查看: 15792|回复: 9
SI4730 收音机芯片资料与程序
ID:72519 发表于 2015-1-20 15:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在网上看到关于这个SI4730的收音机芯片的资料比较少,所以现在特发上来,共有缘人参考,
如有不对之处,请指出。!!
由于时间仓促,自动搜台就没有编写,望有缘人写好后发上来分享。!!!!
晶振:24MHz
单片机:at89s52
注:转载请注明出处,否则追究法律责任!!!
日期:2010-03-06
版本:v1.0
设计者:sws
#include"reg52.h"
#include"intrins.h"
typedef unsigned char uchar;
typedef unsigned int uint;
#define HIGH 1
#define LOW 0
#define SI4730_HIGH    //4730选择地址定义
//#define SI4730_LOW
#define Max_freq_FM 10800      //108MHz
#define Min_freq_FM 8750   //87.5MHz
#define max_freq_AM 1701 //1701KHz
#define min_freq_AM 531
#define    FM_RECEIVER 0x20 //FM调谐频率 page.52
#define    FM_TRNSMITTER 0x30
#define    AM_RECEIVER 0x40 //AM调谐频率
#define    TX_TUNE_MEASURE 0x32
uint Frequency_fm=875;
uint Frequency_am=531;
bit Mode = 0;
sbit KEY_UP = P2^2;   //向上搜台
sbit KEY_DW = P2^3;   //向下搜台
sbit FM_AM_Choose = P2^4; //FM与AM选择
bit FM_AM_ = 0;
START condition:
SCLK: -----------|______
SDIO:-----|_____________
       1 |   2 | 3
STOP condition:
SCLK: ____|--------------
SDIO:____________|-------
1 | 2   |   3
DATA:
SCLK:_______________|---|________|----|_______
SDIO:___________|------------|____________|----
RESET:
SENB:__|---------------------------------------------
SDIO:_________________________________________|------
RST: ___________|------------------------------------
SCLK:__|---------------------------------------------
       |    1    |      2               |   3
sbit Si4730_Reset = P1^3;
sbit Si4730_SCLK = P1^2;
sbit Si4730_SDIO = P1^1;
//如果SI4730的第六脚(SEN)接高电平那么地址是0x23,0x22
//如果SI4730的第六脚(SEN)接低电平那么地址是0xc7,0xc6
//#if 0 //address switch
#ifdef SI4730_LOW
#define READ_ADDR   0x23
#define WRITE_ADDR 0x22
#endif
#ifdef SI4730_HIGH
#define READ_ADDR   0xc7
#define WRITE_ADDR 0xc6
#endif
#define SCLK_HIGH Si4730_SCLK = HIGH
#define SCLK_LOW Si4730_SCLK = LOW
#define SDIO_HIGH Si4730_SDIO = HIGH
#define SDIO_LOW Si4730_SDIO = LOW
#define READ_SDIO Si4730_SDIO
//===============FM START===================
void _NOP()
_nop_();_nop_();
_nop_();_nop_();
_nop_();_nop_();
void Si4730_Delay(unsigned char k)
uchar i,j;
for(i=150;i>0;i--)
   for(j=k;j>0;j--);
#define I2C_CLK_Delay() _NOP()
void ResetSi47XX_2w()
   Si4730_Reset = LOW;
   SCLK_HIGH;
   Si4730_Delay(100);
   SDIO_HIGH;
   Si4730_Delay(250);
   Si4730_Reset = HIGH;
void Si4730_start()
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_ack()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
    I2C_CLK_Delay();
    SDIO_HIGH;
void Si4730_stop()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_writebyte(uchar write_data)
uchar i;
for(i=8;i!=0;i--)    // 循环移入8个位
   READ_SDIO = (bit)(write_data & 0x80);
   SCLK_HIGH;
   I2C_CLK_Delay();
   SCLK_LOW; //SDA数据线上数据变化
   write_data <<= 1;   //调整发送位
void Operation_Si4730_Write(uchar *data1,uchar numByte)
