查看: 3646|回复: 0
12864液晶程序(书上的—我改了一下我的实验板才可以用)
ID:76556 发表于 2015-4-10 01:53 | 显示全部楼层 |阅读模式
#include <reg51.h>
#include <intrins.h>
#include <stdlib.h>
#define uint  unsigned int
/* 端口定义*/
#define LCD_data  P0             //数据口
sbit LCD_RS  =  P1^0;            //寄存器选择输入
sbit LCD_RW  =  P1^1;            //液晶读/写控制
sbit LCD_EN  =  P1^5;            //液晶使能控制
sbit LCD_PSB =  P3^7;            //串/并方式控制
sbit wela    =  P2^6;
sbit dula    =  P2^7;
uchar dis1[10];
uchar code dis2[] = {"www*txmcu*com"};
uchar code dis3[] = {"天祥电子"};
uchar code dis4[] = {"--------"};
void delay_1ms(uint x)
uint i,j;
for(j=0;j<x;j++)
        for(i=0;i<110;i++);
/*写指令数据到LCD                                                  */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。                             */
void write_cmd(uchar cmd)
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = cmd;
        delay_1ms(5);
    LCD_EN = 1;
        delay_1ms(5);
    LCD_EN = 0;
/*写显示数据到LCD                                                  */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。                               */
void write_dat(uchar dat)
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
        delay_1ms(5);
    LCD_EN = 1;
        delay_1ms(5);
    LCD_EN = 0;
/* 设定显示位置                                          */
void lcd_pos(uchar X,uchar Y)
   uchar  pos;
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
   pos = X+Y ;
   write_cmd(pos);     //显示地址
void makerand()
        uint ran;
        ran=rand();
        dis1[0]=ran/10000+0x30;
        dis1[1]=ran%10000/1000+0x30;
        dis1[2]=ran%1000/100+0x30;
        dis1[3]=ran%100/10+0x30;
        dis1[4]=ran%10+0x30;
        ran=rand();
        dis1[5]=ran/10000+0x30;
        dis1[6]=ran%10000/1000+0x30;
        dis1[7]=ran%1000/100+0x30;
        dis1[8]=ran%100/10+0x30;
        dis1[9]=ran%10+0x30;
/*  LCD初始化设定                                                  */
void lcd_init()
    LCD_PSB = 1;         //并口方式
    write_cmd(0x30);      //基本指令操作
    delay_1ms(5);
    write_cmd(0x0C);      //显示开,关光标
    delay_1ms(5);
    write_cmd(0x01);      //清除LCD的显示内容
    delay_1ms(5);
/* 主程序        */
main()
    uchar i;
    wela=0;
        dula=0;
    delay_1ms(10);                 //延时
    lcd_init();                 //初始化LCD
    lcd_pos(1,0);             //设置显示位置为第二行的第1个字符
    i = 0;
    while(dis2[i] != '\0')
       write_dat(dis2[i]);      //显示字符
       i++;
        lcd_pos(2,0);             //设置显示位置为第三行的第1个字符
    i = 0;
    while(dis3[i] != '\0')
       write_dat(dis3[i]);      //显示字符
       i++;
        lcd_pos(3,0);             //设置显示位置为第四行的第1个字符
    i = 0;
    while(dis4[i] != '\0')
       write_dat(dis4[i]);      //显示字符
       i++;
                lcd_pos(0,0);   //设置显示位置为第一行的第1个字符
                makerand();
                for(i=0;i<10;i++)
                    write_dat(dis1[i]);
