查看: 4359|回复: 0
EDA设计 Quartus在点阵电路上实现循环显示HELLO
ID:639016 发表于 2019-11-10 10:53 | 显示全部楼层 |阅读模式
●  在点阵电路上实现循环显示HELLO
●  先显示H,再显示E,……依次循环
●  可以自定义添加状态
  1. HEADER
  2. {
  3.         VERSION = 1;
  4.         TIME_UNIT = ns;
  5.         DATA_OFFSET = 0.0;
  6.         DATA_DURATION = 1000000.0;
  7.         SIMULATION_TIME = 0.0;
  8.         GRID_PHASE = 0.0;
  9.         GRID_PERIOD = 100.0;
  10.         GRID_DUTY_CYCLE = 50;
  11. }
  12. SIGNAL("C1")
  13. {
  14.         VALUE_TYPE = NINE_LEVEL_BIT;
  15.         SIGNAL_TYPE = SINGLE_BIT;
  16.         WIDTH = 1;
  17.         LSB_INDEX = -1;
  18.         DIRECTION = INPUT;
  19.         PARENT = "";
  20. }
  21. SIGNAL("C2")
  22. {
  23.         VALUE_TYPE = NINE_LEVEL_BIT;
  24.         SIGNAL_TYPE = SINGLE_BIT;
  25.         WIDTH = 1;
  26.         LSB_INDEX = -1;
  27.         DIRECTION = INPUT;
  28.         PARENT = "";
  29. }
  30. SIGNAL("1")
  31. {
  32.         VALUE_TYPE = NINE_LEVEL_BIT;
  33.         SIGNAL_TYPE = SINGLE_BIT;
  34.         WIDTH = 1;
  35.         LSB_INDEX = -1;
  36.         DIRECTION = OUTPUT;
  37.         PARENT = "";
  38. }
  39. SIGNAL("2")
  40. {
  41.         VALUE_TYPE = NINE_LEVEL_BIT;
  42.         SIGNAL_TYPE = SINGLE_BIT;
  43.         WIDTH = 1;
  44.         LSB_INDEX = -1;
  45.         DIRECTION = OUTPUT;
  46.         PARENT = "";
  47. }
  48. SIGNAL("3")
  49. {
  50.         VALUE_TYPE = NINE_LEVEL_BIT;
  51.         SIGNAL_TYPE = SINGLE_BIT;
  52.         WIDTH = 1;
  53.         LSB_INDEX = -1;
  54.         DIRECTION = OUTPUT;
  55.         PARENT = "";
  56. }
  57. SIGNAL("4")
  58. {
  59.         VALUE_TYPE = NINE_LEVEL_BIT;
  60.         SIGNAL_TYPE = SINGLE_BIT;
  61.         WIDTH = 1;
  62.         LSB_INDEX = -1;
  63.         DIRECTION = OUTPUT;
  64.         PARENT = "";
  65. }
  66. SIGNAL("A")
  67. {
  68.         VALUE_TYPE = NINE_LEVEL_BIT;
  69.         SIGNAL_TYPE = SINGLE_BIT;
  70.         WIDTH = 1;
  71.         LSB_INDEX = -1;
  72.         DIRECTION = OUTPUT;
  73.         PARENT = "";
  74. }
  75. SIGNAL("B")
  76. {
  77.         VALUE_TYPE = NINE_LEVEL_BIT;
  78.         SIGNAL_TYPE = SINGLE_BIT;
  79.         WIDTH = 1;
  80.         LSB_INDEX = -1;
  81.         DIRECTION = OUTPUT;
  82.         PARENT = "";
  83. }
  84. SIGNAL("C")
  85. {
  86.         VALUE_TYPE = NINE_LEVEL_BIT;
  87.         SIGNAL_TYPE = SINGLE_BIT;
  88.         WIDTH = 1;
  89.         LSB_INDEX = -1;
  90.         DIRECTION = OUTPUT;
  91.         PARENT = "";
  92. }
  93. SIGNAL("D")
  94. {
  95.         VALUE_TYPE = NINE_LEVEL_BIT;
  96.         SIGNAL_TYPE = SINGLE_BIT;
  97.         WIDTH = 1;
  98.         LSB_INDEX = -1;
  99.         DIRECTION = OUTPUT;
  100.         PARENT = "";
  101. }
  102. SIGNAL("L1")
  103. {
  104.         VALUE_TYPE = NINE_LEVEL_BIT;
  105.         SIGNAL_TYPE = SINGLE_BIT;
