查看: 8847|回复: 1
STM32_W25x系列Flash芯片驱动程序(SPI调试通过)
ID:73735 发表于 2015-2-19 00:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
main.c文件:
#include "stm32f10x_it.h"
#include"hw_conf.h"
#include "spi_flash.h"
void delay(int d);
u8 DataByte=0;
u8 Tx_Buffer[] = {0x72,0x62,0x02,0x78,0x60,0x96,0x86,0x79,0x85,0x24,0x36,0x48};
u8 Rx_Buffer[BufferSize];
vu32 FLASH_ID = 0;
int main(void)
#ifdef DEBUG
  debug();
#endif
  Setup_System();
  SPI_FLASH_Init();
  //SPI_FLASH_ByteWrite(0x72, 0x01F01F);
  //DataByte = SPI_FLASH_ByteRead(0x01F01F);
  //DataByte = SPI_Flash_ReadStatusRegister();
  //SPI_FLASH_SectorErase(0x01F01F);
  //SPI_FLASH_BulkErase(0x01F01F);
  //SPI_FLASH_ChipErase();
  //DataByte = SPI_FLASH_FasttRead(0x01F01F);
  //DataByte = SPI_FLASH_ReadDeviceID();
  //SPI_FLASH_ReadManuID_DeviceID(0x000000);
  //SPI_FLASH_ReadJedecID();
  SPI_FLASH_PageWrite(Tx_Buffer, 0x01F01F, 10);
  SPI_FLASH_BufferRead(Rx_Buffer, 0x01F01F, 4);
  while (1)
    if(Rx_Buffer[0]==0x72)
      GPIO_WriteBit(GPIOC,GPIO_Pin_6,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_6)));
      delay(100);
    if(Rx_Buffer[1]==0x62)
      GPIO_WriteBit(GPIOC,GPIO_Pin_7,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_7)));
      delay(100);
    if(Rx_Buffer[2]==0x02)
      GPIO_WriteBit(GPIOC,GPIO_Pin_4,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_4)));
      delay(100);
    if(Rx_Buffer[3]==0x78)
      GPIO_WriteBit(GPIOC,GPIO_Pin_5,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOC,GPIO_Pin_5)));
      delay(100);
void delay(int d)
  int i = 0;
  for ( ;d;--d)
  for (i = 0;i<10000;i++);
Flash.c文件:
#include "stm32f10x_spi.h"
#define SPI_FLASH_PageSize 256
void SPI_FLASH_Init(void)
  SPI_FLASH_CS_HIGH();
  SPI_Flash_WP_HIGH();
  SPI_Flash_HOLD_HIGH();
void SPI_FLASH_WriteEnable(void)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(WriteEnable);
void SPI_FLASH_WriteDisable(void)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(WriteDisable);
u8 SPI_Flash_ReadStatusRegister(void)
  u8 StatusRegister = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ReadStatusRegister);
  StatusRegister = SPI_FLASH_ReceiveByte();
  return StatusRegister;
void SPI_Flash_WriteStatusRegister(u8 Byte)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(WriteStatusRegister);
  SPI_FLASH_SendByte(Byte);
u8 SPI_FLASH_SendByte(u8 byte)
  while(SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE) == RESET);
  SPI_SendData(SPI1, byte);
  while(SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET);
  return SPI_ReceiveData(SPI1);
u8 SPI_FLASH_ReceiveByte(void)
  return (SPI_FLASH_SendByte(Dummy_Byte));
u8 SPI_FLASH_ByteRead(u32 ReadAddr)
  u32 Temp = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(Read_Data);
  SPI_FLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((ReadAddr& 0xFF00) >> 8);
  SPI_FLASH_SendByte(ReadAddr & 0xFF);
  Temp = SPI_FLASH_ReceiveByte();
  //Temp = SPI_FLASH_SendByte(Dummy_Byte);
  return Temp;
u8 SPI_FLASH_FasttRead(u32 ReadAddr)
  u32 Temp = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(FastReadData);
  return Temp;
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead)
  SPI_FLASH_CS_LOW();
  while(NumByteToRead--)
