查看: 21757|回复: 1
解决#error This file requires compiler and library support for the ISO C++ 2...
ID:51024 发表于 2014-7-30 14:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#error  This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
解决方法:
在工程文件.pro中添加:
QMAKE_CXXFLAGS+=-std=c++0x
或者
QMAKE_CXXFLAGS += -std=gnu++11
ID:818777 发表于 2020-9-14 11:04 | 只看该作者
姐姐,windows下怎么解决
