查看: 3134|回复: 0
跳表SkipList
ID:77367 发表于 2015-4-18 20:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    跳表是平衡树的一种替代的数据结构,但是和红黑树不相同的是,跳表对于树的平衡的实现是基于一种随机化的算法的,这样也就是说跳表的插入和删除的工作是比较简单的。
一个测试程序示例, 下载压缩包中已经包含(这里的源代码对不齐):
// test.cpp
#include <iostream>
#include <iomanip>
#include <cstdlib>
#include <time.h>
#include "skiplist.h"
#include "TimeCounter.h"
#define TIME_START CTimeCounter* pT = new CTimeCounter()
#define TIME_END   ShowTime(pT->GetExecutionTime())
// Show execution time (ms)
void ShowTime(__int64 nTime)
        std::cout << "========================================" << std::endl;
        std::cout << "                    Total time: ";
        std::cout << std::fixed << std::setprecision(1) << std::setw(6);
        std::cout << nTime;
        std::cout << " ms" << std::endl << std::endl;
        //printf("Usage time: %I64d millisecond\n\n", nTime); //在g++中对应的是<stdint.h> int64_t, 应该用%lld输出
int main(){
        int count = 10, i;
        SkipList sl;
        srand((unsigned)time(NULL));
        std::cout<<"### Function Test ###\n\n";
        std::cout<<"\n=== Init Skip List ===\n\n";
        sl.Init();
        for ( i = 0; i < count; i++) {
                sl.Insert(i);
        std::cout<<"\n=== Print Skip List ===\n\n";
        sl.Print();
        printf("\n=== Search Skip List ===\n\n");
        TIME_START;
        for (i = 0; i < count; i++) {
                int value = rand()%(count+10);
                sl.Search(value);
        TIME_END;
        std::cout<<"\n=== Delete Skip List ===\n\n";
        char buf[256], *p = buf;
        for (i = 0; i < count+10; i+=2) {
                sprintf_s(buf, "Delete[%d]:%s\n", i, sl.Delete(i) ? "SUCCESS":"NOT FOUND");
                        std::cout<<buf;
        std::cout<<"\n\n";
        sl.Print();
        sl.Free();
        //或者Ctrl+F5调试
        getchar();
