查看: 3843|回复: 3
STM32 HX711程序
ID:199142 发表于 2017-5-11 11:21 | 显示全部楼层 |阅读模式
nclude <stdio.h>
#include "stm32f10x_gpio.h"
// sbit ADDO=P2^0;
// sbit ADSK=P2^1;
#define ADSK_H  GPIO_SetBits (GPIOA ,GPIO_Pin_1)
#define ADSK_L  GPIO_ResetBits(GPIOA ,GPIO_Pin_1)
void static Delay(u32 del)
        while(del--);
void GPIO_Configuration_XH711(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IPU;
//读711 AD数据子程序
u32 ReadCount(void)
        u32 Count;
        u16 ADval;
        u8 i;
        ADSK_L;
        Count=0;
        while(GPIO_ReadInputDataBit(GPIOA ,GPIO_Pin_2));
        for(i=0;i<24;i++)   //读24个bit
                ADSK_H;
                Delay(5);
                Count=Count<<1;
                ADSK_L;
                Delay(5);
                  if(GPIO_ReadInputDataBit(GPIOA ,GPIO_Pin_2))Count++;
        ADSK_H; //发送第25个脉冲,表示下次转换使用A通道128db
        Delay(5);
//        Count=Count^0x800000;
        ADSK_L;
        Delay(5);
/*        if((Count & 0x800000) == 0x800000)
                Count = ~(Count - 1);
//        ADval = (int)(Count >> 8);//取高十六位有效值
        ADval = (int)(Count>>8);
//        ADDO=1;
        return(ADval);
u32 Weighing(void)
        u32 X1;
        u8 t,t1,count=0;
        u16 databuffer[30];                                             //过采样缓冲区
        u16 temp=0;
        u32 X;
    do{        //循环读数30次
                X=ReadCount();
                if(X>100)             //如果是在测量在有效区范围的值,标示此读数有效
                        databuffer[count]=X;
                        count++;
        }while(count<30);
        if(count==30)                                    //每次度数一定要读到30次数据,否则丢弃
            do                                            //将数据X升序排列
                        t1=0;
                        for(t=0;t<count-1;t++)
                                if(databuffer[t]>databuffer[t+1])//升序排列
                                        temp=databuffer[t+1];
                                        databuffer[t+1]=databuffer[t];
                                        databuffer[t]=temp;
                                        t1=1;
                }while(t1);
        /* 从排序过的数组里中间抽取连续的10组数据,进行取平均值,获得较高的精度 */
        X1 = 0;
        for(count = 10; count < 20; count++){
                X1 = X1 + databuffer[count];
        X1 = X1 / 10;
return X1;
ID:221051 发表于 2017-7-23 13:42 | 显示全部楼层
谢谢楼主的分享。
ID:168715 发表于 2017-8-12 14:34 | 显示全部楼层
你这程序错了
ID:64765 发表于 2018-9-26 16:52 | 显示全部楼层
谢谢楼主的分享。
