H>
- typedef unsigned char uint8;
- typedef unsigned int uint16;
- #define channel 0x01 //设置AD通道为 P1.0
- #define ADC_POWER (1<<7)
- #define ADC_SPEEDHH (0x03<<5)
- #define ADC_START (1<<3)
- #define PADCH (1<<5)
- #define ADC_FLAG (1<<4)
- #define P_3 P3 //32列扫描控制
- sbit sw=P1^2;//74HC154组切换控制位
- //放大128倍后的sin整数表(128)
- code char SIN_TAB[128]={0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
- 105,108,112,114,117,119,121,123,124,125,126,126,126,126,126,
- 125,124,123,121,119,117,114,112,108,105,102,98,94,89,85,80,75,
- 70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,-30,-36,-42,
- -48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,-105,-108,-112,
- -114,-117,-119,-121,-123,-124,-125,-126,-126,-126,-126,-126,-125,
- -124,-123,-121,-119,-117,-114,-112,-108,-105,-102,-98,-94,-89,-85,
- -80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,-12,-6};
- //放大128倍后的cos整数表(128)
- code char COS_TAB[128]={127,126,126,125,124,123,121,119,117,114,112,108,105,102,98,94,
- 89,85,80,75,70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,
- -30,-36,-42,-48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,
- -105,-108,-112,-114,-117,-119,-121,-123,-124,-125,-126,-126,-126,
- -126,-126,-125,-124,-123,-121,-119,-117,-114,-112,-108,-105,-102,
- -98,-94,-89,-85,-80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,
- -12,-6,0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
- 105,108,112,114,117,119,121,123,124,125,126,126};
- //采样存储序列表
- code char LIST_TAB[128] = {0,64,32,96,16,80,48,112,8,72,40,104,24,88,56,120,4,68,36,100,20,84,52,116,
- 12,76,44,108,28,92,60,124,2,66,34,98,18,82,50,114,10,74,42,106,26,90,58,
- 122,6,70,38,102,22,86,54,118,14,78,46,110,30,94,62,126,1,65,33,97,17,81,49,
- 113,9,73,41,105,25,89,57,121,5,69,37,101,21,85,53,117,13,77,45,109,29,93,61,
- 125,3,67,35,99,19,83,51,115,11,75,43,107,27,91,59,123,7,71,39,103,23,87,55,
- 119,15,79,47,111,31,95,63,127};
- uint8 LED[32]={0x80,0x00,0xC0,0x00,0xE0,0x00,0xF0,0x00,
- 0xF8,0x00,0xFC,0x00,0xFE,0x00,0xFF,0x00,
- 0xff,0x80,0xff,0xC0,0xff,0xE0,0xff,0xF0,
- 0xff,0xF8,0xff,0xFC,0xff,0xFE,0xff,0xFF,};
- uint8 COUNT=15,COUNT1=0,ADC_Count=0,LINE=15,G=0,T;
- uint8 i,j,k,b,p,anum,led=0;
- int Temp_Real,Temp_Imag,temp; // 中间临时变量
- uint16 TEMP1,max=0;
- int xdata Fft_Real[128];
- int xdata Fft_Image[128]; // fft的虚部
- uint8 xdata LED_TAB2[16]; //记录 漂浮物 是否需要 停顿一下
- uint8 xdata LED_TAB[16]; //记录红色柱状
- uint8 xdata LED_TAB1[16]; //记录 漂浮点
- /////////////shop60610364.taobao.com/////////
- void FFT()//基2fft
- for( i=1; i<=7; i++) /* for(1) */
- b=1;
- b <<=(i-1); //碟式运算,用于计算隔多少行计算例如 第一极 1和2行计算
- for( j=0; j<=b-1; j++) /* for (2) */
- p=1;
- p <<= (7-i);
- p = p*j;
- for( k=j; k<128; k=k+2*b) /* for (3) */
- Temp_Real=Fft_Real[k];
- Temp_Imag=Fft_Image[k];
- temp=Fft_Real[k+b];
- Fft_Real[k]=Fft_Real[k]+((Fft_Real[k+b]*COS_TAB[p])>>7)+((Fft_Image[k+b]*SIN_TAB[p])>>7);
- Fft_Image[k]=Fft_Image[k]-((Fft_Real[k+b]*SIN_TAB[p])>>7)+((Fft_Image[k+b]*COS_TAB[p])>>7);
- Fft_Real[k+b]=Temp_Real-((Fft_Real[k+b]*COS_TAB[p])>>7)-((Fft_Image[k+b]*SIN_TAB[p])>>7);
