查看: 6429|回复: 1
诺基亚5110屏的检测程序(图片和程序)51/52
ID:76190 发表于 2015-4-5 17:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//     COCOGUOJIA NOKIA 5110      //
//         PHILIPS PCD8544 48*48 LCD                    //
//头文件
#include <AT89X51.H>
#define u8  unsigned char
#define u16 unsigned int
u8 nop;
#define nop() nop++
u8 code character_table[]=
/*--  文字:  C  --*/
/*--  Trebuchet MS11;  此字体下对应的点阵为:宽x高=8x14   --*/
/*--  高度不是8的倍数,现调整为:宽度x高度=8x16  --*/
0xE0,0xF0,0x18,0x08,0x08,0x38,0x38,0x00,0x03,0x07,0x0C,0x08,0x08,0x0C,0x04,0x00,
/*--  文字:  O  --*/
0xE0,0xF0,0x18,0x08,0x18,0xF0,0xE0,0x00,0x03,0x07,0x0C,0x08,0x0C,0x07,0x03,0x00,
/*--  文字:  C  --*/
/*--  文字:  O  --*/
/*--  文字:  G  --*/
0xE0,0xF0,0x18,0x08,0x08,0x38,0x38,0x00,0x03,0x07,0x0C,0x08,0x09,0x0F,0x07,0x01,
/*--  文字:  U  --*/
0x08,0xF8,0xF8,0x08,0x08,0xF8,0xF8,0x08,0x00,0x07,0x0F,0x08,0x08,0x0F,0x07,0x00,
/*--  文字:  O  --*/
/*--  文字:  J  --*/
0x00,0x08,0x08,0xF8,0xF8,0x08,0x08,0x00,0x30,0x30,0x20,0x3F,0x1F,0x00,0x00,0x00,
/*--  文字:  I  --*/
0x00,0x08,0x08,0xF8,0xF8,0x08,0x08,0x00,0x00,0x08,0x08,0x0F,0x0F,0x08,0x08,0x00,
/*--  文字:  A  --*/
0x00,0x00,0xE0,0xF8,0xF8,0xE0,0x00,0x00,0x08,0x0E,0x0F,0x09,0x09,0x0F,0x0E,0x08,
u8 code Chinese_table[]=
/*--  文字:  欢  --*/
/*--  Trebuchet MS12;  此字体下对应的点阵为:宽x高=17x16   --*/
0x34,0x64,0xC4,0xE4,0x7C,0x3C,0x38,0x1F,0xEF,0xE8,0x08,0x28,0x38,0x18,0x08,
0x00,0x20,0x30,0x5C,0x4F,0x43,0x6F,0x2C,0x30,0x1C,0x0F,0x07,0x1E,0x38,0x70,0x60,
0x20
/*--  文字:  迎  --*/
,0x41,0xCF,0xCE,0x04,0xFC,0xFC,0x06,0x02,0xFE,0xFC,0x04,0x04,0xFC,0xFC,0x00,
0x00,0x40,0x60,0x3F,0x3F,0x60,0x47,0x47,0x43,0x41,0x5F,0x5F,0x42,0x46,0x47,0x43,
0x40
/*--  文字:  光  --*/
,0x40,0x42,0x46,0x5C,0xDC,0xC8,0x7F,0x7F,0xC0,0xD0,0x5E,0x4E,0x64,0x60,0x40,
0x00,0x00,0x80,0xC0,0x60,0x38,0x1F,0x07,0x00,0x00,0x3F,0x7F,0x40,0x40,0x40,0x78,
0x78
/*--  文字:  临  --*/
,0xF8,0xF8,0x00,0xFE,0xFE,0x70,0xBF,0x8F,0x0A,0x18,0x78,0x68,0x88,0x88,0x08,
0x00,0x00,0x1F,0x1F,0x00,0x7F,0x7F,0x00,0x7F,0x7F,0x21,0x3F,0x3F,0x21,0x7F,0x7F,
0x01
//管脚定义(起个小名了~) lcd的内部驱动是PCD8544,一下的芯片即为PCD8544
sbit    RST = P0^1;  //芯片复位     0有效
sbit    SCE = P0^0;  //芯片使能 0有效
sbit    D_C = P3^4;  //模式选择     1写数据   0写指令
sbit    DIN = P3^5;  //串行数据线 数据类型---8位
sbit    SCK = P3^6;  //串行时钟线   上升沿有效
//delay_1ms: 大约延时1ms
void delay_1ms(void)//1ms延时函数
u16 i;
for (i=0;i<500;i++)
//LCD_Write_Byte: 写数据或命令到LCD
//输入参数:u8 Data_or_Command:要写入的数据或命令;
// u8 D_or_C  :1 写数据/ 0 写命令
void LCD_Write_Byte(u8 Data_or_Command,u8 D_or_C)
u8 i;
SCE=0;//选择芯片
D_C=D_or_C;// 数据? 命令?
