51单片机测程序:
- #include "lpcreg.h"
- #include "main.h"
- #include "mfrc522.h"
- unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
- //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
- //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
- unsigned char code data2[4] = {0x12,0,0,0};
- unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- unsigned char g_ucTempbuf[20];
- void main( )
- unsigned char status;
- InitializeSystem( );
- PcdReset();
- PcdAntennaOff(); //关闭天线
- PcdAntennaOn(); //开启天线
- while ( 1 )
- status = PcdRequest(PICC_REQALL, g_ucTempbuf); #define PICC_REQIDL 0x26 //寻天线区内未进入休眠状态
- if (status != MI_OK)
- LED_GREEN = 1;
- continue;
- LED_GREEN = 0;
- status = PcdAnticoll(g_ucTempbuf);
- continue;
- status = PcdSelect(g_ucTempbuf);
- continue;
- status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);
- continue;
- status = PcdWrite(1, data1);
- continue;
- status = PcdValue(PICC_DECREMENT,1,data2);
- continue;
- status = PcdBakValue(1, 2);
- continue;
- status = PcdRead(2, g_ucTempbuf);
- continue;
- PcdHalt(); //命令卡片进入休眠状态
- //系统初始化
- void InitializeSystem()
- P0M1 = 0x0; P0M2 = 0x0;
- P1M1 = 0x0; P1M2 = 0x0;
- P3M1 = 0x0; P3M2 = 0xFF;
- P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
- //功 能:复位RC522
- //返 回: 成功返回MI_OK
- char PcdReset(void)
- MF522_RST=1;
- _nop_();
- MF522_RST=0;
- _nop_();
- MF522_RST=1;
- _nop_();
- WriteRawRC(CommandReg,PCD_RESETPHASE);
- _nop_();
- WriteRawRC(ModeReg,0x3D); //和Mifare卡通讯,CRC初始值0x6363
- WriteRawRC(TReloadRegL,30);
- WriteRawRC(TReloadRegH,0);
- WriteRawRC(TModeReg,0x8D);
- WriteRawRC(TPrescalerReg,0x3E);
- return MI_OK;
- //功 能:写RC632寄存器
- //参数说明:Address[IN]:寄存器地址
- // value[IN]:写入的值
- void WriteRawRC(unsigned char Address, unsigned char value)
- unsigned char i, ucAddr;
- MF522_SCK = 0;
- MF522_NSS = 0;
- ucAddr = ((Address<<1)&0x7E);
- for(i=8;i>0;i--)
- MF522_SI = ((ucAddr&0x80)==0x80);
- MF522_SCK = 1;
- ucAddr <<= 1;
- MF522_SCK = 0;
- for(i=8;i>0;i--)
- MF522_SI = ((value&0x80)==0x80);
- MF522_SCK = 1;
- value <<= 1;
- MF522_SCK = 0;
- MF522_NSS = 1;
- MF522_SCK = 1;
- //功 能:读RC632寄存器
- //返 回:读出的值
- unsigned char ReadRawRC(unsigned char Address)
- unsigned char ucResult=0;
- MF522_SCK = 0;
- MF522_NSS = 0;
- ucAddr = ((Address<<1)&0x7E)|0x80;
- for(i=8;i>0;i--)
- MF522_SCK = 1;
- ucAddr <<= 1;
- MF522_SCK = 0;
- for(i=8;i>0;i--)
- MF522_SCK = 1;
- ucResult <<= 1;
- ucResult|=(bit)MF522_SO;
- MF522_SCK = 0;
- MF522_NSS = 1;
- MF522_SCK = 1;
- return ucResult;
复制代码 430单片机测试程序:
- #include <msp430x41x.h>
- #include "main.h"
- #pragma memory = constseg(TAB)
- unsigned char data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
- unsigned char data2[4] = {0x12,0,0,0};
- unsigned char DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- #pragma memory=default
- void main(void)
- InitializeSystem();
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- while ( 1 )
- LED_GREEN_OFF;
- continue;
- LED_GREEN_ON; //检测到有卡存在
- { continue; }
- { continue; }
- { continue; }
- { continue; }
- { continue; }
- { continue; }
- { continue; }
- PcdHalt();
- //功能:系统初始化
- void InitializeSystem(void)
- WDTCTL = WDTPW + WDTHOLD; //Stop watchdog timer
- _DINT();
- P1DIR = 0xE8;
- P1OUT = 0xFF;
- P6DIR = 0x08;
- P6OUT = 0xFF;
全部资料(压缩包)下载:
M112120_FSpec_RC522_20050801.pdf
(1.3 MB, 下载次数: 211)