- Fft_Image[k+b]=Temp_Imag+((temp*SIN_TAB[p])>>7)-((Fft_Image[k+b]*COS_TAB[p])>>7); // 移位.防止溢出. 结果已经是本值的 1/64
- Fft_Real[k] >>= 1;
- Fft_Image[k] >>= 1;
- Fft_Real[k+b] >>= 1;
- Fft_Image[k+b] >>= 1;
- for(j=0;j<16;j++)//16分频
- TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求各频段幅值
- if(TEMP1<1)TEMP1=0;
- LED_TAB[j]=TEMP1;
- if(LED_TAB[j]>max)max=LED_TAB[j];
- if(max>16)//分级量化
- max/=16;
- for(j=0;j<16;j++)LED_TAB[j]/=max;
- void delay2us(void) //2us延时
- unsigned char a,b;
- for(b=1;b>0;b--)
- for(a=3;a>0;a--);
- void Init()
- P1ASF = 0x02; //0000,0010, 将 P1.1 置成模拟口
- AUXR1 &=0xFB; //1111,1011, 令 ADRJ=0
- EADC=1; //AD中断打开
- ADC_CONTR = ADC_POWER | ADC_SPEEDHH | ADC_START | channel;//1110 1001 1打开 A/D (ADC_POWER)转换电源;11速度为90周期一次;
- //0中断标志清零;1启动adc(ADC_START);001AD通道打开(这里为P1.1);
- P2M0=1;
- TMOD=0X12;
- TH0=0xb0;
- TL0=0xb0;
- TH1=0xfe;
- TL1=0Xd4;
- ET0=1; //定时器0 打开
- TR0=0; //关闭定时器
- ET1=1;
- TR1=1;
- PT1=0;
- PT0=1;
- IPH=PADCH;
- IP=PADC; //中断优先级
- EA=1; //总中断打开
- void ADC_Finish() interrupt 5
- { ADC_CONTR &= !ADC_FLAG;
- Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)*2;//按LIST_TAB表里的顺序,进行存储采样值
- if(ADC_Count<=127)ADC_Count++;
- else {EADC=0;TR0=0;}
- void LED_Display() interrupt 3 //中断一次显示一列
- TH1=0xfe;
- TL1=0Xd4;
- G++;
- if(G==33)G=1;
- switch(G) //往点阵屏填充一列的数据
- case 1:sw=1;anum=LED_TAB[0];P_3=0x00;break;
- case 2:anum=LED_TAB[0];P_3=0x01;break;
- case 3:anum=LED_TAB[1];P_3=0x02;break;
- case 4:anum=LED_TAB[1];P_3=0x03;break;
- case 5:anum=LED_TAB[2];P_3=0x04;break;
- case 6:anum=LED_TAB[2];P_3=0x05;break;
- case 7:anum=LED_TAB[3];P_3=0x06;break;
- case 8:anum=LED_TAB[3];P_3=0x07;break;
- case 9:anum=LED_TAB[4];P_3=0x08;break;
- case 10:anum=LED_TAB[4];P_3=0x09;break;
- case 11:anum=LED_TAB[5];P_3=0x0a;break;
- case 12:anum=LED_TAB[5];P_3=0x0b;break;
- case 13:anum=LED_TAB[6];P_3=0x0c;break;
- case 14:anum=LED_TAB[6];P_3=0x0d;break;
- case 15:anum=LED_TAB[7];P_3=0x0e;break;
- case 16:anum=LED_TAB[7];P_3=0x0f;break;
- case 17:sw=0;anum=LED_TAB[8];P_3=0x00;break;
- case 18:anum=LED_TAB[8];P_3=0x10;break;
- case 19:anum=LED_TAB[9];P_3=0x20;break;
- case 20:anum=LED_TAB[9];P_3=0x30;break;
- case 21:anum=LED_TAB[10];P_3=0x40;break;
- case 22:anum=LED_TAB[10];P_3=0x50;break;
- case 23:anum=LED_TAB[11];P_3=0x60;break;
- case 24:anum=LED_TAB[11];P_3=0x70;break;
- case 25:anum=LED_TAB[12];P_3=0x80;break;
- case 26:anum=LED_TAB[12];P_3=0x90;break;
- case 27:anum=LED_TAB[13];P_3=0xa0;break;
- case 28:anum=LED_TAB[13];P_3=0xb0;break;
- case 29:anum=LED_TAB[14];P_3=0xc0;break;
- case 30:anum=LED_TAB[14];P_3=0xd0;break;
- case 31:anum=LED_TAB[15];P_3=0xe0;break;
- case 32:anum=LED_TAB[15];P_3=0xf0;break;
- for(led=0;led<=anum;led++) //递增
- { P0=LED[2*led+1];
- P2=LED[2*led];
- delay2us();
- } //递减
- for(;led>=0;led--)
- P2=LED[2*led];
- delay2us();
- void Ad_Control() interrupt 1 //控制采样率
- ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel; //开始AD采集
- void main()
- uint8 i;
- Init();
- while(1)
- ADC_Count=0;
- TR0=1;
- EADC=1; //开启定时器中断0,开启ADC
- while(ADC_Count<128);
- for(i=0;i<128;i++)
- Fft_Image[i]=0;
- FFT();//FFT运算并转换为各频段幅值
