查看: 1797|回复: 0
51单片机DAC0832低频波形发生器源程序 带详细注释
ID:582 发表于 2023-5-18 21:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include<reg52.h>                      //包含头文件
  2. #include<intrins.h>
  3. #define uchar unsigned char         //宏定义
  4. #define uint unsigned int
  5. sbit s1=P3^5;                                  //定义按键的接口
  6. sbit s2=P3^6;
  7. sbit s3=P3^7;
  8. sbit s4=P3^4;
  9. sbit led0=P3^0;                  //定义四个LED,分别表示不同的波形
  10. sbit led1=P3^1;
  11. sbit led2=P3^2;
  12. sbit led3=P3^3;
  13.
  14. sbit lcdrs=P2^7;                                           //液晶控制引脚,还有一个控制
  15. 脚是RW,因为我们只需要向液晶里写数据系就好了,所以,我们直接将RW引脚接地
  16. sbit lcden=P2^6;
  17. char num,boxing,u;                                           //定义全局变量
  18. int pinlv=100,bujin=1,bujin1=1;                   //频率初始值是10Hz,步进值默
  19. 认是0.1,显示步进值变量
  20. uchar code table[]="0123456789";                //定义显示的数组
  21. uchar code table1[]="Fout=     Wave form:";        //初始化显示字符
  22. unsigned long int m;                                   //定义长整形变量 m
  23. int a,b,h,num1;                                                        //定义全局变量
  24. //自定义字符
  25. uchar code zifu[]={                   //此数组内数据为液晶上显示波形符号的自定义字符
  26.                                                 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
  27.                                                 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00,
  28. //正弦波           0  1
  29.                                                 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
  30.                                                 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00,
  31. //矩形波           2  3
  32.                                                 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
  33.                                                 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,
  34. //三角波           4  5
  35.                                                 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00,
  36. //锯齿波           6
  37. };
  38. uchar code sin[64]={           //此数组内的数据为,da输出对应电压值对应的数字量,0是0V,255是5V
  39. 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
  40. 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
  41. };                                          //正弦波取码
  42. uchar code juxing[64]={                //一个周期是采样64个点, 所以数组内是64个数据
  43. 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
  44. 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
  45. };                                          //矩形波取码
  46. uchar code sanjiao[64]={
  47. 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
  48. 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
  49. };                                                //三角波取码
  50.
  51. void delay(uint xms)         //延时函数
  52. {
  53.         int a,b;
  54.         for(a=xms;a>0;a--)
  55.                 for(b=110;b>0;b--);
  56. }
  57. void write_com(uchar com)                //写命令函数
  58. {
  59.         lcdrs=0;
  60.         P0=com;
  61.         delay(1);
  62.         lcden=1;
  63.         delay(1);
  64.         lcden=0;
  65. }
  66. void write_date(uchar date)                //写数据函数
  67. {
  68.         lcdrs=1;
  69.         P0=date;
  70.         delay(1);
  71.         lcden=1;
  72.         delay(1);
  73.         lcden=0;
  74. }
  75. //自定义字符集
  76. void Lcd_ram()
  77. {
  78.         uint i,j,k=0,temp=0x40;
  79.         for(i=0;i<7;i++)
  80.         {
  81.            for(j=0;j<8;j++)
  82.            {
  83.             write_com(temp+j);
  84.             write_date(zifu[k]);
  85.             k++;
  86.            }
  87.            temp=temp+8;
  88.         }
  89. }
  90. void init_lcd()                                        //初始化函数
  91. {
  92.         uchar i;
  93.         lcden=0;                                        //默认开始状态为关使能端,见时序图
  94.         Lcd_ram();
  95.         write_com(0x0f);
  96.         write_com(0x38);                        //显示模式设置,默认为0x38,不用变。
  97.         write_com(0x01);                        //显示清屏,将上次的内容清除,默认为0x01.