uchar j;
Si4730_start();
Si4730_writebyte(WRITE_ADDR);//器件地址 0xc6
Si4730_ack();
I2C_CLK_Delay();
for(j=LOW;j<numByte;j++,*data1++)
   Si4730_writebyte(*data1);
   Si4730_ack();
   I2C_CLK_Delay();
Si4730_stop(); //发送结束
void Si4730_Power_Up_FM_AM_Choose(unsigned char mod) //fm,am选择
unsigned char write_buf[3]={0x01,0xd0,0x05};
switch(mod)
   case FM_RECEIVER:        //si4730
      write_buf[1] = 0xd0; //使用时钟晶振,32.768khz ,FM模式
      write_buf[2] = 0x05; //模拟L/R输出
      break;
     case AM_RECEIVER:           //si4730
       write_buf[1] = 0xd1; //使用时钟晶振,32.768khz ,AM模式
       break;
Operation_Si4730_Write(&(write_buf[0]), 3);//need wait >=300mS
Si4730_Delay(250);
Si4730_Delay(250);
Si4730_Delay(120);
void Si4730_Tune(char mod,unsigned short Channel_Freq)
unsigned char write_buf[5];
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[2] = Channel_Freq >> 8;   //写入高字节
write_buf[3] = Channel_Freq;     //写入低字节
write_buf[4]= 0x00;
   Operation_Si4730_Write(&(write_buf[0]), 5);
void Search_FM()   //调用手动FM 频率调整子程序 menu = 15
   if(Mode)
    Frequency_fm += 10;   //步进+0.1MHz
    if(Frequency_fm > Max_freq_FM)
     Frequency_fm = Min_freq_FM;
    Frequency_fm -= 10;   //步进-0.1MHz
    if(Frequency_fm < Min_freq_FM)
     Frequency_fm = Max_freq_FM;
// Si4730_Power_Up(FM_RECEIVER); //向上搜台
Si4730_Tune(FM_RECEIVER,Frequency_fm); //FM收音芯片数据刷新一次
//=================fm end============
//===============am start==============
void Si4730_Tune_AM(char mod,unsigned short Channel_Freq)
unsigned char write_buf[6];
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
write_buf[5]= 0x00;
   Operation_Si4730_Write(&(write_buf[0]), 6);
void Search_AM()   //调用手动FM 频率调整子程序 menu = 95
   if(Mode)
    Frequency_am += 9;   //步进+9KHz
    if(Frequency_am > max_freq_AM)
     Frequency_am = min_freq_AM;
    Frequency_am -= 9;   //步进-9KHz
    if(Frequency_am < min_freq_AM)
     Frequency_am = max_freq_AM;
// Si4730_Power_Up(AM_RECEIVER); //向上搜台
Si4730_Tune_AM(AM_RECEIVER,Frequency_am); //AM收音芯片数据刷新一次
//=======================am end========================
//==============main start=======================
ResetSi47XX_2w();
Si4730_Delay(250);
   if(!FM_AM_Choose)
    Si4730_Delay(100);
    if(!FM_AM_Choose)
      FM_AM_ = ~FM_AM_;
      if(!FM_AM_)
         Si4730_Power_Up_FM_AM_Choose(FM_RECEIVER); //fm选择
      else if(FM_AM_)
         Si4730_Power_Up_FM_AM_Choose(AM_RECEIVER ); //am选择
    if(!FM_AM_)
   // ResetSi47XX_2w();
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜台
      Search_FM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜台
      Search_FM();
    else if(FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜台
      Search_AM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜台
      Search_AM();
//=================main end=====================
