查看: 4401|回复: 0
基于MSP430单片机的可调恒流源Proteus仿真程序设计
* 实验说明:
*     通设置系统主时钟(MCLK=8Mhz ) 、辅助时钟(ACLK=8Mhz )、
*      子系统时钟(SMCLK=8Mhz )
#include <MSP430x24x.h>
#include <string.h>
/**************定义接口************************/
#define LCDIO     P1OUT
#define LCD1602_RS_1  P2OUT|=1
#define LCD1602_RS_0  P2OUT&=~1
#define LCD1602_EN_1   P2OUT|=2
#define LCD1602_EN_0   P2OUT&=~2
#define PWM_1   P2OUT|=8
#define PWM_0   P2OUT&=~8
/**************定义函数************************/
void LCD_write_command(unsigned char command);//写入指令函数
void LCD_write_dat( unsigned char dat);//写入数据函数
void LCD_set_xy( unsigned char x, unsigned char y );//设置显示位置函数
void LCD_dsp_char( unsigned char x,unsigned char y, char dat);//显示一个字符函数
void LCD_dsp_string(unsigned char X,unsigned char Y,const char *s);//显示字符串函数
void LCD_init(void);//初始化函数
void delay_nms(unsigned int n);//延时函数
void TCL5615_DAC(unsigned int Data);
//变量定义
unsigned char Disbuf[12],flag;
int DAC_num = 5;
unsigned char KEY_OPEN_OR_STOP_times = 1;
//ADC采集函数
void RefreshDis0(unsigned int Data0)
  if( Data0 < 10 )
    Disbuf[0] = 0x30 + Data0/100%10;
    Disbuf[1] = '.';
    Disbuf[2] = 0x30 + Data0/10%10;
    Disbuf[3] = 0x30 + Data0%10;
    Disbuf[4] = 'V';
    Disbuf[1] = '.';
    Disbuf[4] = 'V';
//ADC采集函数
void RefreshDis1(unsigned int Data1)
    Disbuf[5] = 0x30 + Data1/100%10;
    Disbuf[6] = 0x30 + Data1/10%10;
    Disbuf[7] = 0x30 + Data1%10;
    Disbuf[8] = 0x30;
    Disbuf[9] = 'm';
    Disbuf[10] = 'A';
void P23_Onclick( void )
  //50mA
   DAC_num = DAC_num + 10;
   if( DAC_num > 420 )
     DAC_num = 420;
    TCL5615_DAC( DAC_num );                      //205 对应1.0V    410  对应2.0V   5---20mA
void P24_Onclick( void )
  //50mA
   DAC_num = DAC_num - 10;
   if( DAC_num < 5 )
     DAC_num = 5;
void P25_Onclick( void )
    DAC_num = 5;
void P26_Onclick( void )
  //10mA
   DAC_num = DAC_num + 2;
   if( DAC_num > 420 )
     DAC_num = 420;
void P27_Onclick( void )
    //10mA
   DAC_num = DAC_num - 2;
   if( DAC_num < 5 )
     DAC_num = 5;
//电压显示函数
void Display( void )
    LCD_write_command( 0x80 );
    LCD_write_dat('V');
    LCD_write_dat(':');
    LCD_write_dat( Disbuf[0] );
    LCD_write_dat( Disbuf[1] );
    LCD_write_dat( Disbuf[2] );
    LCD_write_dat( Disbuf[3] );
    LCD_write_dat( Disbuf[4] );
    LCD_write_dat( ' ' );
    LCD_write_dat('I');
    LCD_write_dat(':');
    if( Disbuf[5] != 0x30 )
      LCD_write_dat( Disbuf[5] );
    if( Disbuf[6] != 0x30 )
      LCD_write_dat( Disbuf[6] );
    LCD_write_dat( Disbuf[7] );
    LCD_write_dat( Disbuf[8] );
    LCD_write_dat( Disbuf[9] );
    LCD_write_dat( Disbuf[10] );
void Display_Set( void )
   LCD_write_command( 0x80 + 0x40 );
   LCD_write_dat( 'S' );
   LCD_write_dat( 'e' );
   LCD_write_dat( 't' );
   LCD_write_dat( ':' );
   if( KEY_OPEN_OR_STOP_times == 1 )
     LCD_write_dat( 'O' );
     LCD_write_dat( 'P' );
     LCD_write_dat( 'E' );
     LCD_write_dat( 'N' );
   if( KEY_OPEN_OR_STOP_times == 2 )
     LCD_write_dat( 'T' );
/*******延时函数************/
void delayms(uint t)
    uint i;
    while(t--)
      for(i=1330;i>0;i--);//进过参数的调整
/*******检查忙函数*************/
void LCD_check_busy()      //实践证明,在我的LCD1602上,检查忙指令通过率极低,以