    *pBuffer = SPI_FLASH_ReceiveByte();
    pBuffer++;
void SPI_FLASH_SectorErase(u32 SectorAddr)
  SPI_FLASH_WriteEnable();
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(SectorErace);
  SPI_FLASH_SendByte((SectorAddr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((SectorAddr & 0xFF00) >> 8);
  SPI_FLASH_SendByte(SectorAddr & 0xFF);
  SPI_FLASH_WaitForWriteEnd();
void SPI_FLASH_BulkErase(u32 BlockAddr)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(BlockErace);
  SPI_FLASH_SendByte((BlockAddr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((BlockAddr & 0xFF00) >> 8);
  SPI_FLASH_SendByte(BlockAddr & 0xFF);
void SPI_FLASH_ChipErase(void)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ChipErace);
void SPI_FLASH_PowerDown()
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(Power_Down);
void SPI_FLASH_ReleasePowerDown()
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ReleacePowerDown);
u8 SPI_FLASH_ReadDeviceID(void)
  u8 DeviceID = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ReadDeviceID);
  DeviceID = SPI_FLASH_ReceiveByte();
  return DeviceID;
u16 SPI_FLASH_ReadManuID_DeviceID(u32 ReadManu_DeviceID_Addr)
  u16 ManuID_DeviceID = 0;
  u8 ManufacturerID = 0,  DeviceID = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ReadManuIDDeviceID);
  SPI_FLASH_SendByte((ReadManu_DeviceID_Addr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((ReadManu_DeviceID_Addr & 0xFF00) >> 8);
  SPI_FLASH_SendByte(ReadManu_DeviceID_Addr & 0xFF);
  if(ReadManu_DeviceID_Addr==1)
    ManufacturerID = SPI_FLASH_ReceiveByte();
  ManuID_DeviceID = ((ManufacturerID<<8) | DeviceID);
  return ManuID_DeviceID;
u32 SPI_FLASH_ReadJedecID(void)
  u32 JEDECID = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(ReadJedec_ID);
  Temp0 = SPI_FLASH_ReceiveByte();
  Temp1 = SPI_FLASH_ReceiveByte();
  Temp2 = SPI_FLASH_ReceiveByte();
  JEDECID = (Temp0 << 16) | (Temp1 << 8) | Temp2;
  return JEDECID;
void SPI_FLASH_ByteWrite(u8 Byte, u32 WriteAddr)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(Page_Program);
  SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
  SPI_FLASH_SendByte(WriteAddr & 0xFF);
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
  SPI_FLASH_CS_LOW();
  while(NumByteToWrite--)
    SPI_FLASH_SendByte(*pBuffer);
    pBuffer++;
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
  u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
  Addr = WriteAddr % SPI_FLASH_PageSize;
  count = SPI_FLASH_PageSize - Addr;
  NumOfPage =  NumByteToWrite / SPI_FLASH_PageSize;
  NumOfSingle = NumByteToWrite % SPI_FLASH_PageSize;
  if(Addr == 0) /* WriteAddr is SPI_FLASH_PageSize aligned  */
    if(NumOfPage == 0) /* NumByteToWrite < SPI_FLASH_PageSize */
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumByteToWrite);
    else /* NumByteToWrite > SPI_FLASH_PageSize */
      while(NumOfPage--)
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, SPI_FLASH_PageSize);
        WriteAddr +=  SPI_FLASH_PageSize;
        pBuffer += SPI_FLASH_PageSize;
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumOfSingle);
  else /* WriteAddr is not SPI_FLASH_PageSize aligned  */
    if(NumOfPage== 0) /* NumByteToWrite < SPI_FLASH_PageSize */
