自己写的,不规范还望包含,keil和protues文件
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uint speed = 100; //初始转速
- uint max = 200; //最慢转速
- uint min = 20; //最快转速
- sbit swich = P2^0; //总开关
- sbit dir = P2^1; //电机旋转方向
- sbit le1=P2^6;
- sbit le2=P2^7;
- sbit speedadd=P3^2;
- sbit speedsub=P3^3;
- unsigned char uca_MotorStep[]={0x01,0x03,0x02,0x06,0x04,0x0C,0x08,0x09}; //励磁电流数组。
- uchar leddata[]={
- 0x3F, //"0"
- 0x06, //"1"
- 0x5B, //"2"
- 0x4F, //"3"
- 0x66, //"4"
- 0x6D, //"5"
- 0x7D, //"6"
- 0x07, //"7"
- 0x7F, //"8"
- 0x6F, //"9"
- 0x40, //"-"
- 0x00, //熄灭
- void delay1ms(void) //误差 0us
- unsigned char a,b,c;
- for(c=1;c>0;c--)
- for(b=142;b>0;b--)
- for(a=2;a>0;a--);
- void delay(uint x ) //多功能毫秒延时
- uint i;
- for(i=0;i<x;i++)
- delay1ms();
- void display(void)
- if(swich==1)
- P0= leddata[11];
- delay(1);
- le2=1;
- le1=1;
- delay(1);
- le2=0;
- le1=0;
- else
- if(dir==1)
- P0= leddata[11];
- delay(1);
- le2=1;
- delay(1);
- le2=0;
- else
- P0 =leddata[10];
- delay(1);
- le2=1;
- delay(1);
- le2=0;
- P0=leddata[9-(speed-20)/20];
- delay(30);
- le1=1;
- delay(5);
- le1=0;
- void Init_INT0()
- EX0=1; //开启外部中断 0
- IT0=1; //设置成低电平触发,1为下降沿触发
- EX1=1; //开启外部中断 1
- IT1=1; //设置成低电平触发,1为下降沿触发
- EA=1; //开启总中断
- void Interrupt0_handler() interrupt 0
- EA=0; //首先关闭总中断,以消除按键出现的抖动所产生的干扰
- delay(20); //同样是为了消除抖动而产生新的中断
- if(speed>min)
- {speed=speed-20;} //限制最快转速
- else
- {speed=min;}
- while(speedadd==0);
- EA=1; //恢复中断
- void Interrupt1_handler() interrupt 2
- if(speed<max)
- {speed=speed+20;}
- else
- {speed=max;} //限制最慢转速
- while(speedsub==0);
- EA=1; //恢复中断
- void main()
- int i; //初始化
- dir=1;
- le1=0;
- le2=0;
- start:
- if(swich==0)
- {Init_INT0();} //总开关开启,初始化中断,开始转动
- else
- {display(); goto start; }
- if(dir==1)
- seq:
- while(1)
- display();
- for (i=0; i<8; i++)
- P1 = uca_MotorStep[i]; //取数据
- delay(speed); //调节转速
- if(dir==0) //是否换向
- delay(5); // 换向延时
- goto oppo; //换向
- if(swich==1) //总开关运行中关闭
- goto start; //等待开启
- else
- oppo:
abc.zip
(116.04 KB, 下载次数: 208)
