查看: 8684|回复: 6
两片单片机的串行通信 仿真与程序原理图
ID:120620 发表于 2016-5-13 21:34 | 显示全部楼层 |阅读模式
两片单片机的串行通信仿真原理图
单片机双机通信的所有资料下载:
两片单片机的串行通信.rar (48.98 KB, 下载次数: 58)
程序1:
  1. #include <reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit K0=P1^0;
  6. sbit K1=P1^1;
  7. sbit K2=P1^2;
  8. sbit K3=P1^3;
  9. sbit K4=P1^4;
  10. sbit K5=P1^5;
  11. sbit K6=P1^6;
  12. sbit K7=P1^7;
  13. uchar i();
  14. uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,
  15.                   0x6d,0x7d,0x07,0x7f,0x6f,
  16.                                   0x77,0x7c,0x39,0x5e,0x79,0x71};
  17. void delay(uint z)
  18. { uint x,y;
  19. for(x=z;x>0;x--)
  20. for(y=110;y<0;y--);
  21. }
  22. void send(uchar c)   //向串口发送字符
  23. { SBUF=c;
  24.   while(TI==0);
  25.         TI=0;
  26. }
  27. void main()
  28. {
  29. uchar i;
  30. P2=0x00;
  31. SCON=0x50;      //串口模式1
  32. TMOD=0x20;      //T1工作模式2
  33. PCON=0x00;      //波特率不倍增
  34. TH1=0xfd;       //波特率设定6900
  35. TL1=0xfd;
  36. TI=RI=0;
  37. TR1=1;   //启动定时器T1
  38. IE=0x90;     //允许串口中断
  39. while(1)
  40. {
  41. if(K0==0) send('0'); else  send('A');
  42. if(K1==0) send('1'); else  send('B');
  43. if(K2==0) send('2'); else  send('C');
  44. if(K3==0) send('3'); else  send('D');
  45. if(K4==0) send('4'); else  send('E');
  46. if(K5==0) send('5'); else  send('F');
  47. if(K6==0) send('6'); else  send('G');
  48. if(K7==0) send('7'); else  send('H');
  49.    }
  50. }
  51. void serial_int() interrupt 4  //甲机串口接收中断函数
  52. { if(RI)
  53.   { RI=0;
  54.      if(SBUF>=0 &&SBUF<=15)
  55.         P2=tab[SBUF];
  56.       else
  57.       P2=0x00;
  58. if(SBUF=='x')
  59. if(i>=0&&i<9)
  60. {
  61.   i=i+1;
  62.   P2=tab[i];
  63.   }
  64.   if(i==9) i=0;
  65.   if(SBUF=='y')
  66. {
  67.   P2=0x00;
  68.   i=0;
  69.       }
  70.    }
  71. }
程序2:
  1. #include <reg51.h> #include<intrins.h>
  3. #define uint unsigned int
  4. sbit L0=P1^0;
  5. sbit L1=P1^1;
  6. sbit L2=P1^2;
  7. sbit L3=P1^3;
  8. sbit L4=P1^4;
  9. sbit L5=P1^5;
  10. sbit L6=P1^6;
  11. sbit L7=P1^7;
  12. sbit KEY2=P0^2;
  13. void delay(uint z)
  14. { uint x,y;
  15.   for(x=z;x>0;x--)
  16.      for(y=110;y<0;y--);
  17. }
  18. void send(uchar c)   //向串口发送字符
  19.    { SBUF=c;
  20.      while(TI==0);
  21.      TI=0;
  22. }
  23.    uchar key()        //按键扫描
  24. { uchar keyon,temp;
  25.   P2=0x0f;  delay(1);
  26. temp=P2^0x0f;
  27. switch(temp)
  28. { case 1:keyon=3;break;
  29. case 2:keyon=2;break;
  30. case 4:keyon=1;break;
  31. case 8:keyon=0;break;
  32. default:keyon=16;
  33. }
  34. P2=0xf0;
  35. delay(1);
  36. temp=P2>>4^0x0f;
  37. switch(temp)
  38. { case 1:keyon+=0;break;
  39.   case 2:keyon+=4;break;
  40.   case 4:keyon+=8;break;
  41.      case 8:keyon+=12;break;
  42. }
  43. return keyon;
  44. }
  45. void main()
  46. { SCON=0x50;   //串口模式 1,允许接收
  47. TMOD=0x20;  //T1 工作模式2
  48. PCON=0x00;   //波特率不倍增
  49. TH1=0xfd;     //波特率设定: 9600
  50. TL1=0xfd;
  51.     TI=RI=0;
  52.    TR1=1;   //启动定时器T1
  53. IE=0x90;     //允许串口中断
  54.   delay(100);
  55.   while(1)
  56. { P2=0xf0;    //矩阵键盘
  57. if(P2!=0xf0)
  58.   send(key());
  59. if(KEY2==0)    //清零
  60.       send('y');
  61.   }
  62. }
  63. void serial_int() interrupt 4  //乙机串口接收中断函数
  64. { if(RI)
  65.   { RI=0;
  66.    switch(SBUF)
  67.    { case '0':L0=0;break;
  68.     case '1':L1=0;break;
  69.     case '2':L2=0;break;
  70.     case '3':L3=0;break;
  71.     case '4':L4=0;break;
  72.     case '5':L5=0;break;
  73.     case '6':L6=0;break;
  74.     case '7':L7=0;break;
  75.     case 'A':L0=1;break;
  76.     case 'B':L1=1;break;
  77.     case 'C':L2=1;break;
  78.     case 'D':L3=1;break;
  79.     case 'E':L4=1;break;
  80.     case 'F':L5=1;break;
  81.     case 'G':L6=1;break;
  82.     case 'H':L7=1;break;
  83.    }
  84. }
  85. }
  86.
ID:120646 发表于 2016-5-13 23:47 | 显示全部楼层
51黑有你更精彩!!!
ID:120661 发表于 2016-5-14 07:28 | 显示全部楼层
如果给百度云连接就好了
ID:99525 发表于 2016-5-14 12:14 | 显示全部楼层
楼上广告发错地方了,发到STM那边去
ID:88498 发表于 2016-6-13 17:53 | 显示全部楼层
51黑有你更精彩!!!
ID:146892 发表于 2016-11-8 20:04 | 显示全部楼层
谢谢楼主分享!
ID:379864 发表于 2018-7-27 16:07 | 显示全部楼层
51有你更精彩