  106.         WIDTH = 1;
  107.         LSB_INDEX = -1;
  108.         DIRECTION = OUTPUT;
  109.         PARENT = "";
  110. }
  111. SIGNAL("L2")
  112. {
  113.         VALUE_TYPE = NINE_LEVEL_BIT;
  114.         SIGNAL_TYPE = SINGLE_BIT;
  115.         WIDTH = 1;
  116.         LSB_INDEX = -1;
  117.         DIRECTION = OUTPUT;
  118.         PARENT = "";
  119. }
  120. SIGNAL("L3")
  121. {
  122.         VALUE_TYPE = NINE_LEVEL_BIT;
  123.         SIGNAL_TYPE = SINGLE_BIT;
  124.         WIDTH = 1;
  125.         LSB_INDEX = -1;
  126.         DIRECTION = OUTPUT;
  127.         PARENT = "";
  128. }
  129. SIGNAL("L5")
  130. {
  131.         VALUE_TYPE = NINE_LEVEL_BIT;
  132.         SIGNAL_TYPE = SINGLE_BIT;
  133.         WIDTH = 1;
  134.         LSB_INDEX = -1;
  135.         DIRECTION = OUTPUT;
  136.         PARENT = "";
  137. }
  138. SIGNAL("L6")
  139. {
  140.         VALUE_TYPE = NINE_LEVEL_BIT;
  141.         SIGNAL_TYPE = SINGLE_BIT;
  142.         WIDTH = 1;
  143.         LSB_INDEX = -1;
  144.         DIRECTION = OUTPUT;
  145.         PARENT = "";
  146. }
  147. SIGNAL("L8")
  148. {
  149.         VALUE_TYPE = NINE_LEVEL_BIT;
  150.         SIGNAL_TYPE = SINGLE_BIT;
  151.         WIDTH = 1;
  152.         LSB_INDEX = -1;
  153.         DIRECTION = OUTPUT;
  154.         PARENT = "";
  155. }
  156. SIGNAL("L9")
  157. {
  158.         VALUE_TYPE = NINE_LEVEL_BIT;
  159.         SIGNAL_TYPE = SINGLE_BIT;
  160.         WIDTH = 1;
  161.         LSB_INDEX = -1;
  162.         DIRECTION = OUTPUT;
  163.         PARENT = "";
  164. }
  165. SIGNAL("L11")
  166. {
  167.         VALUE_TYPE = NINE_LEVEL_BIT;
  168.         SIGNAL_TYPE = SINGLE_BIT;
  169.         WIDTH = 1;
  170.         LSB_INDEX = -1;
  171.         DIRECTION = OUTPUT;
  172.         PARENT = "";
  173. }
  174. SIGNAL("L12")
  175. {
  176.         VALUE_TYPE = NINE_LEVEL_BIT;
  177.         SIGNAL_TYPE = SINGLE_BIT;
  178.         WIDTH = 1;
  179.         LSB_INDEX = -1;
  180.         DIRECTION = OUTPUT;
  181.         PARENT = "";
  182. }
  183. SIGNAL("L14")
  184. {
  185.         VALUE_TYPE = NINE_LEVEL_BIT;
  186.         SIGNAL_TYPE = SINGLE_BIT;
  187.         WIDTH = 1;
  188.         LSB_INDEX = -1;
  189.         DIRECTION = OUTPUT;
  190.         PARENT = "";
  191. }
  192. SIGNAL("L15")
  193. {
  194.         VALUE_TYPE = NINE_LEVEL_BIT;
  195.         SIGNAL_TYPE = SINGLE_BIT;
  196.         WIDTH = 1;
  197.         LSB_INDEX = -1;
  198.         DIRECTION = OUTPUT;
  199.         PARENT = "";
  200. }
  201. SIGNAL("L16")
  202. {
  203.         VALUE_TYPE = NINE_LEVEL_BIT;
  204.         SIGNAL_TYPE = SINGLE_BIT;
  205.         WIDTH = 1;
  206.         LSB_INDEX = -1;
  207.         DIRECTION = OUTPUT;
  208.         PARENT = "";
  209. }
  210. SIGNAL("L4")
  211. {
