查看: 2553|回复: 0
C语言程序为什么我的第二个if里的语句无法实现?只能产生一个pwm波
ID:543151 发表于 2019-7-18 16:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5黑币
#include <reg51.h>
#include <intrins.h>
#include <delay.h>
// sbit  EN1=P3^0;
// sbit  IN1=P3^1;
sbit  IN2=P2^0;
  sbit   IN1=P2^1;
sfr  AUXR       =   0x8e;
#define FOSC    11059200L
#define BAUD    9600
typedef unsigned char BYTE;
typedef unsigned int WORD;
unsigned char x,y;
uchar t=0;
void Timer0Init(void);
void InitADC();
BYTE GetADCResult(BYTE ch);
void ShowResult();
void Delay(WORD n);
uchar count=0;
sfr T2H   = 0xd6;               //???2?8?
sfr T2L   = 0xd7;               //???2?8?
sfr ADC_CONTR   =   0xBC;           //ADC?????
sfr ADC_RES     =   0xBD;           //ADC?8???
sfr ADC_LOW2    =   0xBE;           //ADC?2???
sfr P1ASF       =   0x9D;           //P1??2???????
#define ADC_POWER   0x80            //ADC?????
#define ADC_FLAG    0x10            //ADC????
#define ADC_START   0x08            //ADC?????
#define ADC_SPEEDLL 0x00            //540???
#define ADC_SPEEDL  0x20            //360???
#define ADC_SPEEDH  0x40            //180???
#define ADC_SPEEDHH 0x60
??ADC???PC
void ShowResult()
  x=GetADCResult(1);
// k=GetADCResult(7);
//    SendData(ADC_LOW2);           //???2???
??ADC??
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START;
    _nop_();                        //??4?NOP
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & ADC_FLAG));//??ADC????
    ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    return ADC_RES;                 //??ADC??
void InitADC()
    P1ASF = 0xff;                   //??P1??AD?
    ADC_RES = 0;                    //???????
    ADC_CONTR = ADC_POWER | ADC_SPEEDLL;
    Delay(2);                       //ADC?????
void Delay(WORD n)
    WORD N;
    while (n--)
        N = 5000;
        while (N--);
void Timer0Init(void)  //100??@11.0592MHz
AUXR |= 0x80;  //?????1T??
TMOD &= 0xF0;  //???????
TL0 = 0xAE;  //??????
TH0 = 0xFB;  //??????
TF0 = 0;  //??TF0??
TR0 = 1;  //???0????
  EA=1;
void tiii () interrupt 1
count++;
if(count==t)
    IN2=~IN2;
  if(count==200)
    IN2=~IN2;
   count=0;
InitADC();
Timer0Init();
  x=GetADCResult(1);
P0=x;
  if(x>=200)
   t=15;
   ET0=1;
   else if(x<=50)
   t=25;
   ET0=1;
     ET0=0;