收藏收藏4 分享淘帖 顶顶 踩踩
ID:71523 发表于 2015-1-20 16:02 | 只看该作者
这个没有显示频率的,我不会加上显示频率,用的是1602,
ID:71523 发表于 2015-1-20 16:08 | 只看该作者
include"reg52.h"
#include"intrins.h"
#include "LCD1602_4w.h"
#define HIGH 1
#define LOW 0
bit Mode = 0;
bit FM_AM_ = 0;
//LCD1602_4w
sbit LCD_RS = P1^0;
sbit LCD_RW = P1^1;
sbit LCD_EP = P1^2;
#define LCD_EN  LCD_EP
#define LCD_DATA    P0
START condition:
       1 |   2 | 3
STOP condition:
1 | 2   |   3
DATA:
RESET:
       |    1    |      2               |   3
#ifdef SI4730_LOW
#endif
#ifdef SI4730_HIGH
#endif
void _NOP()
_nop_();_nop_();
_nop_();_nop_();
_nop_();_nop_();
uchar i,j;
for(i=150;i>0;i--)
   for(j=k;j>0;j--);
   Si4730_Reset = LOW;
   SCLK_HIGH;
   Si4730_Delay(100);
   SDIO_HIGH;
   Si4730_Delay(250);
void Si4730_start()
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_LOW;
void Si4730_ack()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
    I2C_CLK_Delay();
    SDIO_HIGH;
void Si4730_stop()
    SDIO_LOW;
    I2C_CLK_Delay();
    SCLK_HIGH;
    I2C_CLK_Delay();
    SDIO_HIGH;
    I2C_CLK_Delay();
    SCLK_LOW;
uchar i;
   SCLK_HIGH;
   I2C_CLK_Delay();
uchar j;
Si4730_start();
Si4730_ack();
I2C_CLK_Delay();
   Si4730_ack();
   I2C_CLK_Delay();
switch(mod)
      break;
       break;
Si4730_Delay(250);
Si4730_Delay(250);
Si4730_Delay(120);
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
   if(Mode)
write_buf[0]= mod;
write_buf[1]= 0x00;
write_buf[4]= 0x00;
write_buf[5]= 0x00;
   if(Mode)
ResetSi47XX_2w();
Si4730_Delay(250);
   if(!FM_AM_Choose)
    Si4730_Delay(100);
    if(!FM_AM_Choose)
      FM_AM_ = ~FM_AM_;
      if(!FM_AM_)
      else if(FM_AM_)
    if(!FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜台
      Search_FM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜台
      Search_FM();
    else if(FM_AM_)
    if(!KEY_UP)
      Si4730_Delay(100);
      if(!KEY_UP)
         Mode = HIGH; //向上搜台
      Search_AM();
    if(!KEY_DW)
      Si4730_Delay(100);
      if(!KEY_DW)
         Mode = LOW; //向下搜台
      Search_AM();
新建文件夹 (3).rar (5.93 KB, 下载次数: 74)
先不管1602怎么定义接MCU,现在报错,说什么没定义,你帮看一下
ID:71523 发表于 2015-1-20 16:11 | 只看该作者
我只是你这程序加上#include "LCD1602_4w.h",然后加上1602的接线定义后翻译出错,请求版主大家帮看一下,怎么样在你发的程序上加上频率显示,MCU你可随便定义,我改就行,期盼你的回复
ID:75609 发表于 2015-3-29 15:02 | 只看该作者
我现在也要做si4730收音机,一起努力吧
ID:88407 发表于 2015-8-16 00:13 | 只看该作者
好东西,学习,学习,
ID:229361 发表于 2019-1-10 16:35 | 只看该作者
好东西,学习,学习,
ID:403593 发表于 2019-11-8 08:59 | 只看该作者
正在找它的资料,感谢分享!
ID:166475 发表于 2021-11-8 12:24 来自触屏版 | 只看该作者
timer.h:  #ifndef __TIMER_H_  #define __TIMER_H_  //如果外部需要使用这些变量或函数,直接包含头文件即可。  //如果不对外开放的函数,就不需要添加  //注:在C源文件中,函数声明要补全  extern int timerCnt;  extern int timerStatu;  extern void TimerStart();  extern void TimerStop();  extern void TimerInit();  #endif
ID:838732 发表于 2024-9-23 21:34 | 只看该作者
这个程序用不了哦
