查看: 5963|回复: 0
LPC1114驱动1602液晶程序(第一部分)
ID:73735 发表于 2015-2-18 23:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
说明:第二部分为驱动程序核心部分,需要第二部分:http://www.51hei.com/bbs/dpj-31563-1.html
第二部分LCD.h文件:
LCD.h文件
#ifndef     __LCD_H__
#define     __LCD_H__
#define   TESTBIT(a,b) ((a)&(1<<(b)))
#define                LCD_RS_Low()                 LPC_GPIO2->DATA &=~(1<<8)          //给P2.8位写0
#define                LCD_RS_High()                 LPC_GPIO2->DATA |=(1<<8)           //给P2.8位写1
#define                LCD_RW_Low()                 LPC_GPIO2->DATA &=~(1<<9)          //给P2.9位写0
#define                LCD_RW_High()                 LPC_GPIO2->DATA |=(1<<9)           //给P2.9位写1
#define                LCD_EN_Low()     LPC_GPIO2->DATA &=~(1<<10)         //给P2.10位写0
#define                LCD_EN_High()    LPC_GPIO2->DATA |=(1<<10)          //给P2.10位写1
void Set_GPIO_Output(void);
void Set_GPIO_Input(void);
void LCD_GPIO_Init(void);
void Write_Data_Port(unsigned char Data);
unsigned char Read_Data_Port(void);
unsigned char Chk_LCD_busy(void);
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue);
void Write_LCD_data(unsigned char gdata);
void INIT_LCD(void);
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata);
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void Clear_Display(void);
#endif
system_LPX11xx.c(时钟配置程序)
#include <stdint.h>
#include "LPC11xx.h"
#define CLOCK_SETUP           0
#define MAIN_PLL_SETUP        0
#define MAIN_CLKSRCSEL_Val    0x00000001
#define MAIN_PLL_M_Val        0x00000003
#define MAIN_PLL_P_Val        0x00000001
#define SYS_AHB_DIV_Val       4/* 1 through 255, typical is 1 or 2 or 4 */
//-------- <<< end of configuration section >>> ------------------------------
  DEFINES
  Define clocks
#define XTAL        (12000000UL)        /* Oscillator frequency               */
#define OSC_CLK     (      XTAL)        /* Main oscillator frequency          */
#define IRC_OSC     (12000000UL)        /* Internal RC oscillator frequency   */
#define WDT_OSC     (  250000UL)        /* WDT oscillator frequency           */
  Clock Variable definitions
uint32_t ClockSource = IRC_OSC;
uint32_t SystemFrequency = IRC_OSC; /*!< System Clock Frequency (Core Clock)  */
uint32_t SystemAHBFrequency = IRC_OSC;
* Misc. clock generation modules
* @param  none
* @return none
* @brief  Setup the microcontroller system.
*         Initialize the System and update the SystemFrequency variable.
void Main_PLL_Setup ( void )
  uint32_t regVal;
  ClockSource = OSC_CLK;
  LPC_SYSCON->SYSPLLCLKSEL = MAIN_CLKSRCSEL_Val;   /* Select system OSC--PLL时钟源选中系统振荡器 */
  LPC_SYSCON->SYSPLLCLKUEN = 0x01;                 /* Update clock source */
  LPC_SYSCON->SYSPLLCLKUEN = 0x00;                 /* toggle Update register once */
  while ( !(LPC_SYSCON->SYSPLLCLKUEN & 0x01) );    /* Wait until updated 等待系统振荡器锁定*/
  regVal = LPC_SYSCON->SYSPLLCTRL;
  regVal &= ~0x1FF;
  LPC_SYSCON->SYSPLLCTRL = (regVal | (MAIN_PLL_P_Val<<5) | MAIN_PLL_M_Val);/* P=1, M=4 */
  /* Enable main system PLL, main system PLL bit 7 in PDRUNCFG. */
  LPC_SYSCON->PDRUNCFG &= ~(0x1<<7);              /* PDRUNCFG第七位写0,即系统PLL上电 */
  while ( !(LPC_SYSCON->SYSPLLSTAT & 0x01) );    /* Wait until it's locked */
  LPC_SYSCON->MAINCLKSEL = 0x01;              /* Select PLL clock output--选择PLL输出作为主时钟 */
  LPC_SYSCON->MAINCLKUEN = 0x01;              /* Update MCLK clock source --允许更新主时钟*/
  LPC_SYSCON->MAINCLKUEN = 0x00;              /* Toggle update register once */
  while ( !(LPC_SYSCON->MAINCLKUEN & 0x01) );    /* Wait until updated 等待主时钟锁定*/
  LPC_SYSCON->SYSAHBCLKDIV = SYS_AHB_DIV_Val;    /* SYS AHB clock, typical is 1 or 2 or 4 --SYSAHBCLKDIV的值为1,即不分频 AHB时钟为12*4=48MHz*/
#if MAIN_PLL_SETUP
  SystemFrequency = ClockSource * (MAIN_PLL_M_Val+1);    /*系统时钟=时钟源*4MHz*/