  98.         write_com(0x0c);                        //显示功能设置0x0f为开显示,显示光标,光标闪烁;0x0c为开显示,不显光标,光标不闪
  99.         write_com(0x06);                        //设置光标状态默认0x06,为读一个字符光标加1.
  100.         write_com(0x80);                        //设置初始化数据指针,是在读指令的操作里进行的
  101.         for(i=10;i<20;i++)                           //显示初始化
  102.         {
  103.                 write_date(table1[i]);                   //显示第一行字符
  104.         }
  105.         write_com(0x80+0x40);                           //选择第二行
  106.         for(i=0;i<9;i++)
  107.         {
  108.                 write_date(table1[i]);                   //显示第二行字符
  109.         }
  110.         write_com(0x80+10);                                   //选择第一行第十个位置
  111.         write_date(0);
  112.         write_date(1);
  113.         write_date(0);
  114.         write_date(1);
  115.         write_date(0);
  116.         write_date(1);                                           //显示自定义的波形图案
  117.         write_com(0x80+0x40+0x09);                   //选择第二行第九个位置
  118.         write_date(' ');
  119.         write_date('1');
  120.         write_date('0');
  121.         write_date('0');
  122.         write_date('H');
  123.         write_date('z');                                   //显示初始的频率值
  124. }
  125. void initclock()                           //定时器初始化函数
  126. {
  127.         TMOD=0x01;                                   //定时器的工作方式
  128.         TH0=a;
  129.         TL0=b;                                           //定时器赋初值
  130.         EA=1;                                           //打开中断总开关
  131.         ET0=1;                                           //打开定时器允许中断开关
  132.         TR0=1;                                           //打开定时器定时开关
  133. }
  134. void display()                                   //显示函数
  135. {
  136.         uchar qian,bai,shi,ge;           //定义变量用于显示
  137.         qian=pinlv/1000;                   //将频率值拆成一位的数据,将数据除以1000,得到的商是一位数,赋值给qian
  138.         bai=pinlv%1000/100;                   //将频率除以1000的余数再除以100就得到了频率的百位,赋值给bai
  139.         shi=pinlv%1000%100/10;           //同上,得到频率的十位
  140.         ge=pinlv%1000%100%10;
  141.         write_com(0x80+0x40+0x09); //选中第二行第九个位置
  142.            if(qian==0)                                   //千位如果为0
  143.         write_date(' ');                   //不显示
  144.         else                                           //千位不为0
  145.         write_date(table[qian]);   //正常显示千位
  146.         if(qian==0&&bai==0)                   //千位和百位都为0
  147.         write_date(' ');                   //百位不显示
  148.         else                                           //不都为0
  149.         write_date(table[bai]);           //百位正常显示
  150.         write_date(table[shi]);           //显示十位数
  151.         write_date(table[ge]);           //显示个位
  152.         write_date('H');                   //显示频率的单位Hz
  153.         write_date('z');
  154.         if(boxing==0)                           //判断波形为正弦波
  155.         {
  156.                 write_com(0x80+10);           //选中一行频率图案位置
  157.                 write_date(0);                   //显示正弦波图案
  158.                 write_date(1);
  159.                 write_date(0);
  160.                 write_date(1);
  161.                 write_date(0);
  162.                 write_date(1);
  163.                 led3=1;
  164.                 led0=0;                                        //点亮正弦波指示灯
  165.         }
  166.         if(boxing==1)                                //注释同上
  167.         {
  168.                 write_com(0x80+10);
  169.                 write_date(2);
  170.                 write_date(3);
  171.                 write_date(2);
  172.                 write_date(3);
  173.                 write_date(2);
  174.                 write_date(3);
  175.                 led0=1;
  176.                 led1=0;
  177.         }
  178.         if(boxing==2)
  179.         {
  180.                 write_com(0x80+10);
  181.                 write_date(4);
  182.                 write_date(5);
  183.                 write_date(4);
  184.                 write_date(5);
  185.                 write_date(4);
  186.                 write_date(5);
  187.                 led1=1;
  188.                 led2=0;
  189.         }
  190. }
  191. void keyscan()                                        //频率调节键盘检测函数
  192. {
  193.         if(s1==0)                                        //加按键是否按下
  194.         {
  195.                 EA=0;                                        //关闭中断
  196.                 delay(2);                            //延时去抖
  197.                 if(s1==0)                                //再次判断
  198.                 {
  199.                         while(!s1);                        //按键松开
