查看: 3579|回复: 1
求大侠给ds1302加上掉电检测程序
ID:47184 发表于 2013-8-25 20:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
uchar temp[]={0xeb,0x88,0xb3,0xba,0xd8,0x7a,0x7b,0xa8,0xfb,0xfa};
sbit ce=P3^5;//ds1302
sbit sclk=P3^7;//时钟
sbit io=P3^6;//数据口
//定义摁键
sbit key1=P1^5;//小时+
sbit key2=P1^4;//小时-
sbit key3=P1^3;//分钟+
sbit key4=P1^2;//分钟-
//定义蜂鸣器
sbit beep=P1^6;
//定义段位
sbit duan=P1^0;
sbit wei=P1^1;
//位寻址寄存器定义
sbit ACC_7=ACC^7;
uchar num,dat1,dat2;
//地址数据发送子程序
void write1302(unsigned char addr,dat)
        uchar i,temp;
        ce=0;
        sclk=0;
        ce=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=addr;
                io=(bit)(temp&0x01);
                addr>>=1;
                sclk=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=dat;
                dat>>=1;
                sclk=1;
        ce=0;
//数据获取子程序
uchar read1302(uchar addr)
        uchar i,temp;
        ce=0;
        sclk=0;
        ce=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=addr;
                addr>>=1;
                sclk=1;
        for(i=8;i>0;i--)
                ACC_7=io;
                sclk=1;
                ACC>>=1;
                sclk=0;
        ce=0;
        dat1=ACC;
        dat2=dat1/16;
        dat1=dat1%16;
        dat1=dat1+dat2*10;
        return(dat1);
//初始化1302
void init()
        write1302(0x8e,0x00);
        write1302(0x90,0x06);
        write1302(0x80,0x56);
        write1302(0x82,0x46);
        write1302(0x84,0x19);
        write1302(0x8e,0x80);
//简单延时
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
//把1302读取到的数据显示到数码管上
void xianshi(uchar wela1,wela2)
        uchar shi,ge;
        shi=dat1/10;
        ge=dat1%10;
        wei=1;
        P2=wela1;
        wei=0;
        duan=1;
        P2=temp[shi];
        duan=0;
        delay(5);
        wei=1;
        P2=wela2;
        wei=0;
        duan=1;
        P2=temp[ge];
        duan=0;
        delay(5);
//蜂鸣器发声程序
void di()
        beep=0;
        delay(50);
        beep=1;
//摁键检测
void key_check()
                                                if(key1==0)
                                                        delay(1);
                                                        if(key1==0)
        di();
        while(!key1);
        read1302(0x85);
        dat1=dat1++;
        if(dat1==24)
        dat1=0;
        dat1=dat1%10+dat1/10*16;
        write1302(0x84,dat1);
                                                if(key3==0)
                                                        delay(1);
                                                        if(key3==0)
        di();
        while(!key3);
        read1302(0x83);
        dat1=dat1++;
        if(dat1==60)
        dat1=0;
        write1302(0x82,dat1);
                                                if(key2==0)
                                                        delay(1);
                                                        if(key2==0)
        di();
        while(!key2);
        read1302(0x85);
        dat1=dat1--;
        if(dat1==0)
        dat1=23;
                                                if(key4==0)
                                                        delay(1);
                                                        if(key4==0)
        di();
        while(!key4);
        read1302(0x83);
        dat1=dat1--;
        if(dat1==0)
        dat1=59;
//主程序
        init();
                key_check();//键盘检测
                        read1302(0x83);//读分钟
                        xianshi(0xdf,0xef);        //显示分钟
                        read1302(0x85);//读小时
                        xianshi(0x7f,0xbf);//显示小时
ID:76287 发表于 2015-4-10 09:17 | 只看该作者
虽然不懂,但还是要顶,毕竟每一位老手都是从新手蜕变而来的,赞一个。。。。。。
