查看: 6673|回复: 0
无线收发模块NRF2401驱动
ID:75926 发表于 2015-4-10 16:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define NRF_MOSI_LOW()
#define NRF_MOSI_HIGH()
#define NRF_MISO_Read()
#define NRF_CS_LOW()
#define NRF_CS_HIGH()
#define NRF_SCK_LOW()
#define NRF_SCK_HIGH()
#define NRF_CE_LOW()
#define NRF_CE_HIGH()
#define NRF_IRQ_Read()
#define AddressWIDTH5  //地址的宽度
#define DataWIDTH4 //数据宽度
// SPI(nRF24L01) commands ,
#define NRF_READ_REG    0x00  // Define read command to register
#define NRF_WRITE_REG   0x20  // Define write command to register
#define RD_RX_PLOAD 0x61  // Define RX payload register address
#define WR_TX_PLOAD 0xA0  // Define TX payload register address
#define FLUSH_TX    0xE1  // Define flush TX register command
#define FLUSH_RX    0xE2  // Define flush RX register command
#define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
#define NOP         0xFF  // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses) ,NRF24L01 相关寄存器地址的宏定义
#define CONFIG      0x00  // 'Config' register address
#define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
#define SETUP_AW    0x03  // 'Setup address width' register address
#define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
#define RF_CH       0x05  // 'RF channel' register address
#define RF_SETUP    0x06  // 'RF setup' register address
#define STATUS      0x07  // 'Status' register address
#define OBSERVE_TX  0x08  // 'Observe TX' register address
#define CD          0x09  // 'Carrier Detect' register address
#define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
#define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
#define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
#define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
#define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
#define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
#define TX_ADDR     0x10  // 'TX address' register address
#define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
#define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
#define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
#define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
#define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
#define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
#define MAX_RT      0x10 //达到最大重发次数中断标志位
#define TX_DS0x20 //发送完成中断标志位  //
#define RX_DR0x40 //接收到数据中断标志位
#define CHANAL40
typedef enum
    NRF_RxMode,
    NRF_TxMode,
}NRF_ModeTypeDef;
static uint8_t NRF_Address[AddressWIDTH]={0xcc,0xcc,0xcc,0xcc,0xcc};//定义NRF的收发地址
static void NRF_Delay(uint32_t )  //延时t微妙
    /* STM32下的代码*/
        SysTick->VAL=0;
        SysTick->LOAD=t*168;
        SysTick->CTRL|=1<<0;
        while(!SysTick->CTRL&(1<<16));
        SysTick->CTRL&=~(1<<0);
static uint8_t SPI_SR_Byte(uint8_t Byte)
    uint8_t Buff=0,Cnt;
    NRF_SCK_LOW();
    for(Cnt=0;Cnt<8;Cnt++)
        if(Byte&0x80)
            NRF_MOSI_HIGH();
            NRF_MOSI_LOW();
        Byte<<=1;
        Buff<<=1;
        NRF_SCK_HIGH();
        if(NRF_MISO_Read())
            Buff++;
        NRF_SCK_LOW();
    return Buff;
static uint8_t NRF_WriteReg(uint8_t Reg,uint8_t Data)
    uint8_t Status;
    NRF_CS_LOW();
    Status=NRF_SR_Byte(Reg);
