查看: 27484|回复: 67
stm32串行控制lcd12864液晶显示器 程序
ID:127084 发表于 2016-6-17 12:53 | 显示全部楼层 |阅读模式
   手里有一块12864的液晶显示器,今天拿起来用stm32F103做了一个工程,方便大家参考,希望对大家能够有用。PDF文档仅共参考,我使用的LCD的核心与pdf上的有所不同。
  1. #include "12864.h"
  2. GPIO_InitTypeDef GPIO_InitStructure;
  3. void Delay(__IO uint32_t nCount)
  4. {
  5.    for(; nCount != 0; nCount--);
  6. }
  7. void send_dat(unsigned char dat)
  8. {
  9.     unsigned char i;
  10.         //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  11.     for(i=0;i<8;i++)
  12.     {
  13.                 if((dat&0x80)==0x80) SID_1;
  14.                 if((dat&0x80)==0x00) SID_0;
  15.         CLK_0;
  16.                 Delay(35);
  17.         CLK_1;
  18.                 dat<<=1;
  19.     }
  20. }
  21. unsigned char get_byte()
  22. {
  23.      unsigned char i,temp1=0,temp2=0;
  24.          //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  25.      for(i=0;i<8;i++)
  26.      {
  27.            temp1=temp1<<1;
  28.            CLK_0;
  29.                    Delay(25);
  30.            CLK_1;
  31.                    Delay(20);
  32.            CLK_0;
  33.            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp1++;
  34.      }
  35.      for(i=0;i<8;i++)
  36.      {
  37.            temp2=temp2<<1;
  38.            CLK_0;
  39.                    Delay(25);
  40.            CLK_1;
  41.                    Delay(25);
  42.            CLK_0;
  43.            if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3))  temp2++;
  44.      }
  45.          //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  46.      return ((0xf0&temp1)+(0x0f&temp2));
  47. }
  48. void check_busy()
  49. {
  50.     do
  51.     {
  52.         send_dat(0xfc);
  53.     }
  54.     while((get_byte()&0x8000)==0x8000);
  55. }
  56. void send_cmd(unsigned char cmd)
  57. {
  58.     check_busy();
  59.     send_dat(0xf8);    //
  60.     send_dat(cmd&0xf0); //
  61.     send_dat((cmd&0x0f)<<4); //
  62. }
  63. void write_char(unsigned char dat)
  64. {
  65.     check_busy();
  66.     send_dat(0xfa);//rw=0;rs=1
  67.     send_dat(dat&0xf0);
  68.     send_dat((dat&0x0f)<<4);
  69. }
  70. void lcd_clear()        //清除显示
  71. {
  72.     send_cmd(0x01);
  73. }
  74. void lcd_pos(unsigned char y_add , unsigned char x_add)
  75. {
  76.     switch(y_add)
  77.     {
  78.         case 1:
  79.         send_cmd(0X80|x_add);break;
  80.         case 2:
  81.         send_cmd(0X90|x_add);break;
  82.         case 3:
  83.         send_cmd(0X88|x_add);break;
  84.         case 4:
  85.         send_cmd(0X98|x_add);break;
  86.         default:break;
  87.     }
  88. }
  89. void lcd_wstr(unsigned char y_add , unsigned char x_add , unsigned char *str)    //
  90. {
  91.     unsigned char i;
  92.     lcd_pos(y_add , x_add);
  93.     for(i=0;str[i]!='\0';i++)
  94.     {
  95.         write_char(str[i]);
  96.     }
  97. }
  98. void write_figer(unsigned char y_add , unsigned char x_add , unsigned int figer)//在任何位置写数字
  99. {
  100.     unsigned char d[5],i,j;
  101.     lcd_pos(y_add , x_add);
  102.     d[4]=figer%10;
  103.     d[3]=figer%100/10;
  104.     d[2]=figer%1000/100;
  105.     d[1]=figer%10000/1000;
  106.     d[0]=figer/10000;
  107.     for(i=0;i<5;i++)
  108.     {
  109.         if(d[i]!=0)break;
  110.     }
  111.     if(i==5)i--;
  112.     if(i==4)send_dat(0x30);//数据装完,准备发送
  113.     for(j=i;j<5;j++)
  114.     {
  115.        send_dat(d[j]|0x30);//取得的数字加上0x30也即得到该数字的ASCII码,再将该数字发送去显示
  116.     }
  117. }
  118. void lcd_init()     //
  119. {
  120.     Delay(0xfff);
  121.     send_cmd(0x30);
  122.     send_cmd(0x0C);//0000,1100 整体显示,游标off,游标位置off
  123.     send_cmd(0x01);//0000,0001 清DDRAM
  124.     send_cmd(0x02);//0000,0010 DDRAM地址归位
  125.     send_cmd(0x80);//1000,0000 设定DDRAM 7位地址000,0000到地址计数器A
  126. }
  127. /******************* (C) COPYRIGHT 2011 奋斗STM32 *****END OF FILE****/
12864.zip
1.16 MB, 下载次数: 822, 下载积分: 黑币 -5
参与人数 2黑币 +10 收起 理由
00XIAOXU00 + 5 很给力!
shenlan121 + 5 赞一个!