  200.                         pinlv+=bujin;                //频率以步进值加
  201.                         if(pinlv>1000)                //最大加到1000Hz
  202.                         {
  203.                                 pinlv=100;                //1000Hz
  204.                         }
  205.                         display();                        //显示函数
  206.                         m=65536-(150000/pinlv);//计算频率
  207. /*频率值最小是10Hz,pinlv的值是100(因为要显示小数点后一位),150000/100=1500,这个1500就是定时器需要计时的,单位是us,65536-1500得到的是定时器的初值,
  208. 先不管初值,先看定时时间,1500us,一个波形的周期是由64个定时组成的,所以,一个波形周期就是64*1500us=96000,也就是96ms,约等
  209. 于100ms,也就是10Hz的频率*/
  210.                         a=m/256;                        //将定时器的初值赋值给变量
  211.                         b=m%256;
  212.                         EA=1;                                //打开中断总开关
  213.                 }
  214.         }
  215.         if(s2==0)                                        //减按键按下
  216.         {
  217.
  218.                 delay(5);
  219.                 if(s2==0)
  220.                 {
  221.                         EA=0;
  222.                         while(!s2);
  223.                         pinlv-=bujin;                   //频率以步进值减
  224.                         if(pinlv<100)
  225.                         {
  226.                                 pinlv=1000;
  227.                         }
  228.                         display();
  229.                         m=65536-(150000/pinlv);
  230.                         a=m/256;
  231.                         b=m%256;
  232.                         EA=1;
  233.                 }
  234.         }
  235.         if(s3==0)                                         //波形切换按键
  236.         {
  237.                 delay(5);
  238.                 if(s3==0)
  239.                 {
  240.                         EA=0;
  241.                         while(!s3);
  242.                         boxing++;                           //波形切换
  243.                         if(boxing>=3)                   //4种波形
  244.                         {
  245.                                 boxing=0;
  246.                         }
  247.                         display();
  248.                         EA=1;
  249.                 }
  250.         }
  251. }
  252. void bujindisplay()                                 //步进值设置界面显示程序
  253. {
  254.         uint bai,shi,ge;                         //定义步进值 百十个位
  255.         bai=bujin1/100;                                 //将步进值除以100得到百位,也就是频率值的十位,因为有一个小数位
  256.         shi=bujin1%100/10;                         //将步进值除以100的余数除以十得到十位
  257.         ge=bujin1%100%10;                         //取余10后得到个位,也就是频率步进值的小数点后一位
  258.         write_com(0x80+11);                         //选中液晶第一行第十一列
  259.         if(bai==0)                                         //百位是否为0
  260.         write_date(' ');                         //百位不显示
  261.         else                                                 //百位不为0
  262.         write_date(table[bai]);                 //显示百位数据
  263.         write_date(table[shi]);                 //显示十位数据
  264.         write_date(table[ge]);                 //显示个位
  265. }
  266. void bujinjiance()                                 //步进值设置键盘程序
  267. {
  268.         if(s4==0)                                         //步进设置按键按下
  269.         {
  270.                 delay(5);                                 //延时去抖
  271.                 if(s4==0)                                 //再次判断按键
  272.                 {
  273.                          while(!s4);                 //按键释放,按键松开才继续向下执行
  274.                          h++;                                 //变量加
  275.                          if(h==1)                         //进入设置状态时
  276.                          {
  277.                                   write_com(0x01);                          //清屏
  278.                                  write_com(0x80);                          //初始化显示步进设置界面
  279.                                  write_date('S');delay(1);          //step value
  280.                                  write_date('t');delay(1);
  281.                                  write_date('e');delay(1);
  282.                                  write_date('p');delay(1);
  283.                                  write_date(' ');delay(1);
  284.                                  write_date('v');delay(1);
  285.                                  write_date('a');delay(1);
  286.                                  write_date('l');delay(1);
  287.                                  write_date('u');delay(1);
  288.                                  write_date('e');delay(1);
  289.                                  write_date(':');delay(1);
  290.                                  bujin1=bujin;                                  //步进值赋值给临时变量
  291.
