查看: 2200|回复: 0
单片机从00到99程序
ID:148777 发表于 2016-12-6 21:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
sbit a=P2^2;
sbit b=P2^3;
sbit c=P2^4;
uchar kk,temp,Q,F;
void display();
void wei_xuan(uchar Y);
void delay(uint i,j)
        for(;i>0;i--)
                for(j=110;j>0;j--);
        temp=0;
  TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
                if(kk==20)
                        kk=0;
                        temp++;
                        if(temp==100)
                                temp=0;
                        Q=temp/10;
                        F=temp%10;
     display();
        switch(Y)
                case(1):a=0;b=0;c=0;break;
                case(2):a=1;b=0;c=0;break;
void display()
        P0=table[F];
        wei_xuan(1);
  delay(1);
        P0=table[Q];
        wei_xuan();
        delay(1);
void Timer0() interrupt 1
        kk++;