for(i=0;i<8;i++)//写
if(0x80==(Data_or_Command&0x80))
DIN=1;
DIN=0;
Data_or_Command<<=1;//移位
//造个上升沿
SCK=0;
nop();
nop();
nop();
nop();
SCK=1;
//回复到安全状态 保险
D_C=1;
SCE=1;
DIN=1;
//LCD_init: LCD初始化
void LCD_init(void)
RST=0;
   delay_1ms();
   RST=1;
delay_1ms();
LCD_Write_Byte(0x21,0);//初始化Lcd,功能设定使用扩充指令
LCD_Write_Byte(0xd0,0);//设定液晶偏置电压
LCD_Write_Byte(0x20,0);//使用基本指令 水平寻址
//LCD_Write_Byte(0x0C,0);//设定显示模式,正常显示
LCD_Write_Byte(0x0D,0);  //设定显示模式,反白显示
//LCD_Set_XY: 设置LCD坐标函数 用于准备显示高度是‘8个点’的汉字或字母
//输入参数:X:0-83  Y:0-5
void LCD_Set_XY(u8 X, u8 Y)
LCD_Write_Byte(0x40 | Y, 0);// 竖
LCD_Write_Byte(0x80 | X, 0);// 横
//LCD_Clear: LCD清屏函数
void LCD_Clear(void)
u8 x;
u8 y;
LCD_Set_XY(0,0);
for(y=0;y<=5;y++)
for(x=0;x<=83;x++)
LCD_Write_Byte(0x00,1);
//LCD_Write_ABC: 显示8(宽)*16(高)点阵列数字字母符号等半角类
//输入参数: x:
// y:
// ABC:显示的字符的序号
void LCD_Write_ABC(u8 x, u8 y,u8 ABC) //x:横 y:竖 ABC:字符的序号
u8 i;
LCD_Set_XY(x*8, y);//横 ,竖
for(i=0; i<8;i++)
LCD_Write_Byte(character_table[ABC*16+i],1);
    LCD_Set_XY(x*8, y+1);//横 ,竖
for(i=8; i<16;i++)
//LCD_Write_Chinese: 显示16(宽)*16(高)点阵列汉字等半角类
//输入参数:
// x:
// y:
// Chinese:显示的汉字的序号
void LCD_Write_Chinese(u8 x, u8 y,u8 Chinese)
unsigned char i;
LCD_Set_XY(x*8, y);// 列,页
for(i=0; i<16;i++)
LCD_Write_Byte(Chinese_table[Chinese*32+i],1);
    LCD_Set_XY(x*8, y+1);// 列,页
for(i=16; i<32;i++)
void main(void)
unsigned char k;
RST=0;
for(k=0;k<250;k++);
RST=1;
LCD_init();
LCD_Clear();
LCD_Write_ABC(0,1,0);
LCD_Write_ABC(1,1,1);
LCD_Write_ABC(2,1,2);
LCD_Write_ABC(3,1,3);
LCD_Write_ABC(4,1,4);
LCD_Write_ABC(5,1,5);
LCD_Write_ABC(6,1,6);
LCD_Write_ABC(7,1,7);
LCD_Write_ABC(8,1,8);
LCD_Write_ABC(9,1,9);
    LCD_Write_Chinese(1,3,0);
LCD_Write_Chinese(3,3,1);
LCD_Write_Chinese(5,3,2);
LCD_Write_Chinese(7,3,3);
//头文件
u8 nop;
#define nop() nop++
u8 code pic_table[]=
/*--  宽度x高度=80x40  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x80,0x80,0x80,0xC0,0xC0,0xC0,0xE0,0xE0,0xE0,0x60,0x70,0x70,0x30,0x38,0x38,
0x18,0x18,0x1C,0x1C,0x0C,0x0C,0x8C,0x8E,0xCE,0xC6,0xE6,0xE6,0xE2,0xF2,0xF2,0xF0,
0xF0,0xF0,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF8,0xF0,0xF0,
0xF0,0xF0,0xE0,0xE0,0xE0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,
0x0C,0x0C,
0x80,0x80,0xC0,0xE0,0xF0,0xF0,0xF8,0xF8,0xFC,0xFC,