  212.         VALUE_TYPE = NINE_LEVEL_BIT;
  213.         SIGNAL_TYPE = SINGLE_BIT;
  214.         WIDTH = 1;
  215.         LSB_INDEX = -1;
  216.         DIRECTION = OUTPUT;
  217.         PARENT = "";
  218. }
  219. SIGNAL("L7")
  220. {
  221.         VALUE_TYPE = NINE_LEVEL_BIT;
  222.         SIGNAL_TYPE = SINGLE_BIT;
  223.         WIDTH = 1;
  224.         LSB_INDEX = -1;
  225.         DIRECTION = OUTPUT;
  226.         PARENT = "";
  227. }
  228. SIGNAL("L10")
  229. {
  230.         VALUE_TYPE = NINE_LEVEL_BIT;
  231.         SIGNAL_TYPE = SINGLE_BIT;
  232.         WIDTH = 1;
  233.         LSB_INDEX = -1;
  234.         DIRECTION = OUTPUT;
  235.         PARENT = "";
  236. }
  237. SIGNAL("L13")
  238. {
  239.         VALUE_TYPE = NINE_LEVEL_BIT;
  240.         SIGNAL_TYPE = SINGLE_BIT;
  241.         WIDTH = 1;
  242.         LSB_INDEX = -1;
  243.         DIRECTION = OUTPUT;
  244.         PARENT = "";
  245. }
  246. TRANSITION_LIST("C1")
  247. {
  248.         NODE
  249.         {
  250.                 REPEAT = 1;
  251.                 NODE
  252.                 {
  253.                         REPEAT = 100000;
  254.                         LEVEL 0 FOR 5.0;
  255.                         LEVEL 1 FOR 5.0;
  256.                 }
  257.         }
  258. }
  259. TRANSITION_LIST("C2")
  260. {
  261.         NODE
  262.         {
  263.                 REPEAT = 1;
  264.                 NODE
  265.                 {
  266.                         REPEAT = 3125;
  267.                         LEVEL 0 FOR 160.0;
  268.                         LEVEL 1 FOR 160.0;
  269.                 }
  270.         }
  271. }
  272. TRANSITION_LIST("1")
  273. {
  274.         NODE
  275.         {
  276.                 REPEAT = 1;
  277.                 LEVEL X FOR 1000000.0;
  278.         }
  279. }
  280. TRANSITION_LIST("2")
  281. {
  282.         NODE
  283.         {
  284.                 REPEAT = 1;
  285.                 LEVEL X FOR 1000000.0;
  286.         }
  287. }
  288. TRANSITION_LIST("3")
  289. {
  290.         NODE
  291.         {
  292.                 REPEAT = 1;
  293.                 LEVEL X FOR 1000000.0;
  294.         }
  295. }
  296. TRANSITION_LIST("4")
  297. {
  298.         NODE
  299.         {
  300.                 REPEAT = 1;
  301.                 LEVEL X FOR 1000000.0;
  302.         }
  303. }
  304. TRANSITION_LIST("A")
  305. {
  306.         NODE
  307.         {
  308.                 REPEAT = 1;
  309.                 LEVEL X FOR 1000000.0;
  310.         }
  311. }
  312. TRANSITION_LIST("B")
  313. {
  314.         NODE
  315.         {
  316.                 REPEAT = 1;
  317.                 LEVEL X FOR 1000000.0;
  318.         }
  319. }
  320. TRANSITION_LIST("C")
  321. {
  322.         NODE
  323.         {
  324.                 REPEAT = 1;
