查看: 9006|回复: 9
热电阻PT10 PT100 Cu50 Cu100电阻转温度程序
ID:54731 发表于 2015-1-27 12:46 | 显示全部楼层 |阅读模式
*函数描述:PT10&PT100 Cu50&Cu100 热阻转温度
*输入变量:R 热阻阻值
          type热电阻类型 0 PT10
                                 1 PT100
                                 2 Cu50
                                 3 Cu100
*返回变量:float T 温度
float RtoT(float R, uchar type)
        uchar R0;  // 热电阻0度时阻值
        float T, tmp, min, mid, max;
        float x, y, z;
        float d = 3.9083/1e3, b = -5.775/1e7, c = -4.183/1e12;
        if(type <= 1)
                if(type == 0)
                        R0 = 10; min = 1.852; mid = 10; max = 39.049;  // Pt10
                        R0 = 100; min = 18.52; mid = 100; max = 390.49; // Pt100
                if(R>=mid && R<=max)
                        y = sqrt(d*d - 4*b*(1-R/R0));
                        T = (y-d) / (2*b);  // 得出温度
                else if(R<mid && R>=min)
                        x = 0; y = -100; z = -201;
                        tmp = R0*(1 + d*y + b*y*y + c*(y-100)*y*y*y);
                        while(fabs(tmp-R)>=0.007)
                                if(R > tmp)
                                        x = x; z = y;
                                        y = (x+y)/2;
                                        x = y; z = z;
                                        y = (y+z)/2;
                        T = y;  // 得出温度
                if(type == 2)  // Cu50
                        R0 = 50;
                else           // Cu100
                        R0 = 100;
                x = 150; y = 50; z = -50;
                tmp = R0*(1 + 4.289/1e3*y - 2.133/1e7*y*y + 1.233/1e9*y*y*y);
                        if(R > tmp)
                                x = x; z = y;
                                y = (x+y)/2;
                                x = y; z = z;
                                y = (y+z)/2;
                        tmp = R0*(1 + 4.28899/1e3*y - 2.133/1e7*y*y + 1.233/1e9*y*y*y);
                T = y;
        return T;
参与人数 2黑币 +55 收起 理由
loong1 + 5 共享资料的黑币奖励!
admin + 50 共享资料的积分奖励!
ID:1 发表于 2015-1-28 14:11 | 显示全部楼层
资料很 好  谢谢分享
ID:67678 发表于 2015-1-28 22:28 | 显示全部楼层
谢谢分享
ID:43600 发表于 2015-1-29 16:13 | 显示全部楼层
very good, nice job !!!
ID:72973 发表于 2015-1-29 22:59 | 显示全部楼层
资料很 好  谢谢分享
ID:124770 发表于 2016-6-2 20:48 | 显示全部楼层
谢谢分享
ID:135386 发表于 2017-8-28 18:43 | 显示全部楼层
谢谢分享
ID:334781 发表于 2018-5-21 16:55 | 显示全部楼层
谢谢楼主的分享,不错的资料!
ID:156945 发表于 2018-6-7 21:10 | 显示全部楼层
看不完?
ID:412814 发表于 2019-3-21 19:11 | 显示全部楼层
谢谢楼主分享,虽然还是看不懂。