0xFE,0xFE,0xFF,0x3F,0x1F,0x0F,0x07,0x07,0x03,0x01,0x01,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0xF8,0xFC,0xFE,0xFE,0xFF,0xFF,0x7F,0x7F,0x7F,0x3F,0x3F,0x3F,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x7F,0x7F,0x7B,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,
0xF8,0xF8,0xF8,0xFC,0xFC,0xFE,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xF8,0xF8,0xF0,0xF0,0xF0,0xE0,0xE0,0xE0,
0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC1,0xC3,0xC7,0xC7,0xC7,0xC7,0xC6,
0xC6,0xC6,0xC6,0xC6,0xC6,0xC6,0xC6,0xC6,0xC6,0xE6,0xEE,0xEE,0xFE,0xFC,0xFC,0xFC,
0xF8,0xF8,0xF0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x01,0x01,0x83,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xBF,0x0F,0x0F,0x07,0x03,0x01,0x01,0x00,0x00,0x00,0x01,0x01,
0x01,0x1D,0x3F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x7F,0x3F,0x3F,0x3F,
0x1F,0x1F,0x0F,0x0F,0x07,0x03,0x01,0x80,0xC0,0xC0,0xC0,0xE0,0x60,0x60,0x70,0x30,
0x38,0x18,0x1C,0x1C,0x0E,0x0E,0x07,0x07,0x03,0x03,0x01,0x01,0x00,0x00,
0x00,0x00,0x01,0x01,0x03,0x03,0x03,0x07,0x06,0x06,0x04,0x04,0x04,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,
0x00,0x00
u16 i;
for (i=0;i<500;i++)
//delay_3s: 大约延时3s 里面的1ms的延时不太准
void delay_3s(void)
u16 i;
for(i=1;i<=1200;i++)
delay_1ms();
u8 i;
SCE=0;//选择芯片
for(i=0;i<8;i++)//写
DIN=1;
DIN=0;
//造个上升沿
SCK=0;
nop();
nop();
nop();
nop();
SCK=1;
//回复到安全状态 保险
D_C=1;
SCE=1;
DIN=1;
//LCD_init: LCD初始化
void LCD_init(void)
RST=0;
   delay_1ms();
   RST=1;
delay_1ms();
//LCD_Write_Byte(0x0D,0);  //设定显示模式,反白显示
//输入参数:X:0-83  Y:0-5
u8 x;
u8 y;
LCD_Set_XY(0,0);
for(y=0;y<=5;y++)
for(x=0;x<=83;x++)
//LCD_Clear: LCD清屏函数 从0开始计数的 第5行
void LCD_Clear5(void)
u8 x;
LCD_Set_XY(0,5);
for(x=0;x<=83;x++)
LCD_Write_Byte(0xFF,1);
//LCD_Write_pic: 显示 80(宽)* 8(高) 做图
//输入参数:
// x:
// y:
// pic: 图片 高8 宽80 的图片截图 序号
void LCD_Write_pic(u8 x, u8 y,u8 pic)
unsigned char i;
for(i=0; i<80;i++)
LCD_Write_Byte(pic_table[pic*80+i],1);
void main(void)
LCD_init();
LCD_Clear();
LCD_Write_pic(0,0,0);
LCD_Write_pic(0,1,1);
LCD_Write_pic(0,2,2);
LCD_Write_pic(0,3,3);
LCD_Write_pic(0,4,4);
     delay_3s();
    LCD_Clear();
LCD_Clear5();
delay_3s();
    LCD_Clear();
收藏收藏2 分享淘帖 顶顶 踩踩
ID:71423 发表于 2015-4-12 21:58 | 只看该作者
谢谢楼主分享
