查看: 3425|回复: 0
基于GCC_TCPIP Socket—服务端文件传输
ID:51090 发表于 2014-9-18 12:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/socket.h>
#include <arpa/inet.h>
#include <fcntl.h>
#include <sys/stat.h>
#include <errno.h>
#include <signal.h>
#define IPLEN 40
#define  NUM 1024
#define  RCVPORT 1990
#define  NAME 45
#define  EOF  (-1)
int my_open(int sd,char *p);
int my_rdwr(int fd,int stat_st_size,int sd);
int main(int argc,char * argv[])
        int fd;
           int i=1;
        int sockedfd;
        int newsockedfd;
        int stop = EOF;
        char buf[20];
        size_t  len;
        struct sockaddr_in local_addr;
        struct sockaddr_in peer_addr;
        socklen_t addr_len;
        char ipstr[IPLEN];
        pid_t fpid;
        sockedfd = socket(PF_INET, SOCK_STREAM, 0);
        if(sockedfd< 0){
                perror("socket()");
                exit(1);
        setsockopt(sockedfd,SOL_SOCKET,SO_REUSEADDR,&i,sizeof(i) );
        local_addr.sin_family = PF_INET;//ipv4
        local_addr.sin_port = htons(RCVPORT);
        inet_pton(PF_INET, "0.0.0.0", &local_addr.sin_addr);//邦定端口
        if(bind(sockedfd, (struct sockaddr *)&local_addr, sizeof(local_addr)) < 0){
                perror("bind()");
                exit(1);
        if(listen(sockedfd, 200) < 0){
                perror("listen()");
                exit(1);
                addr_len = sizeof(peer_addr);
                newsockedfd = accept(sockedfd,(void*)&peer_addr, &addr_len);
                if(newsockedfd < 0)
                        perror("accept()");
                        exit(1);
                i=1;
                char n='0';
#if 1
                fpid=fork();
                if(0 ==fpid )
                        close(sockedfd);//关闭父进程监听描述符
#endif
                                len = read(newsockedfd,buf,1);
                                if(0 > len )
                                        perror("read()");
                                        return -1;
                                if( 0 ==len )
                                        break;
                                if ( '0'==n )
                                        n=buf[0];
                                        printf("n=%c, i=%d \n",n,i);
                                        if(n<'4'&&n>='1')
                                                snprintf(buf,sizeof(buf),"music/%c.wma",n);
                                                printf("%s \n",buf);
                                                my_fopen_rdwr(newsockedfd,buf);
                                                printf("ERROR()\n");
                                                len=write(newsockedfd,&stop,4);
                                                if(len<0)
                                                        perror("write()");
                                                        printf("writr end fill");
                                                n='0';
                                                break;
                                        if( NAME == i )
                                        {//图片张数
                                                len=write(newsockedfd,&stop,4);//结束写19
                                                if(len<0)
                                                        perror("write()");
                                                break;
                                        snprintf(buf,sizeof(buf),"jpg%c/%d.jpg",n,i++);
                        close(newsockedfd);
                        exit(0);
                else if (0 < fpid)
                        close(newsockedfd);//父进程关闭新套接字
                        signal(SIGCLD, SIG_IGN);//通知内核回收进程,该进程不是父进程回收
                        printf("this is fork error\n");
                //printf("*******%s %s %d****pid=%d****\n",__FILE__,__FUNCTION__,__LINE__,fpid);
        close(sockedfd);
        return 0;
int my_fopen_rdwr(int sd,char *p)
        struct stat stat_init;
        size_t ret;
        int pos,pos1;
        char buf[NUM];
        int j=0;
        FILE * fd;
        fd=fopen(p,"r");
        if(fd<0)
                perror("fopen()");
                return -1;
        if(stat(p,&stat_init)<0)
                perror("stat()");
                return -1;
#if 1
        ret=write(sd,&stat_init.st_size,4);
        pos1+=ret;
        if(ret<0)
                perror("write()");
                return -1;
#endif
        while(stat_init.st_size>0)
                pos=0;
                pos1=0;
                ret=fread(buf+pos,sizeof(char),NUM,fd);
                pos+=ret;
                if(ret<0){
                        perror("fread()");
                        return -1;
                ret=write(sd,buf+pos1,ret);
                pos1+=ret;
                if(ret<0){
                        perror("write()");
                        return -1;
                stat_init.st_size-=ret;
        printf("is over*******\n");
        fclose(fd);
        return 0;
本服务端代码测试通过 ,cpu占用率低,该服务端是采用多进程方式通讯,有客户端连接到服务端时,父进程会fork个子进程,子进程来连接客户,父进程继续监听端口,子进程下载完毕后自动退出,这样做的目的是在没有客户连接时,只有父进程一个处于监听状态,节约内存,提高性能,要是有多个客户连接,父进程只管fork子进程,节约了时间,同时可以多个客户端下载,本代码出错处理不够完善,后期继续跟新,如有建议和本人写的不足之处敬请给位多多指教。