  325.                 LEVEL X FOR 1000000.0;
  326.         }
  327. }
  328. TRANSITION_LIST("D")
  329. {
  330.         NODE
  331.         {
  332.                 REPEAT = 1;
  333.                 LEVEL X FOR 1000000.0;
  334.         }
  335. }
  336. TRANSITION_LIST("L1")
  337. {
  338.         NODE
  339.         {
  340.                 REPEAT = 1;
  341.                 LEVEL X FOR 1000000.0;
  342.         }
  343. }
  344. TRANSITION_LIST("L2")
  345. {
  346.         NODE
  347.         {
  348.                 REPEAT = 1;
  349.                 LEVEL X FOR 1000000.0;
  350.         }
  351. }
  352. TRANSITION_LIST("L3")
  353. {
  354.         NODE
  355.         {
  356.                 REPEAT = 1;
  357.                 LEVEL X FOR 1000000.0;
  358.         }
  359. }
  360. TRANSITION_LIST("L5")
  361. {
  362.         NODE
  363.         {
  364.                 REPEAT = 1;
  365.                 LEVEL X FOR 1000000.0;
  366.         }
  367. }
  368. TRANSITION_LIST("L6")
  369. {
  370.         NODE
  371.         {
  372.                 REPEAT = 1;
  373.                 LEVEL X FOR 1000000.0;
  374.         }
  375. }
  376. TRANSITION_LIST("L8")
  377. {
  378.         NODE
  379.         {
  380.                 REPEAT = 1;
  381.                 LEVEL X FOR 1000000.0;
  382.         }
  383. }
  384. TRANSITION_LIST("L9")
  385. {
  386.         NODE
  387.         {
  388.                 REPEAT = 1;
  389.                 LEVEL X FOR 1000000.0;
  390.         }
  391. }
  392. TRANSITION_LIST("L11")
  393. {
  394.         NODE
  395.         {
  396.                 REPEAT = 1;
  397.                 LEVEL X FOR 1000000.0;
  398.         }
  399. }
  400. TRANSITION_LIST("L12")
  401. {
  402.         NODE
  403.         {
  404.                 REPEAT = 1;
  405.                 LEVEL X FOR 1000000.0;
  406.         }
  407. }
  408. TRANSITION_LIST("L14")
  409. {
  410.         NODE
  411.         {
  412.                 REPEAT = 1;
  413.                 LEVEL X FOR 1000000.0;
  414.         }
  415. }
  416. TRANSITION_LIST("L15")
  417. {
  418.         NODE
  419.         {
  420.                 REPEAT = 1;
  421.                 LEVEL X FOR 1000000.0;
  422.         }
  423. }
  424. TRANSITION_LIST("L16")
  425. {
  426.         NODE
  427.         {
  428.                 REPEAT = 1;
  429.                 LEVEL X FOR 1000000.0;
  430.         }
  431. }
  432. TRANSITION_LIST("L4")
  433. {
  434.         NODE
  435.         {
  436.                 REPEAT = 1;
  437.                 LEVEL X FOR 1000000.0;
  438.         }
  439. }
  440. TRANSITION_LIST("L7")
  441. {
  442.         NODE
  443.         {
  444.                 REPEAT = 1;
  445.                 LEVEL X FOR 1000000.0;
  446.         }
  447. }
  448. TRANSITION_LIST("L10")
  449. {
  450.         NODE
  451.         {
