查看: 8231|回复: 8
详细LCD1602串行或者并行数据传输51单片机程序(自编)
ID:195660 发表于 2017-7-28 10:38 | 显示全部楼层 |阅读模式
单片机串行源程序如下:
  1. #include "reg52.h"
  2. #include <intrins.h>
  3.
  4. //LCD1602接口定义
  5. #define    LCD_DATA    P1  //P1口(P14~P17)与LCD高四位(D4~D7)对应相接
  6. sbit   LCD1602_RS=P1^2;        //数据指令
  7. sbit   LCD1602_EN=P1^3;        //使能
  8.
  9. //延时函数,12mhz 6t延迟时间10*255us
  10. void LCD_init(void);
  11. void LCD_en_write(void);
  12. void LCD_write_command(unsigned char command) ;
  13. void LCD_write_data(unsigned char Recdata);
  14. void LCD_set_xy (unsigned char x, unsigned char y);
  15. void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s);
  16. void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata);
  17. void delay_nus(unsigned int n);
  18. void delay_nms(unsigned int n);
  19.
  20. //以下函数用于输出字符串和数字
  21. int LCD_PutNum(unsigned long num,int XS,int pos);
  22. int LCD_PutStr(unsigned char *DData,int pos);
  23.
  24. //-------------------------1us延时函数---------------------------------
  25. void delay_1us(void)
  26. {
  27.     _nop_();
  28. }
  29. //------------------------N us延时函数---------------------------------
  30. void delay_nus(unsigned int n)
  31. {
  32. unsigned int i=0;
  33. for (i=0;i<n;i++)
  34. delay_1us();
  35. }
  36.   //-----------------------1ms延时函数----------------------------------
  37. void delay_1ms(void)
  38. {
  39. unsigned int i;
  40. for (i=0;i<1140;i++);
  41. }
  42.   //-----------------------N ms延时函数---------------------------------
  43. void delay_nms(unsigned int n)
  44. {
  45. unsigned int i=0;
  46. for (i=0;i<n;i++)
  47. delay_1ms();
  48. }
  49.   //------------------------液晶初始化-----------------------------------
  50. void LCD_init(void)
  51. {
  52. LCD_write_command(0x28);
  53. delay_nus(40);
  54. LCD_write_command(0x28);
  55. delay_nus(40);
  56. LCD_write_command(0x28);
  57. delay_nus(40);
  58.
  59. LCD_en_write();
  60. delay_nus(40);
  61. LCD_write_command(0x28); //4位显示
  62. LCD_write_command(0x0c); //显示开
  63. LCD_write_command(0x01); //清屏
  64. delay_nms(2);
  65. }
  66.
  67.   //----------------------液晶使能函数-------------------------------------
  68. void LCD_en_write(void)
  69. {                       //EN由高电平跳变到低电平时液晶使能
  70. LCD1602_EN=1;
  71. delay_nus(1);
  72. LCD1602_EN=0;
  73. }
  74. //------------------------写指令函数--------------------------------------
  75. void LCD_write_command(unsigned char command)
  76. {
  77. delay_nus(16);
  78. LCD1602_RS=0; //RS=0
  79. LCD_DATA &=0X0f; //清高四位
  80. LCD_DATA|=command&0xf0; //写高四位
  81. LCD_en_write();
  82. command=command<<4; //低四位移到高四位
  83. LCD_DATA&=0x0f; //清高四位
  84. LCD_DATA|=command&0xf0; //写低四位
  85. LCD_en_write();
  86. }
  87.
  88. //------------------------写数据函数--------------------------------------
  89. void LCD_write_data(unsigned char Recdata)
  90. {
  91. delay_nus(16);
  92. LCD1602_RS=1; //RS=1
  93. LCD_DATA&=0X0f; //清高四位
  94. LCD_DATA|=Recdata&0xf0; //写高四位
  95. LCD_en_write();
  96. Recdata=Recdata<<4; //低四位移到高四位
  97. LCD_DATA&=0X0f; //清高四位
  98. LCD_DATA|=Recdata&0xf0; //写低四位
  99. LCD_en_write();
  100. }
  101.
  102. //-----------------------地址定位函数-------------------------------------
  103. void LCD_set_xy( unsigned char x, unsigned char y )
  104. {
  105.     unsigned char address;
  106.     if (y == 0) address = 0x80 + x;
  107.     else address = 0xc0 + x;
  108.     LCD_write_command(address);
  109. }
  110.
  111.
