本设计测试部分采用测周期发,12864液晶显示,如有不足,欢迎指教
MSP430直流电机控制仿真原理图
下面是部分单片机程序源码预览:
- * LCD_12864.c
- * Created on: 2016年6月15日
- * Author: Jack zhao
- #include<MSP430F249.h>
- #include "LCD_12864.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar DIR_S[]={
- /*-- 文字: 顺 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
- 0x00,0xFE,0x00,0xFC,0x00,0xFF,0x00,0xF2,0x12,0x1A,0xD6,0x12,0x12,0xF2,0x02,0x00,
- 0x40,0x3F,0x00,0x3F,0x00,0xFF,0x80,0x4F,0x20,0x18,0x07,0x10,0x20,0x4F,0x80,0x00,
- /*-- 文字: 时 --*/
- 0x00,0xFC,0x84,0x84,0x84,0xFC,0x00,0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x00,
- 0x00,0x3F,0x10,0x10,0x10,0x3F,0x00,0x00,0x01,0x06,0x40,0x80,0x7F,0x00,0x00,0x00,
- /*-- 文字: 针 --*/
- 0x40,0x20,0x38,0xE7,0x24,0x24,0x44,0x40,0x40,0x40,0xFF,0x40,0x40,0x40,0x40,0x00,
- 0x01,0x01,0x01,0x7F,0x21,0x11,0x09,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,
- uchar DIR_N[]={
- /*-- 文字: 逆 --*/
- 0x40,0x42,0xCC,0x00,0x08,0xC8,0x09,0x0E,0x08,0xF8,0x08,0x0C,0x0B,0xC8,0x08,0x00,
- 0x40,0x20,0x1F,0x20,0x40,0x63,0x52,0x4A,0x46,0x43,0x42,0x42,0x42,0x47,0x40,0x00,
- /*-- 文字: 时 --*/
- /*-- 文字: 针 --*/
- uchar num1[]={
- /*-- 文字: 课 --*/
- 0x40,0x42,0xCC,0x00,0x00,0x00,0xFE,0x92,0x92,0xFE,0x92,0x92,0xFE,0x00,0x00,0x00,
- 0x00,0x00,0x3F,0x10,0x08,0x22,0x12,0x0A,0x06,0xFF,0x06,0x0A,0x12,0x22,0x20,0x00,
- /*-- 文字: 程 --*/
- 0x24,0x24,0xA4,0xFE,0x23,0x22,0x00,0x3E,0x22,0x22,0x22,0x22,0x22,0x3E,0x00,0x00,
- 0x08,0x06,0x01,0xFF,0x01,0x06,0x40,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0x41,0x00,
- /*-- 文字: 设 --*/
- 0x40,0x40,0x42,0xCC,0x00,0x40,0xA0,0x9E,0x82,0x82,0x82,0x9E,0xA0,0x20,0x20,0x00,
- 0x00,0x00,0x00,0x3F,0x90,0x88,0x40,0x43,0x2C,0x10,0x28,0x46,0x41,0x80,0x80,0x00,
- /*-- 文字: 计 --*/
- 0x40,0x40,0x42,0xCC,0x00,0x40,0x40,0x40,0x40,0xFF,0x40,0x40,0x40,0x40,0x40,0x00,
- 0x00,0x00,0x00,0x7F,0x20,0x10,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
- uchar num[]={
- /*-- 文字: 电 --*/
- 0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
- 0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00,
- /*-- 文字: 机 --*/
- 0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,
- 0x04,0x03,0x00,0xFF,0x00,0x83,0x60,0x1F,0x00,0x00,0x00,0x3F,0x40,0x40,0x78,0x00,
- /*-- 文字: 控 --*/
- 0x10,0x10,0x10,0xFF,0x90,0x20,0x98,0x48,0x28,0x09,0x0E,0x28,0x48,0xA8,0x18,0x00,
- 0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x40,0x00,
- /*-- 文字: 制 --*/
- 0x40,0x50,0x4E,0x48,0x48,0xFF,0x48,0x48,0x48,0x40,0xF8,0x00,0x00,0xFF,0x00,0x00,
- 0x00,0x00,0x3E,0x02,0x02,0xFF,0x12,0x22,0x1E,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00,
- /*-- 文字: 调 --*/
- 0x40,0x42,0xCC,0x00,0x00,0xFE,0x82,0x92,0x92,0xFE,0x92,0x92,0x82,0xFE,0x00,0x00,
- 0x00,0x00,0x3F,0x10,0x88,0x7F,0x00,0x1E,0x12,0x12,0x12,0x5E,0x80,0x7F,0x00,0x00,
- /*-- 文字: 速 --*/
- 0x40,0x40,0x42,0xCC,0x00,0x04,0xF4,0x94,0x94,0xFF,0x94,0x94,0xF4,0x04,0x00,0x00,
- 0x00,0x40,0x20,0x1F,0x20,0x48,0x44,0x42,0x41,0x5F,0x41,0x42,0x44,0x48,0x40,0x00,
- /*-- 文字: 系 --*/
- 0x00,0x00,0x22,0x32,0x2A,0xA6,0xA2,0x62,0x21,0x11,0x09,0x81,0x01,0x00,0x00,0x00,
- 0x00,0x42,0x22,0x13,0x0B,0x42,0x82,0x7E,0x02,0x02,0x0A,0x12,0x23,0x46,0x00,0x00,
- /*-- 文字: 统 --*/
- 0x20,0x30,0xAC,0x63,0x30,0x00,0x88,0xC8,0xA8,0x99,0x8E,0x88,0xA8,0xC8,0x88,0x00,
- 0x22,0x67,0x22,0x12,0x12,0x80,0x40,0x30,0x0F,0x00,0x00,0x3F,0x40,0x40,0x71,0x00,
- uchar num2[]={
- /*-- 文字: 转 --*/