  452.                 REPEAT = 1;
  453.                 LEVEL X FOR 1000000.0;
  454.         }
  455. }
  456. TRANSITION_LIST("L13")
  457. {
  458.         NODE
  459.         {
  460.                 REPEAT = 1;
  461.                 LEVEL X FOR 1000000.0;
  462.         }
  463. }
  464. DISPLAY_LINE
  465. {
  466.         CHANNEL = "C1";
  467.         EXPAND_STATUS = COLLAPSED;
  468.         RADIX = ASCII;
  469.         TREE_INDEX = 0;
  470.         TREE_LEVEL = 0;
  471. }
  472. DISPLAY_LINE
  473. {
  474.         CHANNEL = "C2";
  475.         EXPAND_STATUS = COLLAPSED;
  476.         RADIX = ASCII;
  477.         TREE_INDEX = 1;
  478.         TREE_LEVEL = 0;
  479. }
  480. DISPLAY_LINE
  481. {
  482.         CHANNEL = "1";
  483.         EXPAND_STATUS = COLLAPSED;
  484.         RADIX = ASCII;
  485.         TREE_INDEX = 2;
  486.         TREE_LEVEL = 0;
  487. }
  488. DISPLAY_LINE
  489. {
  490.         CHANNEL = "2";
  491.         EXPAND_STATUS = COLLAPSED;
  492.         RADIX = ASCII;
  493.         TREE_INDEX = 3;
  494.         TREE_LEVEL = 0;
  495. }
  496. DISPLAY_LINE
  497. {
  498.         CHANNEL = "3";
  499.         EXPAND_STATUS = COLLAPSED;
  500.         RADIX = ASCII;
  501.         TREE_INDEX = 4;
  502.         TREE_LEVEL = 0;
  503. }
  504. DISPLAY_LINE
  505. {
  506.         CHANNEL = "4";
  507.         EXPAND_STATUS = COLLAPSED;
  508.         RADIX = ASCII;
  509.         TREE_INDEX = 5;
  510.         TREE_LEVEL = 0;
  511. }
  512. DISPLAY_LINE
  513. {
  514.         CHANNEL = "A";
  515.         EXPAND_STATUS = COLLAPSED;
  516.         RADIX = ASCII;
  517.         TREE_INDEX = 6;
  518.         TREE_LEVEL = 0;
  519. }
  520. DISPLAY_LINE
  521. {
  522.         CHANNEL = "B";
  523.         EXPAND_STATUS = COLLAPSED;
  524.         RADIX = ASCII;
  525.         TREE_INDEX = 7;
  526.         TREE_LEVEL = 0;
  527. }
  528. DISPLAY_LINE
  529. {
  530.         CHANNEL = "C";
  531.         EXPAND_STATUS = COLLAPSED;
  532.         RADIX = ASCII;
  533.         TREE_INDEX = 8;
  534.         TREE_LEVEL = 0;
  535. }
  536. DISPLAY_LINE
  537. {
  538.         CHANNEL = "D";
  539.         EXPAND_STATUS = COLLAPSED;
  540.         RADIX = ASCII;
  541.         TREE_INDEX = 9;
  542.         TREE_LEVEL = 0;
  543. }
  544. DISPLAY_LINE
  545. {
  546.         CHANNEL = "L1";
  547.         EXPAND_STATUS = COLLAPSED;
  548.         RADIX = ASCII;
  549.         TREE_INDEX = 10;
  550.         TREE_LEVEL = 0;
  551. }
  552. DISPLAY_LINE
  553. {
  554.         CHANNEL = "L2";
  555.         EXPAND_STATUS = COLLAPSED;
  556.         RADIX = ASCII;
  557.         TREE_INDEX = 11;
  558.         TREE_LEVEL = 0;
  559. }
  560. DISPLAY_LINE
  561. {
  562.         CHANNEL = "L3";
  563.         EXPAND_STATUS = COLLAPSED;
  564.         RADIX = ASCII;