{                                          //至于不能正常使用LCD。因此我没有再用检查忙函数。而使
        P1DIR=0x00;
        LCDIO=0xff;
        LCD1602_RS_0;                 //要用200次循环便能完成。
        LCD1602_EN_1;
        while(P1IN&0x80);
        LCD1602_EN_0;
        P1OUT=0x00;
        P1DIR=0xFF;
/**************写指令函数********************************/
        LCD1602_RS_0;
        LCDIO=command;
        LCD1602_EN_1;
        LCD1602_EN_0;
        delayms(1);
/****************写数据函数************************/
      LCD1602_RS_1;
      LCDIO=dat;
      LCD1602_EN_1;
      LCD1602_EN_0;
      delayms(1);
      LCD1602_RS_0;
/***************设置显示位置**************************/
        unsigned char address;
        if (y == 1)
             address = 0x80+x;
        else if (y == 2)
               address=0x80+0x40+x;
        LCD_write_command(address);
/****************显示一个字符**********************/
        LCD_set_xy( x, y );
        LCD_write_dat(dat);
/***************显示字符串函数***************/
       uchar len,List;
       len=strlen(s);
       LCD_set_xy( X, Y );
       for(List=0;List<len;List++)
       LCD_write_dat(s[List]);
/********** 延时**********************/
       unsigned int i=0,j=0;
       for (i=n;i>0;i--)
       for (j=0;j<1;j++);
/************初始化函数****************/
void LCD_init(void)
      LCD1602_EN_0;
      //CLEARSCREEN;//clear screen
      LCD_write_command(0x38);//set 8 bit data transmission mode
      delayms(1);
      delayms(1);
      delayms(1);
      LCD_write_command(0x06);//open display (enable lcd display)
      delayms(1);
      LCD_write_command(0x0C);//set lcd first display address
      delayms(1);
      LCD_write_command(0x01);//clear screen
      delayms(1);
      LCD_dsp_string(1,1,"  LCD TEST   ");//在第一行第一列显示"LCD TEST"
      LCD_dsp_string(1,2,"  SUCCSEEE!  ");//在第一行第一列显示"LCD TEST"
      delayms(500);
      delayms(1);
//ADC
#define ADCST0          P5OUT &= ~BIT4
#define ADCST1         P5OUT |= BIT4
#define ADCALE0         P5OUT &= ~BIT5
#define ADCALE1         P5OUT |= BIT5
#define ADCEOC0         P5OUT &= ~BIT6
#define ADCEOC1         P5OUT |= BIT6
#define ADCOE0          P5OUT &= ~BIT7
#define ADCOE1          P5OUT |= BIT7
#define LED_0          P5OUT &= ~BIT3
#define LED_1          P5OUT |= BIT3
unsigned int  ADC1;
void ADC_START(void)
  ADCALE1;
  ADCST1;
  delayms(1);
   ADCALE0;
  ADCST0;
   delayms(1);
char ADC_READ()
  uchar data;
   data=0x00;
   delayms(1);
   ADCOE1;
  ADC_START();
   delayms(5);
  data=P4IN;
   ADCOE0;
  return data;
// DAC
#define SET_DIN   do{P3OUT |= BIT0;}while(0)      //串行数据输入
#define CLR_DIN   do{P3OUT &= ~(BIT0);}while(0)      //串行数据输入
#define SET_SCLK  do{P3OUT |= BIT1;}while(0)     //串行时钟输入
#define CLR_SCLK  do{P3OUT &= ~(BIT1);}while(0)     //串行时钟输入
#define SET_CS    do{P3OUT |= BIT2;}while(0)      //低电平有效
#define CLR_CS    do{P3OUT &= ~(BIT2);}while(0)      //低电平有效
/*****************************************软件延时******************************/
#define CPU_F ((double)16000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
  unsigned char i;
  Data <<= 6;     //移除高6位,int型数据有16位,该DA是10位
  CLR_SCLK;    //在片选有效前,时钟信号要为低
  CLR_CS;        //片选有效
  for(i=0;i<12;i++)       //每次转换需要10个时钟下降沿
