查看: 9744|回复: 20
自写倒计时器带闹程序最长定时99:59
ID:71774 发表于 2015-1-21 12:36 | 显示全部楼层 |阅读模式
自写倒计时器带闹c程序,最长定时99:59,时间到,闹铃10秒,已在学习板上通过,稍改后可用于控制其他负载。刚学请各位老师指导!用数码管显示的吧,电路下载:http://www.51hei.com/f/ks51.pdf
#include <reg52.h>
typedef  unsigned char   uint8;
typedef  unsigned int    uint16;
code uint8 number[] = {0xc0,0xf9,0xa4,0xb0,
                                              0x99,0x92,0x82,0xf8,
                                            0x80,0x90};
uint8 a[6];
uint16 counter = 0;
uint8 sec,min=0,hour=0,t_min=0,t_hour=0,ky=0;      //操作:a:1、开机显示6个0,可进行闹时设置。-> 2、功能按键K3按1下走时。->        // 3 、功能键再按1下关闹铃。->再按1下回到闹时设置。循环。
uint16  counter1=0;
        //b:  K1、K2可设置时、分,最长定时99:59。
sbit BUZZ = P1^6;
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit KeyOut1=P2^3;
sbit K1 = P2^4;
sbit K2 = P2^5;
sbit K3 = P2^6;
void timer1_init()   //定时器1初使化
        TMOD |= 0x10;
        TMOD &= 0xdf;
        TH1   = 0xFC;
        TL1   = 0x67;
    ET1 = 1;
        EA  = 1;
         TR1 = 1;
void interrupt_timer1()interrupt 3  //中断函数
{          TH1 = 0xFC;
          TL1 = 0x67;
          counter1++;
          if(counter1 == 1000)
          { counter1 =0;
           TR1 = 0;}
           BUZZ = ~BUZZ;
void timer2_init()         //  定时器T2运行函数
        T2MOD=0X00;
        TH2=(65536-110592/60)/256;
        TL2=(65536-110592/60)%256;
        RCAP2H=TH2;
        RCAP2L=TL2;
        EA=1;
        ET2=1;
        TR2=1;
void refresh_led() //数码管刷新函数
          static uint8 j = 0;
                switch(j)
                   case 0: ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;j++;P0=0x7f & number[a[0]];break;
                case 1: ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[1]];break;
                case 2: ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;j++;P0 =0x7f & number[a[2]];break;
                case 3: ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[3]];break;
                case 4: ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;j++;P0 =0x7f & number[a[4]];break;
                case 5: ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;j = 0;P0 = number[a[5]];break;
                default: break;
void Hms(void)         //秒,分,时计算函数
        static uint16 ui2msCount=0;
               if(ky==1)
            ui2msCount++;
                if(ui2msCount>499)
                 ui2msCount=0;
                 if (sec==0)
                     sec=60;
                    if (min==0)
                        min=60;
                     if (hour==0)
                        hour=99;
                         hour--;
                     min--;
                  sec--;
                 a[5]=hour/10;
                 a[4]=hour%10;
                 a[3]=min/10;
                 a[2]=min%10;
                 a[1]=sec/10;
                 a[0]=sec%10;
                        if((ky==1)&&(sec==0)&&(min==0)&&(hour==0))
                        (timer1_init(),ky=0);
void Key3(void) //K3按键处理函数
             while(!K3);
              ky++;
             if(ky > 1)
              ky=0;
void Key2(void) //K2按键处理函数
  while(!K2);
   if(ky==0)
        min++;
     if(min>59)
        min=0;
void Key1(void)          //K1按键处理函数
   while(!K1);
    if(ky==0)
            hour++;
      if(hour>99)
         hour=0;
void Delay(uint8 ms)        //毫秒延时函数
uint8 i;
        while(ms--)
          for( i=0;i<125;i++)
main()                   //主函数
        ENLED = 0; ADDR3 = 1;
        timer2_init();
     KeyOut1=0;
         while(1)                 //主循环
                if(!K1)
                Delay(5);
                if(!K1)
                Key1();
                if(!K2)
                Delay(5);
                if(!K2)
                Key2();
                    if(!K3)
                        Delay(5);
                    if(!K3)
                        Key3();
void interrupt_timer2()        interrupt 5           //定时器T2中断函数
          TF2=0;
          Hms();
          refresh_led();
参与人数 3黑币 +61 收起 理由
mtq + 5 很给力!
admin + 50 共享资料的积分奖励!
liuda + 6 很给力!
ID:43559 发表于 2015-1-21 19:25 | 显示全部楼层
感谢分享经验。
ID:61153 发表于 2015-1-23 14:54 | 显示全部楼层
努力学习中,感谢分享!!
ID:72399 发表于 2015-1-23 16:12 | 显示全部楼层
矩阵键盘的程序,用到再复制
ID:54731 发表于 2015-1-24 18:00 | 显示全部楼层
请问:你用的是74hc138控制LED吗?
ID:71774 发表于 2015-1-24 18:20 | 显示全部楼层
是的,用的38译码器。
ID:72947 发表于 2015-1-31 17:05 来自触屏版 | 显示全部楼层
谢谢楼主,学习一下!!!
ID:73480 发表于 2015-2-28 16:11 | 显示全部楼层
如果改成这样,应该怎么改?:初始时间及定时时间可调,且动态显示剩余时间,并在最后一分钟发出警告声,时间到提醒。
ID:71774 发表于 2015-3-15 22:28 | 显示全部楼层
宰猪的羊羔 发表于 2015-2-28 16:11
如果改成这样,应该怎么改?:初始时间及定时时间可调,且动态显示剩余时间,并在最后一分钟发出警告 ...
不应改,原本就是这样设计的。
ID:105849 发表于 2016-4-20 01:29 | 显示全部楼层
如果断电再上电程序会不会接着原来的运行。
ID:105849 发表于 2016-4-20 01:32 | 显示全部楼层
如果运行过程中,断电再上电,会不会还接这原来的程序运行?
ID:194752 发表于 2017-5-18 22:36 | 显示全部楼层
这个不错,,,跟我想写的程序有点像。。做个记号以学习。。
ID:203313 发表于 2017-5-22 01:10 | 显示全部楼层
楼主的分享太给力了,值得学习,谢谢~
ID:44037 发表于 2017-5-22 06:01 | 显示全部楼层
谢谢分享   感谢分享经验
ID:200824 发表于 2017-5-22 09:09 | 显示全部楼层
不错啊
ID:193705 发表于 2017-5-24 19:38 来自触屏版 | 显示全部楼层
厉害 值得学习
ID:202435 发表于 2017-6-3 15:18 | 显示全部楼层
可以帮改成用LCD1602显示吗?最近需要可不会改。
ID:590386 发表于 2019-7-31 09:45 | 显示全部楼层
ADDR3/ENLED/KeyOut1是连接什么的?
ID:592779 发表于 2019-7-31 11:17 来自触屏版 | 显示全部楼层
不错,挺好的啊
ID:105782 发表于 2019-8-3 11:43 来自触屏版 | 显示全部楼层
程序可以再简单点
ID:590244 发表于 2019-8-15 11:19 | 显示全部楼层
謝謝分享