  565.         TREE_INDEX = 12;
  566.         TREE_LEVEL = 0;
  567. }
  568. DISPLAY_LINE
  569. {
  570.         CHANNEL = "L5";
  571.         EXPAND_STATUS = COLLAPSED;
  572.         RADIX = ASCII;
  573.         TREE_INDEX = 13;
  574.         TREE_LEVEL = 0;
  575. }
  576. DISPLAY_LINE
  577. {
  578.         CHANNEL = "L6";
  579.         EXPAND_STATUS = COLLAPSED;
  580.         RADIX = ASCII;
  581.         TREE_INDEX = 14;
  582.         TREE_LEVEL = 0;
  583. }
  584. DISPLAY_LINE
  585. {
  586.         CHANNEL = "L8";
  587.         EXPAND_STATUS = COLLAPSED;
  588.         RADIX = ASCII;
  589.         TREE_INDEX = 15;
  590.         TREE_LEVEL = 0;
  591. }
  592. DISPLAY_LINE
  593. {
  594.         CHANNEL = "L9";
  595.         EXPAND_STATUS = COLLAPSED;
  596.         RADIX = ASCII;
  597.         TREE_INDEX = 16;
  598.         TREE_LEVEL = 0;
  599. }
  600. DISPLAY_LINE
  601. {
  602.         CHANNEL = "L11";
  603.         EXPAND_STATUS = COLLAPSED;
  604.         RADIX = ASCII;
  605.         TREE_INDEX = 17;
  606.         TREE_LEVEL = 0;
  607. }
  608. DISPLAY_LINE
  609. {
  610.         CHANNEL = "L12";
  611.         EXPAND_STATUS = COLLAPSED;
  612.         RADIX = ASCII;
  613.         TREE_INDEX = 18;
  614.         TREE_LEVEL = 0;
  615. }
  616. DISPLAY_LINE
  617. {
  618.         CHANNEL = "L14";
  619.         EXPAND_STATUS = COLLAPSED;
  620.         RADIX = ASCII;
  621.         TREE_INDEX = 19;
  622.         TREE_LEVEL = 0;
  623. }
  624. DISPLAY_LINE
  625. {
  626.         CHANNEL = "L15";
  627.         EXPAND_STATUS = COLLAPSED;
  628.         RADIX = ASCII;
  629.         TREE_INDEX = 20;
  630.         TREE_LEVEL = 0;
  631. }
  632. DISPLAY_LINE
  633. {
  634.         CHANNEL = "L16";
  635.         EXPAND_STATUS = COLLAPSED;
  636.         RADIX = ASCII;
  637.         TREE_INDEX = 21;
  638.         TREE_LEVEL = 0;
  639. }
  640. DISPLAY_LINE
  641. {
  642.         CHANNEL = "L4";
  643.         EXPAND_STATUS = COLLAPSED;
  644.         RADIX = ASCII;
  645.         TREE_INDEX = 22;
  646.         TREE_LEVEL = 0;
  647. }
  648. DISPLAY_LINE
  649. {
  650.         CHANNEL = "L7";
  651.         EXPAND_STATUS = COLLAPSED;
  652.         RADIX = ASCII;
  653.         TREE_INDEX = 23;
  654.         TREE_LEVEL = 0;
  655. }
  656. DISPLAY_LINE
  657. {
  658.         CHANNEL = "L10";
  659.         EXPAND_STATUS = COLLAPSED;
  660.         RADIX = ASCII;
  661.         TREE_INDEX = 24;
  662.         TREE_LEVEL = 0;
  663. }
  664. DISPLAY_LINE
  665. {
  666.         CHANNEL = "L13";
  667.         EXPAND_STATUS = COLLAPSED;
  668.         RADIX = ASCII;
  669.         TREE_INDEX = 25;
  670.         TREE_LEVEL = 0;
  671. }
  672. TIME_BAR
  673. {
  674.         TIME = 0;
  675.         MASTER = TRUE;
  676. }
  677. ;
全部资料51hei下载地址:
EDA.zip (1.16 MB, 下载次数: 14)