    NRF_SR_Byte(Data);
    NRF_CS_HIGH();
    return Status;
static uint8_t NRF_WriteBuff(uint8_t Reg,uint8_t *pData,uint8_t Cnt)
    uint8_t Status;
    NRF_CS_LOW();
    for(;Cnt>0;Cnt--)
        NRF_SR_Byte(*pBuff++);
    NRF_CS_HIGH();
    return Status;
static uint8_t NRF_ReadReg(uint8_t Reg)
    uint8_t Status;
    NRF_CS_LOW();
    NRF_SR_Byte(Reg);
    Status=NRF_SR_Byte(0xff);
    NRF_CS_HIGH();
    return Status;
static uint8_t NRF_ReadBuff(uint8_t Reg,uint8_t *pBuff,uint8_t Cnt)
    uint8_t Status;
    NRF_CS_LOW();
    NRF_SR_Byte(Reg);
    for(;Cnt>0;Cnt--)
        *pBuff=NRF_SR_Byte(0xff);
        pBuff++;
    NRF_CS_HIGH();
    return Status;
void NRF_ModeInit(NRF_ModeTypeDef    NRF_Mode)
    if(NRF_Mode==NRF_TxMode)
        NRF_CE_LOW();
        NRF_WriteBuff(NRF_WRITE_REG+TX_ADDR,NRF_Address,AddressWIDTH);
        NRF_WriteBuff(NRF_WRITE_REG+RX_ADDR_P0,NRF_Address,AddressWIDTH);
NRF_WriteReg(NRF_WRITE_REG+EN_AA,0x01);     //使能通道0的自动应答            NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
        NRF_WriteReg(NRF_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次
        NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);       //设置RF通道为CHANAL
        NRF_WriteReg(NRF_WRITE_REG+RF_SETUP,0x0f);  //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
        NRF_WriteReg(NRF_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,发射模式,开启所有中断
/*CE拉高,进入发送模式*/
        NRF_CE_HIGH();
        NRF_Delay(0xfff); //CE要拉高一段时间才进入发送模式
NRF_CE_LOW();        NRF_WriteBuff(NRF_WRITE_REG+RX_ADDR_P0,NRF_Address,AddressWIDTH);//写RX节点地址
        NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
        NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);      //设置RF通信频率
        NRF_WriteReg(NRF_WRITE_REG+RX_PW_P0,DataWIDTH);//选择通道0的有效数据宽度
        NRF_WriteReg(NRF_WRITE_REG+CONFIG, 0x0f);  //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式
/*CE拉高,进入接收模式*/
        NRF_CE_HIGH();
uint8_t NRF_TxData(uint8_t *pBuff)
    uint8_t Status;
    NRF_CE_LOW();
    NRF_WriteBuff(WR_TX_PLOAD,pBuff,DataWIDTH);
    NRF_CE_HIGH();
    while(!NRF_IRQ_Read());
    Status=NRF_ReadReg(STATUS);
     /*清除TX_DS或MAX_RT中断标志*/
    NRF_WriteReg(NRF_WRITE_REG+STATUS,Status);
    NRF_WriteReg(FLUSH_TX,NOP);    //清除TX FIFO寄存器
     /*判断中断类型*/
    if(Status&MAX_RT)                     //达到最大重发次数
         return MAX_RT;
    else if(Status&TX_DS)                  //发送完成
         return TX_DS;
        return ERROR;                 //其他原因发送失败
uint8_t NRF_RxData(uint8_t *pBuff)
    uint8_t Status;
    NRF_CE_HIGH(); //进入接收状态
     /*等待接收中断*/
    while(NRF_IRQ_Read()!=0);
    NRF_CE_LOW();   //进入待机状态
    /*读取status寄存器的值  */
    /* 清除中断标志*/
    /*判断是否接收到数据*/
    if(Status&RX_DR)                                 //接收到数据
        NRF_ReadBuff(RD_RX_PLOAD,pBuff,DataWIDTH);//读取数据
        NRF_WriteReg(FLUSH_RX,NOP);          //清除RX FIFO寄存器
        return RX_DR;
        return ERROR;                    //没收到任何数据
uint8_t NRF_Check(void)
    uint8_t TxBuff[5]={0xaa,0xaa,0xaa,0xaa,0xaa};
    uint8_t RxBuff[5],Cnt=5;
    NRF_WriteBuff(NRF_WRITE_REG+TX_ADDR,TxBuff,5);
    NRF_ReadBuff(TX_ADDR,RxBuff,5);
    for(Cnt=0;Cnt<5;Cnt++)
        if(RxBuff[Cnt]!=0xaa)
            return 1;//错误
    return 0;//连接正确
收藏收藏3 分享淘帖 顶顶 踩踩
