查看: 7730|回复: 5
发一个单片机红外测速、调速程序
采用80c51单片机进行测速调速。
nclude <reg51.h>
#include <intrins.h>
unsigned char code lcd[]={"speed0k"};
unsigned char code table[]= {"0123456789"};
unsigned char code pin[]={"Hz"};
unsigned char zhuan[5];
unsigned char shi=20;
unsigned int  y,jia;
sbit rd=P2^7;
sbit rw=P2^6;
sbit e=P2^5;
sbit kong=P3^0;
void delay1(unsigned char ms)  //延时函数
        unsigned char j;
        while(ms--)
                for(j=0;j<125;j++);
void delay()//延时函数
        _nop_();
        _nop_();
        _nop_();
bit du()//LCD读忙状态
        bit s;
        rw=1;
        rd=0;
        delay();
        e=1;
        delay();
        s=(bit)(P0&0x80);
        e=0;
        return  s;
void xie(unsigned char com)//LCD写命令
        while (du());
        rd=0;
        rw=0;
        delay();
        e=0;
        P0=com;
        e=1;
        delay();
//        delay1(20);
void xieshuju(unsigned char dat)//LCD写数据
        while (du());
        rw=0;
        rd=1;
        delay();
        e=0;
        P0=dat;
        e=1;
        delay();
        e=0;
void chushihua()//LCD初始化
        xie(0x38);
        xie(0x0c);
        xie(0x01);
        xie(0x06);
void delayms (unsigned char time)//延时函数
        unsigned char  i,j;
        for(i=0;i<time;i++)        ;
        e=0;
        for(j=100;j>1;j--) ;
void tiaosu(unsigned int shi1)//电机调速
        kong=0;
        delayms(5);
        kong=1;
        delayms(shi1);
unsigned char keycan()//按键返回值函数
                static         unsigned char key;
                if(P3!=0xff)
                delay1(10);
                if(P3!=0xff)
                key=P3&0Xff;
                if(P3==0xfd)
                jia=jia+5;
                if(P3==0xfb)
                jia=jia-5;
                if(jia<=5)
                jia=3;
        while(P3!=0xff);
    return(key);
void zhuanhuan()  //电机转速数据处理
        zhuan[0]=table[y/1000%10];
    zhuan[1]=table[y/100%10];
    zhuan[2]=table[y/10%10];
           zhuan[3]=table[y%10];
void main ()
        unsigned char  wei;
        unsigned char w=0;
        EA=1;
        TR0=1;
        ET0=1;
        TR1=1;
        ET1=1;
        TH0=0x3c;
        TL0=0xb0;
        TH1=0x00;
        TL1=0x00;
        TMOD=0x51;
        chushihua();
        delay1(20);      //在这里如果时间不过长的话 控制位置无用
        xie(0x84);
        delay();
        while (lcd[w]!='\0')//LCD显示cesuji
                xieshuju(lcd[w]);
                w++;
         delay();
        w=0;
        xie(0xca);
        while (pin[w]!='\0')//LCD显示hz
                xieshuju(pin[w]);
                w++;
                delay();
    while (1)
                wei=keycan();
                switch (wei)
                        case 0xfe:  kong=0;        break;//电机全速启动
                        case 0xfd:
                        case 0xfb:  tiaosu(jia);break;
                        case 0xf7:  kong=1;        break;//电机停止
void zhongduan()  interrupt 1   //中断  刷新数据
        unsigned char i;
          TH0=0x3c;
          TL0=0xb0;  //50ms中断一次
          shi--;
        if(shi<1)//1s取数据一次
          shi=20;
          y=(TH1*256+TL1);//红外对管中断次数
          TH1=0x00;
          TL1=0x00;
          zhuanhuan();//数据转换
          xie(0xc6);
        for(i=0;i<4;i++)//LCD数据处理显示
           xieshuju(zhuan[ i]);
           delay();
void zhongd()  interrupt 3//红外对管中断次数
        TH1=0x00;
        TL1=0x00;
电路图
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
收藏收藏3 分享淘帖 顶顶 踩踩
ID:43559 发表于 2015-4-23 19:52 | 只看该作者
感谢分享。
ID:77707 发表于 2015-4-24 08:09 | 只看该作者
谢谢版主加分;谢谢关注。
ID:201577 发表于 2017-5-29 11:28 | 只看该作者
感谢分享
ID:92841 发表于 2017-7-8 17:28 | 只看该作者
谢谢版主,正好需要,学习中
ID:195884 发表于 2017-8-4 22:43 | 只看该作者
这个程序很巧妙,顶了
