查看: 4247|回复: 0
Easyarm lpc2200外部中断使用小结
ID:72519 发表于 2015-1-23 23:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天够郁闷的,下午写了个中断程序玩玩,一直到晚上8:00才把它搞定,原因是我没有开启IRQ中断,实在是郁闷,好在解决了,且又学到东西,先把程序附下,我就没怎么注释啦,反正要记得在InitStacks.s中要把系统管理模式堆栈处的代码改为“MSR     CPSR_c, #0x5f”,即使能IRQ,否则永远也实现不了。有什么问题可以在下面留言。
#include "config.h"
#define        spi_shcp    0x00000010    //0.4
#define        spi_stcp    0x00000100    //0.8
#define        spi_q7        0x00000020    //0.5
#define        spi_ds        0x00000040    //0.6
void  delay(uint32  dly)
{  uint32  i;
   for(; dly>0; dly--)
      for(i=0; i<5000; i++);
void hc595send_data(uint8 data)
    uint8 i;
    IO0CLR = spi_stcp;
    for(i=0;i<8;i++)
        IO0CLR = spi_shcp;
        if((data&0x80)!=0)IO0SET = spi_ds;
            else IO0CLR = spi_ds;
        data <<= 1;
        IO0SET = spi_shcp;
    IO0SET = spi_stcp;
const uint8  DISP_TAB[16] = { 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
                              0x81,0x42,0x24,0x18,0x24,0x42,0x81,0x00 };
void __irq IRQ_Eint1(void)
    uint8 a;
    for(a=0;a<16;a++)
        hc595send_data(~DISP_TAB[a]);
        delay(5);
       EXTINT = 0x02;                // 清除EINT1中断标志
    VICVectAddr = 0;                    // 向量中断结束
int main (void)
{// add user source code
    PINSEL0 = 0x20000000;
    IO0DIR = 0x00000150;//0001 1/0 101 0000
    EXTMODE = 0x00;
    EXTPOLAR = 0x02;
    VICIntSelect = 0x00000000;
    VICVectCntl0 = 0x20|15;
    VICVectAddr0 = (int)IRQ_Eint1;
    EXTINT = 0x02;
    VICIntEnable = 0x00008000;
    while(1);
    return 0;
