查看: 892|回复: 3
STM32F103外部中断设下降沿 函数内检测端口电压有时为正
ID:961122 发表于 2025-8-19 14:21 | 显示全部楼层 |阅读模式
STM32F103 外部中断设置为下降沿触发并在中断函数内检测用端口电压有时为高电平,请问是由于误触发导致的吗,还是配置有问题,输入信号是按键给的。
初始化程序
void exti0_init(void(*f)(uint8_t,uint8_t),uint8_t item){
    exti_flag = -1;
    exti_cp = f;
    exit_item = item;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,ENABLE);
    GPIO_InitTypeDef GPIO_InitStructure;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_EXTILineConfig(GPIO_PortSourceGPIOE,GPIO_PinSource3);
    EXTI_InitTypeDef EXTI_InitStructure;
    EXTI_InitStructure.EXTI_Line    =  EXTI_Line3;
    EXTI_InitStructure.EXTI_Mode =  EXTI_Mode_Interrupt;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
    EXTI_InitStructure.EXTI_LineCmd = ENABLE;
    EXTI_Init(&EXTI_InitStructure);
    NVIC_InitTypeDef NVIC_InitStructure;
    NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn ;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE;
    NVIC_Init(&NVIC_InitStructure);
void EXTI3_IRQHandler(void){
    if(EXTI_GetITStatus(EXTI_Line3) != RESET){
        #ifdef DEBUG_ENABLE
            printf("EXIT3 trigger:%d\n",GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_3));
        #endif
        EXTI_ClearITPendingBit(EXTI_Line3);
        while(EXTI_GetITStatus(EXTI_Line3) != RESET);
ID:384109 发表于 2025-8-19 15:49 | 显示全部楼层
端口复用功能不应该开启,中断向量设置为什么是DISABLE,可以找个例程,对比一下
ID:961122 发表于 2025-8-20 09:16 | 显示全部楼层
感谢回复!使用外部断是要开启RCC_APB2Periph_AFIO 复用功能的,中断向量DISABLE已改
ID:891041 发表于 2025-8-21 13:52 | 显示全部楼层
物理按键有抖动  按下之后 可能有很多重复的高低电平。有时候就被检测到了。
