专注电子技术学习与研究
当前位置:单片机教程网 >> STM32 >> 浏览文章
stm32_CAN总线的发送和接收程序
作者:碧海蓝天   来源:来自碧海蓝天   点击数:…  更新时间:2014年07月30日   【字体:大 中 小】
碧海蓝天在做CAN模块的多线路控制系统的程序,现在把简单的发送和接收的程序贴出来供大家参考,注释写的很清楚了,这里我就不废话了,直接上代码了——
文件can.c
#include "stm32f10x.h"
#include "can.h"
#define GPIO_CAN                   GPIOA
#define RCC_APB2Periph_GPIO_CAN    RCC_APB2Periph_GPIOA
#define GPIO_Pin_RX                GPIO_Pin_11
#define GPIO_Pin_TX                GPIO_Pin_12
#define GPIO_Remap_CAN             GPIO_Remap1_CAN1
#define LED_SET() GPIO_SetBits(GPIOB,GPIO_Pin_15)
#define LED_RST() GPIO_ResetBits(GPIOB,GPIO_Pin_15)
void CAN_config_init(void)
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
    // 36M 250k速率
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
  CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_12tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_3tq;
  CAN_InitStructure.CAN_Prescaler=9;
  CAN_Init(CAN1, &CAN_InitStructure);
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
void CAN_init(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
      // 首先打开电源及时钟
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO |RCC_APB2Periph_GPIO_CAN, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    NVIC_InitStructure.NVIC_IRQChannel = USB_HP_CAN1_TX_IRQn;
    // 然后配置pin
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_RX;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
    GPIO_Init(GPIO_CAN, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_TX;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    // 映射下
    GPIO_PinRemapConfig(GPIO_Remap_CAN , ENABLE);
    // 波特率过滤器初始化
    CAN_config_init();
    CAN_ITConfig(CAN1, CAN_IT_FMP0 | CAN_IT_FF0 | CAN_IT_FOV0, ENABLE);  // fifo0中断
    CAN_ITConfig(CAN1, CAN_IT_FMP1 | CAN_IT_FF1 | CAN_IT_FOV1, ENABLE);  // fifo1中断
    CAN_ITConfig(CAN1, CAN_IT_TME, DISABLE);                // 发送中断
int CAN_tx_data(void)
    CanTxMsg TxMessage;
    uint8_t TransmitMailbox = 0;
  u32 i;
    TxMessage.StdId=0x001;
    TxMessage.RTR=CAN_RTR_DATA;
    TxMessage.IDE=CAN_ID_STD;
    TxMessage.DLC=4;
    TxMessage.Data[0]=0x04;
    TxMessage.Data[1]=0x08;
    TxMessage.Data[2]=0x0c;
    TxMessage.Data[3]=0x10;
    TransmitMailbox = CAN_Transmit(CAN1, &TxMessage);
  i = 0;
  // 用于检查消息传输是否正常
  while((CAN_TransmitStatus(CAN1, TransmitMailbox) != CANTXOK) && (i != 0xFF))
   i++;
  i = 0;
  // 检查返回的挂号的信息数目
  while((CAN_MessagePending(CAN1, CAN_FIFO0) < 1) && (i != 0xFF))
   i++;
void USB_LP_CAN1_RX0_IRQHandler(void)
  //  u32 i;
    CanRxMsg RxMessage;
   if(SET == CAN_GetITStatus(CAN1,CAN_IT_FF0))
        CAN_ClearITPendingBit(CAN1,CAN_IT_FF0);
   else if(SET == CAN_GetITStatus(CAN1,CAN_IT_FOV0))
        CAN_ClearITPendingBit(CAN1,CAN_IT_FOV0);
        CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
        if(RxMessage.StdId==0x001&&RxMessage.DLC==4)
     LED_SET();
     //   printf("CAN_FIFO0 RxMessage.StdId is 0x%x\r\n",RxMessage.StdId);
     //   printf("RxMessage.DLC is 0x%x\r\n",RxMessage.DLC);
      //  for(i = 0; i < RxMessage.DLC; i++)
     //       printf("data[%d] is 0x%x\r\n",i,RxMessage.Data[i]);
     //   printf("\r\n");
void LED_init(void)
 GPIO_InitTypeDef GPIO_InitStruct;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
 GPIO_InitStruct.GPIO_Pin = GPIO_Pin_15;
 GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;
 GPIO_Init(GPIOB, &GPIO_InitStruct);
void soft_delayms(u16 t)
 u16 tt;
 while(t--)
  tt = 10000;
  while(tt--);
文件:can.h
 #ifndef __CAN_H
#define __CAN_H
void CAN_config_init(void);
void CAN_init(void);
int CAN_tx_data(void);
void LED_init(void);
void soft_delayms(u16 t);
#endif
文件:main.c
#include "can.h"
int main(void)
 SystemInit();
 LED_init();
 CAN_config_init();
 CAN_init();
 CAN_tx_data();
有问题的可以直接提问,大家互相讨论着进步
【关闭窗口】
相关文章
