查看: 3838|回复: 0
USART test---ATMEGA128
ID:80436 发表于 2015-5-21 23:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  #include<avr/io.h>
#define fosc 16000000UL //晶振16MHZ
#define baud 9600//波特率
#define com0
void uart0_init(void)
     UCSR0B = 0x00; //disable while setting baud rate
     UCSR0A = 0x00;
     UCSR0C =(1<<UCSZ01)|(1<<UCSZ00);//8bit+1bit stop
     UBRR0L=(fosc/16/(baud+1))%256;
     UBRR0H=(fosc/16/(baud+1))/256;
     UCSR0B =(1<<RXEN0)|(1<<TXEN0);//RXCEN TXCEN
void uart1_init(void)
     UCSR1B = 0x00; //disable while setting baud rate
     UCSR1A = 0x00;
     UCSR1C = (1<<UCSZ11)|(1<<UCSZ10);//8bit+1bit stop
     UBRR1L=(fosc/16/(baud+1))%256;
     UBRR1H=(fosc/16/(baud+1))/256;
     UCSR1B =(1<<RXEN1)|(1<<TXEN1);//RXCEN TXCEN
void putchar0(unsigned char c)
    while (!(UCSR0A&(1<<UDRE0)));
    UDR0=c;
void putchar1(unsigned char c)
    while (!(UCSR1A&(1<<UDRE1)));
    UDR1=c;
unsigned char getchar0(void)
    while(!(UCSR0A& (1<<RXC0)));
    return UDR0;
unsigned char getchar1(void)
    while(!(UCSR1A& (1<<RXC1)));
    return UDR1;
void puts0(char *s)
    while (*s)
        putchar0(*s);
        s++;
    putchar0(0x0a);
    putchar0(0x0d);
void puts1(char *s)
    while (*s)
        putchar1(*s);
        s++;
    putchar1(0x0a);
    putchar1(0x0d);
int main(void)
    unsigned char i;
    #ifdef com0
    uart0_init();
    puts0("HELLO!");
    #else
    uart1_init();
    puts1("HELLO!");
    #endif
    #ifdef com0
        if (getchar0()=='t')//按键盘t键开始测试
            puts0("test ok!");
            for (i=0;i<10;i++)
               putchar0(0x30+i);
           putchar0(0x0a);
           putchar0(0x0d);
       #else
      if (getchar1()=='t')//按键盘t键开始测试
         puts1("test ok!");
      for (i=0;i<10;i++)
        putchar1(0x30+i);
         putchar1(0x0a);
         putchar1(0x0d);
  #endif
//USART test for atmega128
        seabiscuit
        2011.12.11.jiujiang
