查看: 5536|回复: 12
这程序什么意思啊
ID:77138 发表于 2015-4-16 12:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RS  BIT P2.0     //定义接口
RW  BIT P2.1
E   BIT P2.2
ORG 0000H
SJMP START
ORG  0030H
START:
LCALL LCDINIT
MAIN:
        MOV A,#80H
        LCALL BUSY
        LCALL WRTC
        MOV  R2,#04H
        MOV  DPTR,#TAB1
        LCALL DELAY
        LCALL WRTD
        MOV A,#0C0H
        LCALL BUSY
        LCALL WRTC
MOV  R2,#04H
        MOV  DPTR,#TAB2
        LCALL DELAY
        LCALL WRTD
LCALL DELAY1
LCALL DELAY1
MOV A,#01H
        LCALL BUSY
        LCALL WRTC
MOV A,#80H
        LCALL BUSY
        LCALL WRTC
        MOV  R2,#0FH
        MOV  DPTR,#TAB4
        LCALL DELAY
        LCALL WRTD
LCALL DELAY1
LCALL DELAY1
    MOV A,#01H
        LCALL BUSY
        LCALL WRTC
MOV A,#80H
        LCALL BUSY
        LCALL WRTC
        MOV  R2,#0FH
        MOV  DPTR,#TAB5
        LCALL DELAY
        LCALL WRTD
LCALL DELAY1
LCALL DELAY1
    MOV A,#01H
        LCALL BUSY
        LCALL WRTC
   LJMP MAIN
LCDINIT:
        LCALL  DELAY
        LCALL  DELAY
        LCALL  DELAY
        MOV  A,#38H
        LCALL WRTC
        LCALL DELAY
        MOV  A,#38H
        LCALL WRTC
        LCALL DELAY
        MOV  A,#38H
        LCALL WRTC
        LCALL DELAY
        MOV  A,#38H
        LCALL BUSY
        LCALL WRTC
        MOV  A,#08H
        LCALL BUSY
        LCALL WRTC
        MOV A,#01H
        LCALL BUSY
        LCALL WRTC
        MOV  A,#06H
        LCALL BUSY
        LCALL WRTC
        MOV A,#0CH
        LCALL BUSY
        LCALL WRTC
MOV    A,#40H
LCALL BUSY
        LCALL   WRTC
      MOV   R2,#40H
        MOV   DPTR,#TAB3
LCALL BUSY
LCALL WRTD
        RET
WRTC:
      CLR RS
      CLR RW
      CLR E
      MOV P0,A
          LCALL DELAY ;延时5ms
          SETB E
          LCALL DELAY ;延时5ms
      CLR E
      RET
WRTD:    MOV R1,#00H
AGAIN:   MOV A,R1
         MOVC A,@A+DPTR
         SETB RS
         CLR  RW
         CLR  E
         MOV  P0,A
         LCALL DELAY
         SETB E
         LCALL DELAY
         CLR E
         INC  R1
         MOV  A,R1
         MOV  B,R2
         CJNE A,B,AGAIN
         RET
BUSY:
        PUSH ACC
        CLR  RS
        SETB RW
TT0:    SETB E
        MOV A,P0
        CLR E
        ANL A,#80H
        JNZ TT0
        POP ACC
        RET
TAB1:
          DB 00H,01H,02H,03H
TAB2:
          DB 04H,05H,06H,07H
TAB3:
         DB 03H,07H,0fH,1FH,1FH,1FH,1FH,1FH
         DB 18H,1EH,1FH,1FH,1FH,1FH,1FH,1FH
         DB 07H,1FH,1FH,1FH,1FH,1FH,1FH,1FH
         DB 10H,18H,1cH,1EH,1EH,1EH,1EH,1EH
         DB 0FH,07H,03H,01H,00H,00H,00H,00H
         DB 1fH,1FH,1FH,1FH,1FH,0FH,07H,01H
         DB 1fH,1FH,1FH,1FH,1FH,1CH,18H,00H
         DB 1CH,18H,10H,00H,00H,00H,00H,00H
TAB4:    DB " Electrical 516 "
TAB5:         DB " CS UNIVERSITY "
DELAY:  MOV R6,#10
D1:     MOV R7,#250
        DJNZ R7,$
        DJNZ R6,D1
        RET
DELAY1:
    MOV R3,#30H
DL1:
    MOV R4,#26H
DL0:
    MOV R5,#82H
    DJNZ R5,$
    DJNZ R4,DL0
    DJNZ R3,DL1
    RET
ID:43559 发表于 2015-4-16 21:53 | 只看该作者
汇编语言写的程序。
RS  BIT P2.0     //定义接口
RW  BIT P2.1
E   BIT P2.2
这几行代码是定义LCD数据命令,读写,使能端。
汇编语言的程序知道得少,不能乱说。懂得大侠来。
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:76800 发表于 2015-4-17 07:51 | 只看该作者
我也不懂,只看出是一个特殊的LCD初始化,没去了解发那些指令是什么意思,然后显示轮流显示4个表格的内容。没有特殊功能,仅仅是一个练习程序。
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:63484 发表于 2015-4-18 09:59 | 只看该作者
类似于LCD16**系列的控制程序
,汇编语言
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:77329 发表于 2015-4-18 11:46 来自触屏版 | 只看该作者
汇编语言不会
ID:77448 发表于 2015-4-19 21:59 | 只看该作者
没接触汇编语言
ID:153199 发表于 2017-3-6 12:47 | 只看该作者
LCD初始化
ID:68499 发表于 2017-3-6 22:32 | 只看该作者
很久不用汇编语言了。
ID:168631 发表于 2017-3-7 12:41 | 只看该作者
汇编语言。。不会,现在一般都C语言
ID:168862 发表于 2017-3-7 16:25 | 只看该作者
试试反编译再读读C?
ID:139514 发表于 2017-3-7 16:55 | 只看该作者
沒有一些些註解我也看不懂你這在寫什麼,麻煩給註解
ID:168920 发表于 2017-3-7 19:54 | 只看该作者
汇编,太难了,用c吧还是
ID:168949 发表于 2017-3-7 20:52 | 只看该作者
定义各种字节,没想到汇编语言这么有用,想当年我学的通透,如今都忘 了。
