查看: 4169|回复: 0
基于STC15单片机ADC卡尔曼滤波程序
ID:507486 发表于 2020-4-4 16:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. #include "stdio.h"
  4. #define FOSC    11059200L
  5. #define BAUD    9600
  6. typedef unsigned char BYTE;
  7. typedef unsigned int WORD;
  8. /*Declare SFR associated with the ADC */
  9. sfr ADC_CONTR   =   0xBC;           //ADC control register
  10. sfr ADC_RES     =   0xBD;           //ADC hight 8-bit result register
  11. sfr ADC_LOW2    =   0xBE;           //ADC low 2-bit result register
  12. sfr P1ASF       =   0x9D;           //P1 secondary function control register
  13. /*Define ADC operation const for ADC_CONTR*/
  14. #define ADC_POWER   0x80            //ADC power control bit
  15. #define ADC_FLAG    0x10            //ADC complete flag
  16. #define ADC_START   0x08            //ADC start control bit
  17. #define ADC_SPEEDLL 0x00            //420 clocks
  18. #define ADC_SPEEDL  0x20            //280 clocks
  19. #define ADC_SPEEDH  0x40            //140 clocks
  20. #define ADC_SPEEDHH 0x60            //70 clocks
  21. void InitUart();
  22. void SendData(BYTE dat);
  23. void Delay(WORD n);
  24. void InitADC();
  25. BYTE ch = 0;                        //ADC channel NO.
  26. WORD adc_buf[3];
  27. float vin_buf[3],kalman_buf[3];
  28. float kalmanFilter_A(float inData)
  29. {
  30.         //其中p的初值可以随便取,但是不能为0(为0的话卡尔曼滤波器就认为已经是最优滤波器了)
  31.         //q,r的值需要我们试出来
  32.         static float prevData=0;
  33.         static float p=10, q=0.0001, r=0.005, kGain=0;
  34.         p = p+q;
  35.         kGain = p/(p+r);
  36.         inData = prevData+(kGain*(inData-prevData));
  37.         p = (1-kGain)*p;
  38.         prevData = inData;
  39.         return inData;
  40. }
  41. void main()
  42. {
  43.     InitUart();                     //Init UART, use to show ADC result
  44.     InitADC();                      //Init ADC sfr
  45.     IE = 0xa0;                      //Enable ADC interrupt and Open master interrupt switch
  46.                                     //Start A/D conversion
  47.     while (1);
  48. }
  49. /*----------------------------
  50. ADC interrupt service routine
  51. ----------------------------*/
  52. void adc_isr() interrupt 5 using 1
  53. {
  54.     ADC_CONTR &= !ADC_FLAG;         //Clear ADC interrupt flag
  55.         adc_buf[ch] = ADC_RES;
  56.         vin_buf[ch] = 5.0*adc_buf[ch]/255;
  57.         kalman_buf[ch] = kalmanFilter_A(vin_buf[ch]);
  58.         printf("%1.3f /r/n ",vin_buf[ch]);
  59.
  60.     if (++ch > 2) ch = 0;           //switch to next channel
  61.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | ch;
  62. }
  63. /*----------------------------
  64. Initial ADC sfr
  65. ----------------------------*/
  66. void InitADC()
  67. {
  68.     P1ASF = 0xff;                   //Set all P1 as analog input port
  69.     ADC_RES = 0;                    //Clear previous result
  70.     ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | ch;
  71.     Delay(2);                       //ADC power-on delay and Start A/D conversion
  72. }
  73. /*----------------------------
  74. Initial UART
  75. ----------------------------*/
  76. void InitUart()
  77. {
  78.     SCON = 0x5a;                    //8 bit data ,no parity bit
  79.     TMOD = 0x20;                    //T1 as 8-bit auto reload
  80.     TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate
  81.     TR1 = 1;                        //T1 start running
  82. }
  83. /*----------------------------
  84. Send one byte data to PC
  85. Input: dat (UART data)
  86. Output:-
  87. ----------------------------*/
  88. void SendData(BYTE dat)
  89. {
  90.     while (!TI);                    //Wait for the previous data is sent
  91.     TI = 0;                         //Clear TI flag
  92.     SBUF = dat;                     //Send current data
  93. }
  94. /*----------------------------
  95. Software delay function
  96. ----------------------------*/
  97. void Delay(WORD n)
  98. {
  99.     WORD x;
  100.     while (n--)
  101.     {
  102.         x = 5000;
  103.         while (x--);
  104.     }
  105. }
卡尔曼滤波ADC.rar
39.44 KB, 下载次数: 78, 下载积分: 黑币 -5
收藏收藏2 分享淘帖 顶顶 踩踩