      if(NumOfSingle > count) /* (NumByteToWrite + WriteAddr) > SPI_FLASH_PageSize */
        temp = NumOfSingle - count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, count);
        WriteAddr +=  count;
        pBuffer += count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, temp);
      NumByteToWrite -= count;
      WriteAddr +=  count;
      pBuffer += count;
      while(NumOfPage--)
      if(NumOfSingle != 0)
void SPI_FLASH_WaitForWriteEnd(void)
  u8 FLASH_Status = 0;
  SPI_FLASH_CS_LOW();
  do
    FLASH_Status = SPI_FLASH_SendByte(Dummy_Byte);
  } while((FLASH_Status & WriteStatusRegister) == SET);
Flash.h文件:#include "stm32f10x_lib.h"
#ifndef __SPI_FLASH_H
#define __SPI_FLASH_H
#define  BufferSize               (countof(Tx_Buffer)-1)
#define countof(a)                (sizeof(a) / sizeof(*(a)))
#define Dummy_Byte                0xA5
#define SPI_FLASH_CS_LOW()        GPIO_ResetBits(GPIOA, GPIO_Pin_4)
#define SPI_FLASH_CS_HIGH()       GPIO_SetBits(GPIOA, GPIO_Pin_4)
#define SPI_Flash_WP_LOW()        GPIO_ResetBits(GPIOC, GPIO_Pin_0)
#define SPI_Flash_WP_HIGH()       GPIO_SetBits(GPIOC, GPIO_Pin_0)
#define SPI_Flash_HOLD_LOW()      GPIO_ResetBits(GPIOC, GPIO_Pin_1)
#define SPI_Flash_HOLD_HIGH()     GPIO_SetBits(GPIOC, GPIO_Pin_1)
#define WriteEnable               0x06       //写使能,设置状态寄存器
#define WriteDisable              0x04       //写禁止
#define ReadStatusRegister        0x05       //读状态寄存器
#define WriteStatusRegister       0x01       //写状态寄存器
#define Read_Data                 0x03       //读取存储器数据
#define FastReadData              0x0B       //快速读取存储器数据
#define FastReadDualOutput        0x3B       //快速双端口输出方式读取存储器数据
#define Page_Program              0x02       //页面编程--写数据
#define BlockErace                0xD8       //块擦除
#define SectorErace               0x20       //扇区擦除
#define ChipErace                 0xC7       //片擦除
#define Power_Down                0xB9       //掉电模式
#define ReleacePowerDown          0xAB       //退出掉电模式
#define ReadDeviceID              0xAB       //获取设备ID信息
#define ReadDeviceID              0xAB       //退出掉电模式、设备ID信息
#define ReadManuIDDeviceID        0x90       //读取制造厂商ID信息和设备ID信息
#define ReadJedec_ID              0x9F       //JEDEC的ID信息
void SPI_FLASH_Init(void);
void SPI_FLASH_WriteEnable(void);
void SPI_FLASH_WriteDisable(void);
u8 SPI_Flash_ReadStatusRegister(void);
void SPI_Flash_WriteStatusRegister(u8 Byte);
u8 SPI_FLASH_SendByte(u8 byte);
u8 SPI_FLASH_ReceiveByte(void);
u8 SPI_FLASH_ByteRead(u32 ReadAddr);
u8 SPI_FLASH_FasttRead(u32 ReadAddr);
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead);
void SPI_FLASH_SectorErase(u32 SectorAddr);
void SPI_FLASH_BulkErase(u32 BlockAddr);
void SPI_FLASH_ChipErase(void);
void SPI_FLASH_PowerDown();
void SPI_FLASH_ReleasePowerDown();
u8 SPI_FLASH_ReadDeviceID(void);
u16 SPI_FLASH_ReadManuID_DeviceID(u32 ReadManu_DeviceID_Addr);
u32 SPI_FLASH_ReadJedecID(void);
void SPI_FLASH_ByteWrite(u8 Byte, u32 WriteAddr);
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite);
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite);
void SPI_FLASH_WaitForWriteEnd(void);
#endif
参与人数 1黑币 +5 收起 理由
544852010 + 5 很给力!
ID:235049 发表于 2017-9-23 10:32 | 只看该作者
哈哈哈哈哈,楼主你咋把我的程序转载到这儿来发表了啊,欢迎多多交流,多多指教。
