查看: 4692|回复: 2
怎样把stc15w104单片机内部EEPROM的内容读出来?
怎样把stc15w104单片机EEPROM的内容读出来?
或者显示到液晶1602上?
void IAP_Disable()
//关闭IAP 功能, 清相关的特殊功能寄存器,使CPU 处于安全状态,
//一次连续的IAP 操作完成之后建议关闭IAP 功能,不需要每次都关
IAP_CONTR = 0; //关闭IAP 功能
IAP_CMD = 0; //清命令寄存器,使命令寄存器无命令,此句可不用
IAP_TRIG = 0; //清命令触发寄存器,使命令触发寄存器无触发,此句可不用
IAP_ADDRH = 0;
IAP_ADDRL = 0;
//读一字节,调用前需打开IAP 功能,入口:DPTR = 字节地址,返回:A = 读出字节
unsigned char Byte_Read(unsigned int add)
IAP_DATA = 0x00;
IAP_CONTR = ENABLE_ISP; //打开IAP 功能, 设置Flash 操作等待时间
IAP_CMD = 0x01; //IAP/ISP/Eeprom 字节读命令
my_unTemp16.un_temp16 = add;
IAP_ADDRH = my_unTemp16.un_temp8[0]; //设置目标单元地址的高8 位地址
IAP_ADDRL = my_unTemp16.un_temp8[1]; //设置目标单元地址的低8 位地址
//EA = 0;
IAP_TRIG = 0x5A; //先送 5Ah,再送A5h 到ISP/IAP 触发寄存器,每次都需如此
IAP_TRIG = 0xA5; //送完A5h 后,ISP/IAP 命令立即被触发起动
_nop_();
//EA = 1;
IAP_Disable(); //关闭IAP 功能, 清相关的特殊功能寄存器,使CPU 处于安全状态,
return (IAP_DATA);
//字节编程,调用前需打开IAP 功能,入口:DPTR = 字节地址, A= 须编程字节的数据
void Byte_Program(unsigned int add, unsigned char ch)
IAP_CONTR = ENABLE_ISP; //打开 IAP 功能, 设置Flash 操作等待时间
IAP_CMD = 0x02; //IAP/ISP/Eeprom 字节编程命令
IAP_DATA = ch; //要编程的数据先送进IAP_DATA 寄存器
//EA = 0;
_nop_();
//EA = 1;
//擦除扇区, 入口:DPTR = 扇区地址
void Sector_Erase(unsigned int add)
IAP_CMD = 0x03; //IAP/ISP/Eeprom 扇区擦除命令
//EA = 0;
_nop_();
//EA = 1;
//读取Eeprom中的运行参数数据,以便程序调用
void EepromRead(unsigned int Eeprom_Address, unsigned char MaxPara, unsigned int *P)
unsigned char i;
for( i=0; i<MaxPara; i++ )
*P =(unsigned int)(Byte_Read(Eeprom_Address+i*2))*0xFF+Byte_Read(Eeprom_Address+1+i*2); //读Eeprom的值,存到read_Eeprom
P++;
//存储系统参数,以便将来应用
void EepromSave(unsigned int Eeprom_Address, unsigned char MaxPara, unsigned int *P)
unsigned char i;
Sector_Erase(Eeprom_Address);
Byte_Program(Eeprom_Address+i*2,(unsigned char)( *P /0xFF));
Byte_Program(Eeprom_Address+i*2+1,(unsigned char)( *P %0xFF));
P++;
//Eeprom出厂设置
void EepromFactory(void)
MemorySys[DTime0] = 200; //系统参数200;,240
MemorySys[DTime1] = 100;
MemorySys[DTime2] = 200;
MemorySys[DTime3] = 200;
MemorySys[DTime4] = 100;
MemorySys[DTime5] = 300; //编码器方向
EepromSave(0x0000, SysTotal, MemorySys);//保存系统参数
DelayMS(100);
ID:213173 发表于 2020-6-12 06:11 | 只看该作者
参照STC官方读写EEPROM的示例程序修改即可,不过stc15w104只有6个IO口,驱动LCD1602有点问题。采用4线驱动只写不读也得占用4+2个IO口。这样就没有端口可用于其它外围设备了。就算用扩展电路也只能省下1~2个IO口。
ID:285863 发表于 2020-6-12 07:27 | 只看该作者
stc官网有例程