  112. //----------------------在某个地址处,写一个字符----------------------------
  113. void LCD_write_char(unsigned char X,unsigned char Y,unsigned char Recdata) //列x=0~15,行y=0,1
  114. {
  115.     LCD_set_xy(X, Y); //写地址
  116.     LCD_write_data(Recdata);
  117. }
  118. //----------------------------输出字符串-------------------------------------
  119. int LCD_PutStr(unsigned char *DData,int pos)  //pos表示字符显示位置,0~31
  120. {
  121.     unsigned char i;
  122.     if(pos==-1)
  123.     {
  124.         LCD_write_command(0x01); //清屏
  125.         delay_nms(2);
  126.         pos=0;
  127.     }
  128.     while((*DData)!='\0')
  129.     {
  130.         switch(*DData)
  131.         {
  132.             case '\n': //如果是\n,则换行
  133.             {
  134.                 if(pos<17)
  135.                 {
  136.                     for(i=pos;i<16;i++) LCD_write_char(i%16, i/16,' ');
  137.                     pos=16;
  138.                 }
  139.                 else
  140.                 {
  141.                     for(i=pos;i<32;i++) LCD_write_char(i%16, i/16,' ');
  142.                     pos=0;
  143.                 }
  144.                 break;
  145.             }
  146.
  147.             case '\b': //如果是\b,则退格
  148.             {
  149.                 if(pos>0) pos--;
  150.                 LCD_write_char(pos%16, pos/16, ' ');
  151.                 break;
  152.             }
  153.
  154.             default:
  155.             {
  156.                 if((*DData)<0x20)  //小于0x20的显示不了?
  157.                 {
  158.                     *DData=' ';
  159.                 }
  160.
  161.                 LCD_write_char(pos%16, pos/16,*DData);
  162.                 pos++;
  163.                 break;
  164.             }
  165.         }
  166.         DData++;
  167.     }
  168.     return(pos);
  169. }
  170. //----------------------------输出数字---------------------------------
  171. //这段程序写法我的理解大致是这样:num为去掉小数点之后的数字,XS为小数点
  172. //从左数第几位,pos为显示的位置
  173. //---------------------------------------------------------------------
  174. int LCD_PutNum(unsigned long num,int XS,int pos)
  175. {
  176.     unsigned long tmp=0;
  177.     unsigned char numbits=0; //总数字位数
  178.     if(pos==-1)
  179.     {
  180.         LCD_write_command(0x01);
  181.         delay_nms(2);
  182.         pos=0;
  183.     }
  184.
  185.     if(num==0)
  186.     {
  187.         LCD_write_char(pos%16, pos/16, '0');
  188.         pos++;
  189.     }
  190.     else
  191.     {
  192.         if(num<0)
  193.         {
  194.             LCD_write_char(pos%16, pos/16, '-');
  195. ……………………
  196. …………限于本文篇幅 余下代码请从51黑下载附件…………
主函数还没有写,大家可以按自己写需求写,程序存在问题还很多,请多多指教,一起进步:
LCD1602.zip (61.29 KB, 下载次数: 100)
ID:266711 发表于 2018-3-16 15:32 | 显示全部楼层
学到了很多,让我受益很多谢谢
ID:442599 发表于 2019-3-7 18:47 | 显示全部楼层
没有主函数啊
ID:398105 发表于 2019-3-9 10:59 | 显示全部楼层
谢谢分享
ID:770247 发表于 2020-12-9 14:06 | 显示全部楼层
请问串行的电路图是什么样子的啊?
ID:770247 发表于 2020-12-9 14:07 | 显示全部楼层
请问串行的电路图是什么样子的啊,下载了压缩包只有程序
ID:328014 发表于 2020-12-9 16:18 | 显示全部楼层
看程序顶部有端口定义,按端口定义接线就可以了,如果以前没有接过这种电路 最好去51hei先找一个电路图,搜索"1602 4线"或者"1602 四线"这几个字即可,有很多人分享http://www.51hei.com/bbs/dpj-52853-1.html
http://www.51hei.com/bbs/dpj-167284-1.html
ID:857626 发表于 2020-12-9 18:43 | 显示全部楼层
谢谢分享,写的很详细!!
ID:770247 发表于 2020-12-23 14:24 | 显示全部楼层
51hei团团 发表于 2020-12-9 16:18
看程序顶部有端口定义,按端口定义接线就可以了,如果以前没有接过这种电路 最好去51hei先找一个电路图,搜 ...
好的,谢谢
