查看: 4577|回复: 0
STM32F4xx_DSP_StdPeriph_Lib_V1.3.0中的systick延时
ID:77367 发表于 2015-4-19 01:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1】
  * @file    Project/STM32F4xx_StdPeriph_Templates/main.c
  * @author  MCD Application Team
  * @version V1.3.0
  * @date    13-November-2013
  * @brief   Main program body
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t uwTimingDelay;
RCC_ClocksTypeDef RCC_Clocks;
int main(void)
  /* SysTick end of count event each 10ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 100);
  Delay(5);
  while (1)
  * @brief  Inserts a delay time.
  * @param  nTime: specifies the delay time length, in milliseconds.
  * @retval None
void Delay(__IO uint32_t nTime)
  uwTimingDelay = nTime;
  while(uwTimingDelay != 0);
  * @brief  Decrements the TimingDelay variable.
  * @param  None
  * @retval None
void TimingDelay_Decrement(void)
  if (uwTimingDelay != 0x00)
    uwTimingDelay--;
2】
  * @file    Project/STM32F4xx_StdPeriph_Templates/main.h
  * @version V1.3.0
  * @brief   Header for main.c module
  * @attention
  * <h2><center>© COPYRIGHT 2013 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __MAIN_H
#define __MAIN_H
#include "stm32f4xx.h"
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
void TimingDelay_Decrement(void);
#endif /* __MAIN_H */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
3】
  * @file    Project/STM32F4xx_StdPeriph_Templates/stm32f4xx_it.c
  * @version V1.3.0
  * @brief   Main Interrupt Service Routines.
  *          This file provides template for all exceptions handler and
  *          peripherals interrupt service routine.
  * @attention
#include "stm32f4xx_it.h"
#include "main.h"
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
/*            Cortex-M4 Processor Exceptions Handlers                         */
  * @brief  This function handles NMI exception.
  * @param  None
  * @retval None
void NMI_Handler(void)
  * @brief  This function handles Hard Fault exception.
  * @param  None
  * @retval None
void HardFault_Handler(void)
  /* Go to infinite loop when Hard Fault exception occurs */
  while (1)
  * @brief  This function handles Memory Manage exception.
  * @param  None
  * @retval None
void MemManage_Handler(void)
  /* Go to infinite loop when Memory Manage exception occurs */
  while (1)
  * @brief  This function handles Bus Fault exception.
  * @param  None
  * @retval None
void BusFault_Handler(void)
  /* Go to infinite loop when Bus Fault exception occurs */
  while (1)
  * @brief  This function handles Usage Fault exception.
  * @param  None
  * @retval None
void UsageFault_Handler(void)
  /* Go to infinite loop when Usage Fault exception occurs */
  while (1)
  * @brief  This function handles SVCall exception.
  * @param  None
  * @retval None
void SVC_Handler(void)
  * @brief  This function handles Debug Monitor exception.
  * @param  None
  * @retval None
void DebugMon_Handler(void)
  * @brief  This function handles PendSVC exception.
  * @param  None
  * @retval None
void PendSV_Handler(void)
  * @brief  This function handles SysTick Handler.
  * @param  None
  * @retval None
void SysTick_Handler(void)
  TimingDelay_Decrement();
