查看: 5700|回复: 5
怎样用at89c51同时使用lcd1602和数码管
ID:425189 发表于 2018-11-12 18:28 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
ID:425189 发表于 2018-11-16 12:40 | 只看该作者
我代码如下:
        #include<reg51.h>
unsigned         char  tab[]="  23:58:48";
unsigned         char         code         tab2[]="SZ30329 ";
#define lcdp P0
sbit rs=P3^5;
sbit rw=P3^6;
sbit en=P3^7;
sbit led=P1^7;
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
   sbit  RED=P3^4;
   unsigned   s=2;
   unsigned  flag=0;
unsigned         char n,count,number;
char         shi=23,fen=58,miao=55;
void delay(unsigned char z)
        unsigned char i,j;
        for(i=z;i>0;i--)
                for(j=110;j>0;j--);
}           //延时
void  time_gai()
if(count==0)
s--;
void write_com(unsigned char com)//写指令
        rs=0;
        rw=0;
        en=0;
        lcdp=com;
        delay(5);
        en=1;
        delay(5);
        en=0;
void write_date(unsigned char date)//写数据
        rs=1;
        rw=0;
        en=0;
        lcdp=date;
        delay(5);
        en=1;
        delay(5);
        en=0;
void write_sj(unsigned add,unsigned date)
        unsigned char shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+add);
        write_date(shi+0x30);
        write_date(ge+0x30);
void init()        //初始化
        write_com(0x38);          //设置16x2显示,5x7点阵,8位数据接口
        write_com(0x06);        //写一个字符后地址指针自动加1
        write_com(0x01);        //显示清零,数据指针清零
        write_com(0x0c);        //开显示,不显示光标
        //write_com(0x08);
        //write_com(0x0e);//光标开启,但不闪烁
        write_com(0x80);        //显示位置
        for(n=0;n<10;n++)
                write_date(tab[n]);
                delay(1);
        write_com(0x80+0x40+3);//第二行显示
        for(n=0;n<8;n++)
                write_date(tab2[n]);
                delay(1);
        //定时器初始化
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
void keyscan()
        if(s1==0)
                delay(5);
                if(s1==0)
                        number++;
                        while(!s1);
        if(number==1)
                TR0=0;
                write_com(0x80+9);
                write_com(0x0f);//光标闪烁
        if(number==2)
                write_com(0x80+6);
        if(number==3)
                write_com(0x80+3);
        if(number==4)
                TR0=1;
                number=0;
                write_com(0x0c);//关闭光标
        if(number!=0)
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                while(!s2);
                                if(number==1)
                                        miao++;
                                        if(miao==60)
                                                  miao=0;
                                        write_sj(8,miao);
                                        write_com(0x80+9);
                                if(number==2)
                                        fen++;
                                        if(fen==60)
                                                fen=0;
                                        write_sj(5,fen);
                                        write_com(0x80+6);
                                if(number==3)
                                        shi++;
                                        led=!led;
                                        if(shi==24)
                                                shi=0;
                                        write_sj(2,shi);
                                        write_com(0x80+3);
                if(s3==0)
                        delay(5);
                        if(s3==0)
                                while(!s3);
                                if(number==1)
                                        miao--;
                                        if(miao==-1)
                                                  miao=59;
                                        write_sj(8,miao);
                                        write_com(0x80+9);
                                if(number==2)
                                        fen--;
                                        if(fen==-1)
                                                fen=59;
                                        write_sj(5,fen);
                                        write_com(0x80+6);
                                if(number==3)
                                        shi--;
                                        led=!led;
                                        if(shi==-1)
                                                shi=23;
                                        write_sj(2,shi);
                                        write_com(0x80+3);
         RED=0;
        init();
                 keyscan();
void time0() interrupt 1
        count++;
        if(count==20)
                count=0;
                miao++;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)
                                        shi=0;
                                write_sj(2,shi);
                        write_sj(5,fen);
                write_sj(8,miao);
想加个倒计时秒表,四分钟(不用调的),按下开关就工作,求大神帮写下程序
ID:422467 发表于 2018-11-15 21:41 | 只看该作者
串口通信
ID:425189 发表于 2018-11-15 21:28 来自触屏版 | 只看该作者
123456m 发表于 2018-11-15 17:58
32个I/O可以或动态显示也可以或加芯片逻辑芯片
已经设计了lcd时钟,数码管代码无法实现啊
ID:316332 发表于 2018-11-15 17:58 | 只看该作者
ID:111634 发表于 2018-11-14 08:30 | 只看该作者
把2个案例拼起来
