查看: 2972|回复: 0
51单片机中断和查询工作模式的区别
ID:80436 发表于 2015-5-20 18:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
中断是硬件自动的清零,查询如果是查询的TFX就必须软件清零,如果查询的是THX和TLX就也是硬件自动的清零。验证的程序如:
#include <reg51.h>
uchar count ;
sbit LED=P3^0;
        TMOD = 0X01;
        TH0 = (65536 - 50000)/256;
        TL0 = (65536 - 50000)%256;
        ET0 =1;
        TR0 = 1;
            while(TF0 == 1)
                        if(count++ == 50)
                            LED =!LED;
                    TF0 = 0;
                }        //查询工作的模式        软件清零
#include <reg51.h>
uint count=0;
       TMOD = 0X01;
        TH0 = (65536-50000)/256;
        TL0 =(65536-50000)%256;
        ET0 = 1;
        TR0 = 1;
                if((TH0 == 65535/256)&&(TL0 == 65535%256))                {
                        count++;
                        if(count == 50)
                                P3 = ~P3;
                                count = 0;
                    TH0 =(65536-50000)/256;
