- //PIC16f877A读写24c02程序
- #include<pic.h>
- #include<string.h>
- #define uchar unsigned char
- #define uint unsigned int
- static volatile unsigned char aCC @ 0x20; //发收数据暂存器
- static volatile bit acc0 @ (unsigned)&acc*8+0; //接收
- static volatile bit acc7 @ (unsigned)&acc*8+7; //发送
- static volatile unsigned char err @ 0x21; //
- static volatile bit err0 @ (unsigned)&err*8+0;
- static volatile bit err3 @ (unsigned)&err*8+3;
- static volatile bit err6 @ (unsigned)&err*8+6;
- static volatile bit err7 @ (unsigned)&err*8+7; //应答位暂存位 void Cack(); //应答位检查
- void Mnack(); //发送非应答位
- void Mack(); //发送应答位
- void Stop(); //停止IC总线
- void Sta(); //启动IC总线
- void Wrbyt (uchar x) ; //写一字节
- uchar Rdbyt( ); //读一字节
- void Rdnbyt (); //读n个数据
- void Wrnbyt(uchar SLAwtemp ); //写n个数据
- void initial(); //I/O初始化子程序
- void LED (); //
- void delay(uint a);
- void delay1();
- #define SCL RB4 //4 ;24C01-6
- #define SDA RB5 //5 ;24C01-5
- #define SCLIO TRISB4 //4
- #define SDAIO TRISB5 //5
- #define SLAW 0x0A0//寻址字节写
- #define SLAR 0x0A1//寻址字节读
- uchar numer=1; //数码管数据暂存区
- unsigned char sun[10] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; //////////////24C01/////////////////
- //--------应答位检查---------
- void Cack()
- SCL=1;
- SDAIO=1;//输入1
- SCLIO=0;
- delay1();
- err7=SDA;//c=1错误ERR
- SCL=0;
- ///--------发送非应答位----------
- void Mnack()
- SDA=1;
- SCLIO=0;
- SDAIO=0;//输出
- SCL=1;
- delay1();
- SCL=0;
- SDA=0;
- //-------发送应答位---------------
- void Mack()
- SDA=0;
- SCLIO=0;
- SDAIO=0;//输出
- SCL=1;
- delay1();
- SCL=0;
- SDA=1;
- //--------停止IC总线---------------
- void Stop()
- SDAIO=0;//输出
- SCLIO=0;
- SDA=0;
- delay1();
- SCL=1;
- delay1();
- SDA=1;
- delay1();
- //--------;启动IC总线-------------
- void Sta()
- SDAIO=0;//输出
- SCLIO=0;
- SDA=1;
- delay1();
- SCL=1;
- delay1();
- SDA=0;
- delay1();
- SCL=0;
- //--------写一字节------------------------
- void Wrbyt(uchar x)
- uchar i;
- acc=x;
- SCLIO=0;
- SDAIO=0;
- for(i=8;i>0;i--)
- SDA=acc7;
- SCL=1;
- delay1();
- SCL=0;
- SDA=0;
- acc=acc<<1;
- //---------读一字节-----------------
- uchar Rdbyt( )
- uchar i;
- SCLIO=0;
- SDAIO=1;//;输入
- for(i=8;i>0;i--)
- acc=acc<<1;//接收数据左移寄存器
- SCL=1;
- delay1();
- acc0=SDA;
- SCL=0;
- delay1();
- return(acc);
- ////---------读n个数据----------------
- void Rdnbyt () //传送数据个
- Sta(); //启动IC总线
- delay1();
- numer = Rdbyt();///读一字节
- delay1();
- Stop(); //停止IC总线
- //---------写n个数据---------------
- { err7=1;
- if(err7==1)///c=1E0,ERR
- Sta(); //启动IC总线
- delay1();
- Wrbyt(SLAwtemp); //写一字节
- delay1();
- Cack();//应答位检查-
- delay1();
- while(err7==1);
- Stop(); //停止IC总线
- //系统 各I/O初始化子程序
- void initial()
- TRISC=0;
- TRISA=0;
- TRISB1=1;
- TRISB2=1;
- } //LED
- void LED ()
- PORTA=0X1f;
- PORTC=sun[numer];
- uint b=100;
- while(a--)
- while(b--);
- void delay1()
- NOP();
- NOP();
- NOP();
- NOP();
- void main()
- initial();//系统 各I/O初始化子程序
- LED();
- delay(100);
- Wrnbyt (SLAW);//寻址字节写#0A0
- delay1();
- Wrnbyt (0x05);//写地址0x05
- delay1();
- Wrnbyt (0x06);//写数据0x06
- delay1();
- Wrnbyt (SLAR);//寻址字节读#0A1
- delay1();
- Wrnbyt (0x05);//读地址0x05
- delay1();
- Rdnbyt (); //读数据
- delay(5);
- while(1)
- {LED();}
复制代码 |