ID:196399 发表于 2017-5-9 19:03 | 显示全部楼层
从串行时序图中可以看出,发送一个指令需要三个字节,第一个是0xf8或者0xfa这个根据你要发送的是命令还是数据而定,然后发送下一个数据的高四位和第四位,但是数据都是在高四位上面,用51的话我们要分三次发送,但是32的话一个字节可以是32位的/所以我们一次就能完成,这也是为什么下面的i<24的原因因为最后的8位没有用,
admin + 50 回帖助人的奖励!
ID:274187 发表于 2018-1-11 15:05 | 显示全部楼层
请问该模式是串口版硬件配置的程序吗?   PSB端口没用到的那个
ID:302850 发表于 2018-8-20 18:38 | 显示全部楼层
这个似乎是目前为止能找到的最好的12864串行驱动程序了
ID:152510 发表于 2016-12-6 13:36 | 显示全部楼层
感谢分享
ID:105206 发表于 2016-12-15 04:39 | 显示全部楼层
谢谢楼主分享,学习了。
ID:143525 发表于 2016-12-15 08:10 | 显示全部楼层
谢谢分享
ID:159847 发表于 2017-1-4 13:06 | 显示全部楼层
louzh1iahdahoiewjfiaelbf
ID:45457 发表于 2017-1-28 00:07 | 显示全部楼层
学习了
ID:165013 发表于 2017-3-11 19:54 | 显示全部楼层
下来研究研究
ID:190079 发表于 2017-4-16 14:15 | 显示全部楼层
我按照这个做不显示
ID:190786 发表于 2017-4-18 13:27 | 显示全部楼层
感谢楼主分享
ID:148444 发表于 2017-4-18 16:34 | 显示全部楼层
谢谢分享,学习了
ID:148444 发表于 2017-4-18 16:35 | 显示全部楼层
谢谢分享,学习了
ID:187303 发表于 2017-4-24 08:09 | 显示全部楼层
是有些区别 感谢作者的奉献 可以帮助很多初学者
值得拥有!
ID:199351 发表于 2017-5-10 23:37 | 显示全部楼层
谢谢分享,学习了
ID:199732 发表于 2017-5-11 21:27 | 显示全部楼层
谢谢楼主分享,学习了。
ID:155842 发表于 2017-7-17 17:36 | 显示全部楼层
楼主,有硬件原理图吗
ID:220577 发表于 2017-7-18 16:09 | 显示全部楼层
还ok,谢谢分享
ID:222817 发表于 2017-7-28 14:26 | 显示全部楼层
LCD12864 DB0-DB7是接的哪个Io口
ID:153282 发表于 2017-8-31 11:23 | 显示全部楼层
谢谢分享
ID:230697 发表于 2017-9-3 15:33 | 显示全部楼层
谢谢分享,一生平安
ID:77669 发表于 2017-9-12 16:27 | 显示全部楼层
好东西啊,可惜下载币不够
ID:232682 发表于 2017-9-12 17:02 | 显示全部楼层
不错,看看
ID:240989 发表于 2017-10-19 16:53 | 显示全部楼层
谢谢楼主的分享
ID:262564 发表于 2017-12-17 09:33 | 显示全部楼层
赞一个,顺便那个资料
ID:276061 发表于 2018-3-7 15:11 | 显示全部楼层
看看怎么样?
ID:295369 发表于 2018-3-22 10:24 | 显示全部楼层
很给力
ID:197780 发表于 2018-4-3 00:39 | 显示全部楼层
加油,没有钱下载啊
ID:197780 发表于 2018-4-3 00:40 | 显示全部楼层
深夜顶帖,望开源
ID:351564 发表于 2018-6-14 08:45 | 显示全部楼层
好东西,帮顶,看看参考
ID:346034 发表于 2018-7-15 14:15 | 显示全部楼层
谢谢楼主分享资源
ID:374464 发表于 2018-7-18 23:26 | 显示全部楼层
ID:281804 发表于 2018-7-20 11:44 | 显示全部楼层
之前用51做过应用12864点阵液晶屏的东西,现在试试用STM32来
ID:294123 发表于 2018-7-22 00:26 | 显示全部楼层
学习了 谢楼主
ID:46517 发表于 2018-7-28 11:23 | 显示全部楼层
黑币扣了,弹出来,服务器故障,重新点,没黑币了,这是咋回事?
ID:380691 发表于 2018-7-30 09:02 | 显示全部楼层
谢谢lz分享,我一直就没有搞明白液晶屏咋驱动
ID:382798 发表于 2018-8-6 15:12 | 显示全部楼层
想下载来学习一下,,黑币不够
ID:390544 发表于 2018-8-27 20:44 | 显示全部楼层
谢谢分享