- 0xC8,0xB8,0x8F,0xE8,0x88,0x88,0x40,0x48,0x48,0xE8,0x5F,0x48,0x48,0x48,0x40,0x00,
- 0x08,0x18,0x08,0xFF,0x04,0x04,0x00,0x02,0x0B,0x12,0x22,0xD2,0x0A,0x06,0x00,0x00,
- /*-- 文字: 速 --*/
- /*-- 文字: : --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- uchar num3[]={
- /*-- 文字: 转 --*/
- /*-- 文字: 向 --*/
- 0x00,0xF8,0x08,0x08,0x0C,0xCA,0x49,0x48,0x48,0xC8,0x08,0x08,0x08,0xF8,0x00,0x00,
- 0x00,0xFF,0x00,0x00,0x00,0x1F,0x08,0x08,0x08,0x1F,0x00,0x40,0x80,0x7F,0x00,0x00,
- /*-- 文字: : --*/
- uchar shuzi[]={
- /*-- 文字: 0 --*/
- /*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
- 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
- /*-- 文字: 1 --*/
- 0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,
- /*-- 文字: 2 --*/
- 0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
- /*-- 文字: 3 --*/
- 0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 4 --*/
- 0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24,
- /*-- 文字: 5 --*/
- 0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00,
- /*-- 文字: 6 --*/
- 0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00,
- /*-- 文字: 7 --*/
- 0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00,
- /*-- 文字: 8 --*/
- 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
- /*-- 文字: 9 --*/
- 0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00,
- uchar RMP[]={
- /*-- 文字: r --*/
- 0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,
- /*-- 文字: / --*/
- 0x00,0x00,0x00,0x00,0xC0,0x38,0x04,0x00,0x00,0x60,0x18,0x07,0x00,0x00,0x00,0x00,
- /*-- 文字: m --*/
- 0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,
- /*-- 文字: i --*/
- 0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
- /*-- 文字: n --*/
- 0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,
- void left() //左半屏
- P6OUT&=~BIT0;//cs1=0;
- P6OUT|=BIT1;//cs2=1;
- void right() //右半屏
- P6OUT|=BIT0;//cs1=1;
- P6OUT&=~BIT1;//cs2=0;
- //判忙
- void busy_12864()
- do{
- P6OUT&=~BIT4;//e=0;
- _NOP();
- P6OUT&=~BIT2;//rs=0;
- P6OUT|=BIT3;//rw=1;
- P5OUT=0x00;
- P6OUT|=BIT4;//e=1;
- }while(!(bflag==0X00));
- //命令写入
- void wreg(uchar c)
- busy_12864();
- P6OUT&=~BIT3;//rw=0;
- P6OUT&=~BIT4;//E=0
- _NOP();
- _NOP();
- P5OUT=c;
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- //数据写入
- void wdata(uchar c)
- busy_12864();
- P6OUT|=BIT2;//rs=1
- P5OUT=c;
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- P6OUT|=BIT4;//e=1
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- P6OUT&=~BIT4;
- //显示初始页
- void pagefirst(uchar c)
- uchar i=c;
- c=i|0xb8;
- busy_12864();
- wreg(c);
- //设置显示初始列
- void linefirst(uchar c)
- uchar i=c;
- c=i|0x40;
- busy_12864();
- wreg(c);}
- //清屏
- void ready_12864()
- uint i,j;
- left();
- wreg(0x3f);
- right();
- wreg(0x3f);
- left();
- for(i=0;i<8;i++)
- pagefirst(i);
- linefirst(0x00);
- for(j=0;j<64;j++)
- wdata(0x00);
- right();
- for(i=0;i<8;i++)
- pagefirst(i);
- linefirst(0x00);
- for(j=0;j<64;j++)
- wdata(0x00);
- //16*16汉字显示,纵向取模,字节倒序
- void display(uchar *s,uchar page,uchar line)
- uchar i,j;
- pagefirst(page);
- linefirst(line);
- for(i=0;i<16;i++)
- wdata(*s);s++;
- pagefirst(page+1);
- linefirst(line);
- for(j=0;j<16;j++)
- wdata(*s);s++;
- //8*16汉字显示,纵向取模,字节倒序
- void display_sz(uchar *s,uchar page,uchar line)
- uchar i,j;
- pagefirst(page);
- linefirst(line);
- for(i=0;i<8;i++)
- wdata(*s);s++;
- linefirst(line);
- for(j=0;j<8;j++)
- wdata(*s);s++;
MSP430直流电机控制的所有资料下载:
DC_Motor.rar
(127.51 KB, 下载次数: 249)