  292.                                  bujindisplay();                          //显示步进值
  293.                          }
  294.                          if(h==2)                                                  //退出设置
  295.                          {
  296.                                  h=0;                                                  //清零
  297.                                 bujin=bujin1;                                  //设置好的临时步进值赋值给步进变量
  298.
  299.                                 init_lcd();                                          //初始化液晶显示
  300.                                 initclock();                                  //定时器初始化
  301.                                 display();                                          //调用显示程序
  302.                          }
  303.                 }
  304.         }
  305.         if(h==1)        //设置步进值时
  306.         {
  307.                 if(s1==0)                                                          //加按键按下
  308.                 {
  309.                         delay(5);                                                  //延时去抖
  310.                         if(s1==0)                                                  //再次判断
  311.                         {
  312.                                 while(!s1);                                          //按键释放
  313.                                 bujin1++;                                          //步进值加1
  314.                                 if(bujin1>=101)                                  //步进值最大100,也就是10.0Hz
  315.                                 {
  316.                                         bujin1=1;                                  //超过最大值就恢复到
  317.      0.1Hz
  318.                                 }
  319.                                 bujindisplay();                                  //步进显示
  320.                         }
  321.                 }
  322.                 if(s2==0)                                                          //减按键,注释同上
  323.                 {
  324.                         delay(5);
  325.                         if(s2==0)
  326.                         {
  327.                                 while(!s2);
  328.                                 bujin1--;                                          //步进减
  329.                                 if(bujin1<=0)
  330.                                 {
  331.                                         bujin1=100;
  332.                                 }
  333.                                 bujindisplay();
  334.                         }
  335.                 }
  336.         }
  337. }
  338. void main()                                         //主函数
  339. {
  340.         init_lcd();                                 //调用初始化程序
  341.         m=65536-(150000/pinlv);         //定时器初值
  342.         a=m/256;
  343.         b=m%256;
  344.         initclock();                         //定时器初始化
  345.         led0=0;                                         //点亮第一个波形指示灯
  346.         while(1)                                 //进入while循环,括号内为1,一直成立,所以也叫死循环,程序不会跳出,一直在内执行
  347.         {
  348.                 if(h==0)                         //正常模式不是步进调节
  349.                 {
  350.                         keyscan();                 //扫描按键
  351.                 //        display();
  352.                 }
  353.
  354.                 bujinjiance();                 //扫描步进调节程序
  355.                 switch(boxing)                                                        //选择波形
  356.                 {
  357.                         case 0 : P1=sin[u]; break;                        //正弦波
  358.                         case 1 : P1=juxing[u]; break;                //矩形波
  359.                         case 2 : P1=sanjiao[u]; break;                //三角波
  360.                 }
  361.         }
  362. }
  363. void T0_time()interrupt 1                   //定时器
  364. {
  365.         TH0=a;
  366.         TL0=b;                                                   //根据不同的初值,定时器定时时间不同,达到不同频率的目的
  367.         u++;                                                   //变量加
  368.         if(u>=64)                                           //一个周期采样64个点, 所以加到64就清零
  369.         u=0;                                                   //u清零
  370. }
word文档:http://www.51hei.com/bbs/dpj-228989-1.html
收藏收藏1 分享淘帖 顶 踩
