查看: 3200|回复: 6
新手发一个秒表程序
ID:160658 发表于 2017-1-8 13:47 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
本人新手,发一个小改的秒表,赚点人气,也请多多指点
#include<reg51.h>
sbit Key1 = P1^0;
sbit Key2 = P1^1;
sbit Key3 = P1^2;
sbit Key4 = P1^3;
bit StopwatchRuning = 0;
bit StopwatchRefresh = 1;
unsigned char code LedChar[] = {
        0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[8] = {
        0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,0xFF
unsigned char KeySta[4] = {1, 1, 1, 1};
unsigned char ms = 0;
unsigned char sec = 0;
unsigned char minu = 0;
unsigned char hour = 0;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
void ConfigTimer0(unsigned char ms);
void StopwatchDisplay();
void KeyDriver();
        EA = 1;
        P1 = 0xEF;
        ConfigTimer0(2);
                if(StopwatchRefresh)
                        StopwatchRefresh = 0;
                        StopwatchDisplay();
                KeyDriver();
        unsigned long tmp;
        tmp = 11059200 / 12;
        tmp = (tmp * ms) / 1000;
        tmp = 65536 - tmp;
        tmp = tmp + 18;
        T0RH = (unsigned char)(tmp>>8);
        T0RL = (unsigned char)tmp;
        TMOD &= 0xF0;
        TMOD |= 0x01;
        TH0 = T0RH;
        TL0 = T0RL;
        ET0 = 1;
        TR0 = 1;
        signed char i;
        unsigned char buf[6];
        LedBuff[0] = LedChar[ms%10];
        LedBuff[1] = LedChar[ms/10];
        buf[0] = sec%10;
        buf[1] = sec/10;
        buf[2] = minu%10;
        buf[3] = minu/10;
        buf[4] = hour%10;
        buf[5] = hour/10;
        for(i=5; i>=1; i--)
                if(buf[i] == 0)
                        LedBuff[i+2] = 0xFF;
                        break;
        for( ; i>=0; i--)
                LedBuff[i+2] = LedChar[buf[i]];
        LedBuff[2] &= 0x7F;
        if((buf[2] != 0) || (buf[3] != 0 ) || (buf[4] != 0) || (buf[5] != 0))
                LedBuff[4] &= 0x7F;
        if((buf[4] != 0) || (buf[5] != 0))
                LedBuff[6] &= 0x7F;
void StopwatchAction()
        if(StopwatchRuning)
                StopwatchRuning = 1;
void StopwatchReset()
        ms = 0;
        sec = 0;
        minu = 0;
        hour = 0;
void KeyDriver()
        unsigned char i;
        static unsigned char backup[4] = {1, 1, 1, 1};
        for(i=0; i<4; i++)
                if(KeySta[i] != backup[i])
                        if(backup[i] == 0)
                                if(i == 1)
                                        StopwatchReset();
                                else if(i == 2)
                                        StopwatchAction();
                        backup[i] = KeySta[i];
void KeyScan()
        static unsigned char keybuf[4];
        unsigned char i;
        keybuf[0] =        (keybuf[0] << 1) | Key1;
        keybuf[1] = (keybuf[1] << 1) | Key2;
        keybuf[2] =        (keybuf[2] << 1) | Key3;
        keybuf[3] = (keybuf[3] << 1) | Key4;
        for(i=0; i<4; i++)
                if(keybuf[i] == 0x00)
                        KeySta[i] = 0;
                else if(keybuf[i] == 0xFF)
                        KeySta[i] = 1;
void LedScan()
        static unsigned char i = 0;
        P0 = 0xFF;
        switch(i)
                case 0: P2 = 0xFE; i++; P0 = LedBuff[0]; break;
                case 1: P2 = 0xFD; i++; P0 = LedBuff[1]; break;
                case 2: P2 = 0xFB; i++; P0 = LedBuff[2]; break;
                case 3: P2 = 0xF7; i++; P0 = LedBuff[3]; break;
                case 4: P2 = 0xEF; i++; P0 = LedBuff[4]; break;
                case 5: P2 = 0xDF; i++; P0 = LedBuff[5]; break;
                case 6: P2 = 0xBF; i++; P0 = LedBuff[6]; break;
                case 7: P2 = 0x7F; i=0; P0 = LedBuff[7]; break;
                default: break;
void StopwatchCount()
        if(StopwatchRuning)
                ms++;
                if(ms >= 100)
                        ms = 0;
                        sec++;
                        if(sec >= 60)
                                sec = 0;
                                minu++;
                                if(minu >=60)
                                        minu = 0;
                                        hour++;
                                        if(hour >= 100)
                                                hour = 0;
void int0() interrupt 1
        static unsigned char tmr10ms = 0;
        TH0 = T0RH;
        TL0 = T0RL;
        LedScan();
        KeyScan();
        tmr10ms++;
        if(tmr10ms >= 5)
                tmr10ms = 0;
                StopwatchCount();
收藏收藏1 分享淘帖 顶 踩
ID:161433 发表于 2017-1-13 16:10 | 只看该作者
有电路图配那就更好了,电子爱好者之家力挺你,加油!!!
ID:73463 发表于 2017-1-13 13:46 | 只看该作者
大师兄你好
ID:147359 发表于 2017-1-12 14:33 | 只看该作者
楼主风格是金沙滩宋老师的教程吧。写程有一个好格式是好的习惯。
ID:1 发表于 2017-1-12 02:20 | 只看该作者
截图就可以了
ID:160658 发表于 2017-1-8 15:30 | 只看该作者
电路图不知道怎么转成PDF文件
ID:1 发表于 2017-1-8 15:03 | 只看该作者
很好 电路图能分享一下吗?
