查看: 3361|回复: 5
MFRC522 51单片机测试程序
完整的源码和教程下载:
MFRC522测试程序.rar (349.68 KB, 下载次数: 64)
主程序预览:
  1. /**********************RC522实验开发板例程************************
  2. *  CPU:STC89C52RC
  3. *  晶振:11.0592MHZ
  4. ------------------------------------------------*/
  5. #include <reg52.h>
  6. #include  <STDIO.H>
  7. #include <string.h>
  8. #include "main.h"
  9. #include "mfrc522.h"
  10. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  11. //M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
  12. //4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
  13. unsigned char code data2[4]  = {0,0,0,0x01};
  14. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  15. unsigned char g_ucTempbuf[20];
  16. void delay1(unsigned int z)
  17. {
  18.         unsigned int x,y;
  19.         for(x=z;x>0;x--)
  20.         for(y=110;y>0;y--);
  21. }
  22. void main( )
  23. {
  24.      unsigned char status,i,j;
  25.           unsigned int temp;
  26.      InitializeSystem( );
  27.      PcdReset();
  28.      PcdAntennaOff();
  29.      PcdAntennaOn();
  30.      while ( 1 )
  31.      {
  32.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  33.          if (status != MI_OK)
  34.          {
  35.               InitializeSystem( );
  36.      PcdReset();
  37.      PcdAntennaOff();
  38.      PcdAntennaOn();
  39.                           continue;
  40.          }
  41.
  42.                         printf("卡的类型:");
  43.             for(i=0;i<2;i++)
  44.                                         {
  45.                                                 temp=g_ucTempbuf[i];
  46.                                                 printf("%X",temp);
  47.
  48.                                         }
  49.
  50.          status = PcdAnticoll(g_ucTempbuf);//防冲撞
  51.          if (status != MI_OK)
  52.          {    continue;    }
  53.
  54.                                         ////////以下为超级终端打印出的内容////////////////////////
  55.
  56.                                         printf("卡序列号:");        //超级终端显示,
  57.                                         for(i=0;i<4;i++)
  58.                                         {
  59.                                                 temp=g_ucTempbuf[i];
  60.                                                 printf("%X",temp);
  61.
  62.                                         }
  63.                                         ///////////////////////////////////////////////////////////
  64.          status = PcdSelect(g_ucTempbuf);//选定卡片
  65.          if (status != MI_OK)
  66.          {    continue;    }
  67.
  68.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  69.          if (status != MI_OK)
  70.          {    continue;    }
  71.
  72.          status = PcdWrite(1, data1);//写块
  73.          if (status != MI_OK)
  74.          {    continue;    }
  75. while(1)
  76.                 {
  77.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
  78.          if (status != MI_OK)
  79.          {
  80.                  InitializeSystem( );
  81.      PcdReset();
  82.      PcdAntennaOff();
  83.      PcdAntennaOn();
  84.                           continue;
  85.          }
  86.                  status = PcdAnticoll(g_ucTempbuf);//防冲撞
  87.          if (status != MI_OK)
  88.          {    continue;    }
  89.                 status = PcdSelect(g_ucTempbuf);//选定卡片
  90.          if (status != MI_OK)
  91.          {    continue;    }
  92.
  93.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
  94.          if (status != MI_OK)
  95.          {    continue;    }
  96.          status = PcdValue(PICC_DECREMENT,1,data2);//扣款
  97.          if (status != MI_OK)
  98.          {    continue;    }
  99.
  100.          status = PcdBakValue(1, 2);//块备份
  101.          if (status != MI_OK)
  102.          {    continue;    }
  103.
  104.          status = PcdRead(2, g_ucTempbuf);//读块
  105.          if (status != MI_OK)
  106.          {    continue;    }
  107.                 printf("卡读块:");        //超级终端显示,
  108.          for(i=0;i<16;i++)
  109.                                         {
  110.                                                 temp=g_ucTempbuf[i];
  111.                                                 printf("%X",temp);
  112.
  113.                                         }
  114.                  printf("\n");
  115.                 LED_GREEN = 0;
  116.             for(i=0;i<250;i++)//先输出一种频率的声音
  117.         {
  118.          for(j=0;j<80;j++);
  119.          Speaker=~Speaker;
  120.         }
  121.                 delay1(100);
  122.                 LED_GREEN = 1;
  123.                 delay1(100);
  124.                 LED_GREEN = 0;
  125.                 delay1(200);
  126.                 LED_GREEN = 1;
  127.                  PcdHalt();
  128.                 }
  129.     }
  130. }
  131. /////////////////////////////////////////////////////////////////////
  132. //系统初始化
  133. /////////////////////////////////////////////////////////////////////
  134. void InitializeSystem()
  135. {
  136. /*        P0M1 = 0x0; P0M2 = 0x0;
  137.         P1M1 = 0x0;        P1M2 = 0x0;
  138.         P3M1 = 0x0; P3M2 = 0xFF;
  139. */        P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
  140.         TMOD=0x21;                   //设T0为方式1,GATE=1;
  141.         SCON=0x50;
  142.         TH1=0xF4;          //波特率为2400bps
  143.         TL1=0xF4;
  144.         TH0=0;
  145.         TL0=0;
  146.         TR0=1;
  147.         ET0=1;             //允许T0中断
  148.         TR1=1;                           //开启定时器
  149.         TI=1;
  150.         EA=1;                                   //开启总中断
  151.
  152.         ES = 1;
  153.         RI = 1;
  154. }
参与人数 1黑币 +5 收起 理由
张胜233 + 5 很给力!
ID:89286 发表于 2017-1-13 15:22 | 只看该作者
thank for sharing
ID:185990 发表于 2017-4-4 13:42 | 只看该作者
这个流弊,说的很详细啊!
ID:185854 发表于 2017-4-4 22:57 | 只看该作者
谢谢分享啊
ID:234919 发表于 2017-12-5 20:48 | 只看该作者
好东西
ID:46475 发表于 2018-4-16 22:09 | 只看该作者
程序大同小异为什么偏偏不能用