    if(Data&0x8000)     //取最高位数据,模拟串行数据
      SET_DIN;
      CLR_SCLK;
      SET_SCLK;
      CLR_DIN;           //数据在时钟上升沿到来前准备好
      CLR_SCLK;
      SET_SCLK;
    Data <<= 1;          //数据左移,为下一次取数据做准备
    CLR_SCLK;
  SET_CS;                    //片选失效
delayms(1);
void P22_Onclick( void )
    KEY_OPEN_OR_STOP_times++;
    if( KEY_OPEN_OR_STOP_times > 2 )
void main(void)
    WDTCTL=WDTPW + WDTHOLD; // 关闭看门狗
    P1DIR=0xFF;            // 设置方向
    P1SEL=0;            // 设置为普通I/O 口
    P2DIR=0x03;            // 设置方向
   // P2SEL=0;            // 设置为普通I/O 口
    P3DIR=0xFF;            // 设置方向
    //-----配合机械按键,启用内部上拉电阻-----
    P2REN |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     //启用P3.5内部上下拉电阻
    P2OUT |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     //将电阻设置为上拉
    //-----配置P3.5中断参数-----
    P2DIR &= ~BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                    // P3.5设为输入(可省略)
    P2IES |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                     // P3.5设为下降沿中断
    P2IE  |= BIT2+BIT3+BIT4+BIT5+BIT6+BIT7;                    // 允许P3.5中断
    P1OUT=0x00;
    P5DIR |= BIT7+BIT4+BIT5+BIT6+BIT3;
    delayms(200);
    LCD_init();         //LCD1602初始化
    /****设置AD寄存器****/
    ADC12CTL0=ADC12ON+SHT0_2;//打开AD转换内核,参考电压3.3V
    ADC12CTL1=SHP;
    ADC12IE=0X01;//使能中断允许
    ADC12CTL0|=ENC;
    P6SEL|=0x01;//P6.0电压输入
    P6DIR = 0xFE;
    flag=0;
    ADC12CTL0|=ADC12SC;//启动ADC转换器
    _BIS_SR(LPM0_bits+ GIE);//进入低功耗睡眠模式
         LED_1;
        ADC1=ADC_READ();
        RefreshDis0(15-((ADC1*10)+25));
         Display();
         Display_Set();
        if(flag == 1)
            flag=0;
         KEY_OPEN_OR_STOP_times = 2;
         LED_0;
/****ADC12中断服务****/
#pragma vector=ADC12_VECTOR
__interrupt void ADC12_ISR(void)
   RefreshDis1(ADC12MEM0/8);
   flag=1;
   LPM0_EXIT;
* 名       称:P2_IODect()
* 功       能:判断具体引发中断的IO,并调用相应IO的中断事件处理函数
* 说       明:该函数兼容所有8个IO的检测,请根据实际输入IO激活“检测代码”。
void P2_IODect()
    unsigned int Push_Key=0;
    //-----排除输出IO的干扰后,锁定唯一被触发的中断标志位-----
    Push_Key=P2IFG&(~P2DIR);
    //-----延时一段时间,避开机械抖动区域-----
     delayms(5);                  //消抖延时
    //----判断按键状态是否与延时前一致-----
    if((P2IN&Push_Key)==0)                      //如果该次按键确实有效
        //----判断具体哪个IO被按下,调用该IO的事件处理函数-----
        switch(Push_Key)
               case BIT2:     P22_Onclick();      break;
               case BIT3:     if(KEY_OPEN_OR_STOP_times == 1) P23_Onclick();      break;
               case BIT4:     if(KEY_OPEN_OR_STOP_times == 1)P24_Onclick();      break;
               case BIT5:     if(KEY_OPEN_OR_STOP_times == 1)P25_Onclick();      break;
               case BIT6:     if(KEY_OPEN_OR_STOP_times == 1)P26_Onclick();      break;
               case BIT7:     if(KEY_OPEN_OR_STOP_times == 1)P27_Onclick();      break;
            default:                              break;      //任何情况下均加上default
#pragma vector = PORT2_VECTOR
__interrupt void PORT2_ISR(void)
    //-----启用Port2事件检测函数-----
    P2_IODect();                                //检测通过,则会调用事件处理函数
    P2IFG=0;                                    //退出中断前必须手动清除IO口中断标志
全部资料51hei下载地址:
恒流源.rar (341.46 KB, 下载次数: 80)