#else
  SystemFrequency = ClockSource;
#endif
  SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val);   /*AHB时钟=系统时钟/AHB分频值*/
  return;
* Initialize the system
* @param  none
* @return none
void SystemInit (void)
  //uint32_t i;
#ifdef __DEBUG_RAM
  LPC_SYSCON->SYSMEMREMAP = 0x1;/* remap to internal RAM */
#else
#ifdef __DEBUG_FLASH
  LPC_SYSCON->SYSMEMREMAP = 0x2;/* remap to internal flash */
#endif
#endif
#if (CLOCK_SETUP)                       /* Clock Setup */
  /* bit 0 default is crystal bypass,
  bit1 0=0~20Mhz crystal input, 1=15~50Mhz crystal input. */
  LPC_SYSCON->SYSOSCCTRL = 0x01;
  /* main system OSC run is cleared, bit 5 in PDRUNCFG register */
  LPC_SYSCON->PDRUNCFG &= ~(0x1<<5);    /* PDRUNCFG的第五位写0,即系统系统振荡器上电 */
  /* Wait 200us for OSC to be stablized, no status
  indication, dummy wait. */
  for ( i = 0; i < 0x100; i++ );
#if (MAIN_PLL_SETUP)
  Main_PLL_Setup();
#endif
#endif/* endif CLOCK_SETUP */
  /* System clock to the IOCON needs to be enabled or
  most of the I/O related peripherals won't work. */
  LPC_SYSCON->SYSAHBCLKCTRL |= (1<<16);                  //使能IO配置模块的时钟
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);                   //开启定时器Timer16_1时钟
  return;
main.c程序:
#include "LPC11XX.h"
#include "gpio.h"
#include "timer16.h"
#include "main.h"
#include "Delay.h"
#include "LCD.h"
#include "Key.h"
const unsigned char P[] = {"Bei-Jing"};
int main(void)
SystemInit();                             //系统初始化--主要是设置主时钟和开启所需模块时钟
GPIOInit();                                //GPIO初始化--主要是开启GPIO时钟
LPC_IOCON->PIO0_3 &= (~0x07);              //设置P2.0为GPIO
LPC_GPIO0->DIR |= (0x1<<3);                //设置P0.3为输出
INIT_LCD();
DispChar_XY_LCD(15, 0, 'A');               //显示A
DispChar_XY_LCD(15, 1, 'Y');               //显示Y
Display_LCD_string(1, 0, 8, P);
Display_LCD_string(1, 1, 8, P);
    GPIOSetValue( 0, 3, 0 );                 //给P0.3位写0
Delay_Ms(1000);                          //延时
GPIOSetValue( 0, 3, 1 );                 //给P0.3位写1
Delay.c程序:(延时程序使用Timer16_1实现)
#include "gpio.h"
#include "Delay.h"
/*系统时钟配置为48MHz,AHB不分频,一次定时器时钟为48Mhz,因此得出以下分频值,匹配值*/
void Delay_Us(unsigned int DelayTimes)     /** setup timer #1 for delay */
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);     /*开启定时器Timer16_1时钟--时钟配置中开启该时钟*/
  LPC_TMR16B1->TCR = 0x02;               /* reset timer */
  LPC_TMR16B1->PR  = 3;                 /* set prescaler to zero 根据AHB时钟确定分频值*/
  LPC_TMR16B1->MR0 = DelayTimes;             /* 所需的延时时间 */
  LPC_TMR16B1->IR  = 0xff;               /* reset all interrrupts 复位所有的中断*/
  LPC_TMR16B1->MCR = 0x04;               /* stop timer on match --达到匹配停止*/
  LPC_TMR16B1->TCR = 0x01;               /* start timer 启动定时器*/
while (LPC_TMR16B1->TCR & 0x01);           /*等待直到时间到*/
LPC_TMR16B1->TCR = 0x00;               /* Close timer --关闭定时器*/
void Delay_Ms(unsigned int DelayTimes)       /** setup timer #1 for delay */
//LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8);       //开启定时器Timer16_1时钟
  LPC_TMR16B1->PR  = 3000;               /* set prescaler to zero */
  LPC_TMR16B1->IR  = 0xff;               /* reset all interrrupts */
  LPC_TMR16B1->MCR = 0x04;               /* stop timer on match */
  LPC_TMR16B1->TCR = 0x01;               /* start timer */
LPC_TMR16B1->TCR = 0x00;               /* Close timer */
void Delay_Sec(unsigned int DelayTimes)      /* * setup timer #1 for delay */
  LPC_TMR16B1->PR  = 3000000;           /* set prescaler to zero */
Delay.h程序:(延时程序使用Timer16_1实现)
#ifndef     __DELAY_H__
#define     __DELAY_H__
void Delay_Us(unsigned int DelayTimes);            /*微秒延时函数*/
void Delay_Ms(unsigned int DelayTimes);            /*毫秒延时函数*/
void Delay_Sec(unsigned int DelayTimes);          /*秒延时函数*/
#endif
