查看: 4207|回复: 0
STM8S-Discovery串口测试程序
ID:75926 发表于 2015-4-2 23:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include
<iostm8s105c6.h>
#include
<stdio.h>
#define BAUD_RATE     9600         //波特率
#define F_CPU         16000000     //CPU频率
//串口配置
//数据位:8
//停止位:1
//校验位:None
void UART_Init(void)
    UART2_CR2_TEN
= 1;
    UART2_CR2_REN
= 1;
    UART2_CR2_RIEN
= 1;
    UART2_BRR2
= ((unsigned char)((F_CPU / BAUD_RATE) & 0x0f)) + (((unsigned char)((F_CPU / BAUD_RATE) >> 8)) & 0xf0);
    UART2_BRR1
= ((unsigned char)((F_CPU / BAUD_RATE) >> 4));
void UART_TxByte(unsigned char _data)
while (UART2_SR_TXE == 0);
    UART2_DR
= _data;
int putchar(int c)
    UART_TxByte(c);
return c;
int main(void)
    CLK_SWCR_SWEN
= 1;
    CLK_SWR
= 0xB4;    //HSE selected as master clock source
    UART_Init();
    printf(
"********** STM8S-Discovery UART Test *********\r\n");
    printf(
"Build: %s  %s\r\n", __DATE__, __TIME__);
    asm(
"rim");
while (1)
#pragma vector = UART2_R_RXNE_vector
__interrupt
void UART2_IRQHandler(void)
if (UART2_SR_RXNE == 1)
        UART_TxByte(UART2_DR);
