查看: 3547|回复: 1
读/写atmega8515内部EEPROM的程序
ID:51472 发表于 2013-7-9 11:00 | 显示全部楼层 |阅读模式
;    Copyright 2004 pingfan's mcustudio
;    All rights Reserved
;作者:周坚
;eeprom.c
;读/写atmega8515内部EEPROM的例子
;将数据0....9写入eeprom中,再读出用数码管显示出来
#include "avr/io.h"
#include "avr/eeprom.h"
#define Hidden 16
uchar DispTab[17]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xFF};
uchar BitTab[6]={0x7F,0xBF,0xDF,0xEF,0xF7,0xFB};
uchar DispBuf[6]; //显示缓冲区
unsigned char Counter=0;
static void io_init(void)
// PortA
PORTA = 0xff;
DDRA = 0xff;
// PortB
PORTB = 0x0;
DDRB = 0x0;
// PortC
PORTC = 0xfc;
DDRC = 0xfc;
// PortD
PORTD = 0x0;
DDRD = 0x0;
void mDelay(uint16_t DelayTim)
{ uint16_t i;
for(;DelayTim>0;DelayTim--)
{ for(i=0;i<600;i++)
void disp()
{ static uchar i;
uchar tmp;
if(++i>=6)
i=0;
PORTC=0xff; //关闭显示
tmp=DispBuf[i];
PORTA=DispTab[tmp];
tmp=BitTab[i];
PORTC=tmp;
mDelay(1); //延时1ms
int main(void)
{ unsigned int Count=0;
unsigned char Addr=1; //向地址1里面写数字
uint8_t temp=0;
io_init();
DispBuf[0]=Hidden;
DispBuf[1]=Hidden;
DispBuf[2]=Hidden;
DispBuf[3]=Hidden;
DispBuf[4]=0; //次低位显示0
temp=eeprom_read_byte (Addr);
DispBuf[5]=temp;
if(++Count==1000)
{ Count=0;
Counter++;
eeprom_write_byte(Addr,Counter);
if(Counter>=10)
Counter=0; //计数值在0~9之间循环
disp(); //调用显示程序
ID:552794 发表于 2019-6-17 08:32 | 显示全部楼层
请问:用什么电路读取?请做详细说明。向楼主学习。
